Question about LG Washing Machines
Lg intellowasher 7.5kg WD-8016F OE showing on display wont finish cycle
  • 383 Answers
SOURCE: OE problem with the LG WD - 12270BD Washer
Turn the knob to start and restart again let it run thru the course.
AND IF THIS DONT WORK TRY THIS:
Put knob on spin and let it run thru the course.
Posted on Nov 26, 2007
MNTECH
  • 1543 Answers
SOURCE: lg intellowasher DD 7.5kg WM14225FD error
I think your "OE" is really a "DE" or drain error. Open the access door on the lower left of the front panel on the machine, drain the remaining water with the small drain hose there, and unscrew and remove the larger thing, which is a filter. Clean filter. If filter was not blocked, check for loose impeller on drain pump motor, which requires replacement of drain pump motor. (just sticking it back on will result in it coming off again)
If this helps, a "fixya" rating would be appreciated. Thanks.
Posted on Oct 01, 2008
  • 73 Answers
SOURCE: My LG Clothes Washer has
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
Posted on Apr 29, 2009
  • 901 Answers
SOURCE: LG Intellowasher 7kg, Model WD-8074FHB - noisy spin cycle
You are right!
Bearings have to be replaced. Replace with the same type and design. All the bearings connected to the washer center shaft has to be replaced at the same time with new set.
Replace the water seals also connected to this. Check the shaft where the bearing sits, for any abrasions or metal damage.
Check the bearing housing also. While carrying out these repairs check the drive belt also. If needed replace it.
If you are happy with the machine outer body and other aspects repair it and re-use it.
Posted on Apr 07, 2010
Testimonial: "Thanks for the quick reply Ambari, that's exactly what I wanted to know. Atleast I'll some idea if the repair bloke is pulling a swifty. Cheers"
jumptrout51
  • 3361 Answers
SOURCE: Manual for LG Intellowasher 7kg
While not exact to your model,this manual may answer your questions.
http://136.166.4.200/contents/Laundry/WD-1070FH/WD-1070FD_Service_Manual.pdf
Posted on Sep 08, 2010
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Wash cycle works ok but will not spin and oe appears in digital display then it switches off. We have just had drum and shaft and bearings replaced, repair man ran it then when we trid to use it it has...
This is what "OE" Means :
"OE" Drain error. Cause: not fully drained within 10 minutes Check there isn't a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge
Feb 09, 2011 | LG Washing Machines
My LG intellowasher 7,5kg WD- 8016c is flashing the letters OE Can you please tell me what this means
An OE error presents if the washing machine has not successfully drained the water in ten minutes. However, the OE error code does not always mean that the washer requires a service call. If periodic maintenance has not been performed on the washer, there are a few simple steps to take before calling for service.
LED display models LCD Display Models
Step 1: Check the drain pump filter.
Step 3: Confirm that the washer is leveled properly.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a LEVEL on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
NOTE: Perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Washing Machines
LG Intellowasher (Model WD-1023C)
The water pump can be blocked and thus stop the machine from finishing the wash cycle. In front on the bottom there is as hatch that can be opened with a flat screwdriver, the small black rubber pipe can be used to first drain all the water before the opening the filter. Small objects such as coins coluld be found in here, blocking the pump. Clean the pump by removing these, optionally blowing into the outlet (yuck!), to dislodge anything. If that does not help to fix the problem, you can clean that actual water pump, but this requires you to use a screwdriver to remove the pump.
Tilt the machine on its side, the pump is attached with 3 self-tapping screws. (if you can't figure out what the pump is you should probably let a technician do this). The pump has 2 parts to it, take it apart carefully and clean out all the dirt that has accumulated in there. Plastic friendly, waterproof grease can be applied to the pump spindle and bearing if available.
If the problem still persists a new pump is available from LG at a reasonable cost.
Jul 30, 2010 | LG Washing Machines
Lg wd-8013, all lights on at end of cycle door wont open
It sounds like you have a faulty interlock. This is what locks the door during the wash cycle.Sometimes they won't unlock and need to be replaced. There may be a pull tab inside the pump access area at floor level to get door open....Not a big job for a tech......Nomess
Apr 12, 2010 | LG WD-1045FH Front Load Washer
Lg intellowasher wd-8013f is very noisy
You suspect right.
It is a complete strip down job. I have just finished mine.
taking apart and reassembling is not too dificult.but you need to make up a tool to remove and replace the bearings which are two different sizes. It consists of a lenghth of studding, bolts and washers.
Download the manual from LG.
Good Luck
Mar 17, 2010 | Washing Machines
Washing Machines Logo
75 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
