Question about Maytag Performa PAV2200
The agitator doesn't work on the wash cycle--it will empty and spin on the rinse cycle! I checked the belt and the agitator splines ,makes a loud grinding noise on wash cycle
  • 1 more comment
  • vassilou Mar 20, 2011
    Part 30 is the drive belt,nothing wrong with the belt,still works on spin cycle,doesn't work agitator when washing cycle
    Part 30 as shown is not faulty,works on spine cycle and have checked belt,agitater not working on wash cycle,will not move and making a grinding noise
    No problem with belt,have checked,machine spins baut will not agitate in wash mode
  • Maytag Master
  • 12,061 Answers
Http://appliancejunk.com/forums/index.php?action=downloads;sa=view;id=8
Hi above is a place to obtain for free your service and repair manual, here there are troubleshooting steps to be performed to isolate the problem(s)
http://www.do-it-yourself-washing-machine-and-dryer-repair-help.com/
Above is a great DIY washer site to assist you to isolate and repair your problem.
Any grinding noises are NOT good, and if the belt is OK, then we must suspect something maybe caught in the pump, or a bad pump or gearbox? It's pretty hard to tell just from a description, well unless the description is unique, but noise can mean many things.
Now, if you don't wish to DIY then simply call in a Maytag serviceman, and then when he arrives ask for a "Quote" before allowing any work to be undertaken. This way you can make an informed decision as to what to do, repair or replace, depending on costings.
Posted on Mar 20, 2011
  • 10,319 Answers
That means the pump is doing its job so the direct drive coupler has sheared off between the transmission and the motor
My washer will not spin or agitate, but will fill & drain
with it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Feb 08, 2014 | Washing Machines
SPLINES STRIPPED
Replace this agitator coupling part number WH49X10042 make sure the inside of the agitator is not stripped.
Feb 05, 2014 | GE Profile WPSR3100W
Washer fills with water but doesn't begin to agitate to wash. It also drains but doesn't spin when we set the dial to that
Your agitator pindle. has come loose From the spline. Try to lift up on the agitator. If it lifts off the spindle easily then it has worn out the spline. That is what connects the agitator to the s
Feb 06, 2013 | GE Profile WPRE6100G Top Load Washer
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
Dec 25, 2017 | Frigidaire Washing Machines
I have a Maytag Model A412, series 11 washing machine. After the machine fills with water the machine appears to start its cleaning cycle but the agitator doesn't work. The water starts & the...
if this is a two piece agitator,it should behave like a ratchet turn freely clockwise and catch counter clockwise if it doesn't catch the agitator "dogs " are shot this is a verry inexpencive repair
Jun 08, 2011 | Washing Machines
My hotpoint washer will spin but will not wash or rinse, the agitator makes a noise as it attempts to wash and then rinse. the spin seems to work fine
The agitator shaft has splines at its top which fit inside a splined area inside the agitator. Sometimes the splines in the agitator strip; then you would need a new agitator. If that is not the case the problem is within the mechanism. There is a repair kit available for that, but you need to take the mechanism out of the machine. I am assuming that you have the "direct drive" machine, recognizable by the pump sitting at the front, in the middle, under the tub. If you have the older, belt driven washer, please get back and I will explain.
May 09, 2011 | Hotpoint Washing Machines
Loud banging noise during washing cycle. Sounds like agitator is slipping,then banging. No noise during spinning cycles.
Grab the agitator at the base and attempt to rotate it clockwise and counter clock wise. It should remain firmly in place. If there is movement the agitator spline is worn.
This is your Agitator:
http://www.repairclinic.com/Appliance-Parts?s=t-WBSR3140DW-%3d%3dc201
It does not come with the fabric dispenser. It has to be ordered seperately. You should be able to transfer you old one to the new one if you do have to replace the agitator.
Besides the agitator the drive bell can also be the source of the noise. It is located under the agitator.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WBSR3140DW-%3d%3dc239i1195917&PartID=1195917
This part is the most likely cause of the noise.
Thanks for using FixYa.
Kelly
Mar 07, 2010 | GE WBSR3140DW Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
