Question about Vacuums
I have a continental electric sewing machine, but I lost the instructions. I've figured out the top thread, I don't know how to thread the bottom bobbin
  • charles urban Mar 20, 2011
    what is the model #?
    Genius:
  • 1,075 Answers
On the bottom bobbin if you look you will see a small metal flap this is the bobbin tentioner simply make sure the thread is under this flap ,and the top needle will do the rest.adrian.
Posted on Mar 20, 2011
Adjusting the knobs on the front of my Singer 9005
If the bottom thread is showing through, back off the tensioner, 1/2 number at a time.
Jan 18, 2013 | SewShop.com 9005 Singer Instruction Manual...
How to get Brother sewing machine apart to replace spool spindle.
To be honest the best thingon such instructions is the manual which is provided along with the machines,but many people don't have it , probably because they have lost the manual orthey have got the machine as a used one and forgot to take the manual alongwith it.
Please follow the belowinstructions :-
Close to the end of theHandwheel , there is usually a spindle, at the back of the machine.
This is where you need to restthe spool on and you would notice it sitting perfectly.
In case the length of the spindleis less , then pull it up gently with your fingers.
Also there are machines these dayswhich have easy to replace facilities , so the spindles just slide intothe machine for safety norms when you put the machine away.
Therefore , all you need to do it pullit up and it would be fine.
An example of a manual forbrother's sewing machine can be found in the below link which would give you anidea of how exactly it's done.
http://bit.ly/j2BdsP
Hope this helps ..:)
Jun 11, 2011 | Vacuums
I was given this machine but do not have instruction booklet how do I thread it?
MCICCONE, we're going to need a little more info about the vacuum before we can answer this. First off, what is it you're trying to thread? I don't know of any vac's that have any parts that require being threaded anywhere. If it's a sewing machine, then that's a different story.,
Apr 22, 2011 | Vacuums
I have a Janome 8048. Here's my problem: As I sew I notice that the stitches on the top of the fabric look the way they should on the bottom side and when I take the material off the machine and flip it...
I haven't sewn in years. A sewing machine has a tension control on top and on the bobbin. If the intersection of the top and bottom threads is not in the middle of the sewn material, you have to adjust your tension.
In your case, what I think you are saying is that the stitch on top is just a straight line and on the back it disappears into the fabric.
To correct this, lower the top tension by loosening the tension adjuster on the thread where the thread loops around the small pulley.
Also, you could tighten the tension on the bobbin by slightly tightening the small screw on the side of the bobbin.
Gary
Feb 21, 2011 | Vacuums
I need to know how to thread a perfection sewing machine because I've lost the instructions.
hi, I have a few questions:
1- Your question is listed as a "Vacuums Problem". is that correct?
2- Your writing is broken-up, I think that you have a problem with a sewing machine. is that correct?
If correct, can you tell me that brand, and model of it?
3- What exactly you are trying to do?
Jan 04, 2011 | Vacuums
I have a model 605d ,the machine work fine except it will not sew! i look over the machine it look ok ! i am found out that top spool thread and the bottom bobbin thread are not coming together to sew!
You have to do the first stitch using the handwheel so that the top thread catches under the bobbin thread and then you can pull the top thread which will bring up the bobbin thread. put both threads to back of machine. Now you can sew.
Every time you re-thread you need to do this.
Dec 21, 2010 | Vacuums
With my K6 Industrial Singer sewing machine the top thread seems to be too tight. The bottom thread is looping too much on the top of the fabric. The timming is ok. I have checked and rechecked that I have...
Hello there, loosen your top thread tension,if it looping on top of the material the tension is way too tight, you will also find changing the thread size to smaller thread, the top tension will also reduce,depending on application a good size thread to use is 25 grade,bobbin tension should have just a slight amount of drag as the top thread and bottom work against each other when sewing.
regards
Tony
Apr 04, 2008 | Singer Vacuums
Vacuums Logo
716 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
