Question about Microwave Ovens
I have an Everstar HDIM90. I get one harvest, then it freezes up. Any clue what the problem may be? I am thinking the ice sensor. I also need to know where to find parts.
I installed a new fridge filter and now my ice maker will not make ice.
Check the direction of the water flow for the filter, did you put it on backwards? Did you open the pep-**** to allow water to flow to the unit again? Did the ice-maker line freeze up when you were changing the filter. These are all things that are common mistakes when changing the filter. Check this things out and get back to me with an update...
Jun 14, 2011 | Microwave Ovens
I dont think the thermostat is working properly..sometimes freezer will not freeze and it keeps icing up and blocking everything with ice
Your right thermostat has the problem. Call your local refrigerator service center for a thermostat replacement or do it on your own if you can. But unplug the AC cord before doing that.
I hope I help you solve with you problem.
Mar 29, 2011 | Microwave Ovens
My GE Monogram ZDIS15CSS ice maker fills the bin with water but does not pump water over the plate to produce ice. We did drain and shut unit down for 2 weeks and it would not start on our return. Can...
I would check the ice level sensor... it is shown on page 9 of this manual...
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60440.pdf
If the sensor thinks that the bin is full it will not do anything...
That is why that would be my first area of interest..
heatman101
Mar 24, 2011 | Microwave Ovens
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
Food in the refrigerator department is freezing. I checked the refrigerator temperature setting and it is 46 deg f. I checked the freezer temperature setting and it is 5 deg f. I put a NIST traceble...
When the refrigerator side is getting too cold this is because the control of the compressor has gone bad in some way...
There a few different things that could cause the unit to lose control over the temperature of the fridge side.
If your refrigerator has a damper door that opens and closes to allow cold air to move to the fridge side the damper linkage or the damper motor may have broken or gone bad.
The coils in your fridge may have frozen over and now the air does not move at all so then the ice builds up and can freeze parts of the fridge side.
The thermostat has gone bad and so now the compressor runs continually. This will not be noticed readily on the freezer side but will show up quickly on the fridge side.
Many newer model refrigerators use an electronic sensor or thermistor to read the temperature and supply the info for the circuit board and often a digital readout.
So, here is how I would go about troubleshooting this problem.
Check the coils for ice, defrost the coils with a heat gun or hairdryer, then check for the reason why they iced over. Defrost control or defrost timer bad? Evaporator fan bad?
Check the damper door to see if it is stuck in the open position. If it is then check the motor and the linkage.
Check to see if the refrigeration unit will shut down if the thermostat or digital setting is turned up to a higher temperature. If it continues to run then find the cause and fix it. It may be a bad thermostat, sensor, or control board.
Sometimes with a change is weather to a cooler climate this will be enough to also affect the inside temperatures. Make sure that a bit of adjustment in the thermostat or setting of the temperature will not solve your problem very simply.
I hope the above helps.
Good luck.
Jan 13, 2011 | Microwave Ovens
Not making ice. water is getting to the water dispenser but don't know why it is not getting to the ice maker itself. how do i check it/repair it.
Hia and wl;ecome to FixYa, I am Kelly.
We really need a make and model number to provide you with specific unit applicable information but.... in general, here goes:
1. Ice makers must have a freezer temp below 16 Deg F. If there is an airflow problem in the freezer caused by a fan or ice build up the ice maker will no longer make ice.
2. The ice maker has a thermostat that controls the harvest and fill cycle. If the thermostat fails it will stop making ice.
3. There is a water valve in the back of the unit that has TWO electric solenoids on it. One for water in door and one for ice. If a solenoid fails it will stop providing water to the applicable function. I.e water in door or ice. You can briefly remove the fiberboard back cover to gain access to the water valve. Then switch the installed terminal connection between solenoids. Left to right or front to back depending on how it is mounted. Then try the water in door. If water flows to the ice maker when water in door switch is actuated then the solenoid for making ice is good and the probem is with the icemaker. (Reconect wires in original positions.)
Note that anytime you remove power from the unit you must wait 10 - 15 mintues before re-applying power so the coolant system can stabilze. Other wise the compressor will not start.
Here is a web link that will help most people troubleshoot ice maker problems:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
The link above is pretty good.
There is a 48 page job aid also for whirlpool in door ice that is also a big help:
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/8527f904cc8ea8cd85256b5800672333/$FILE/4322658A.pdf
This should help you find out why it is not making ice.
Thanks for choosing FixYa,
Kelly
Oct 26, 2010 | Microwave Ovens
Need directions for use & care of American Harvest snackmaster jr 50/60/70
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Oct 25, 2010 | Microwave Ovens
I have a CEM Global PS78121 ice maker that has quit making ice after one month of use. I don't have a manual to trouble shoot it and need help. The compressor won't keep running to freeze the ice. Then if...
The problem is that the tabs on your white plastic tray with the ice falls into our broken off. I have the same problem. I am looking for a source to buy the new ice tray. If you have any knowledge of where to get parts for this piece of junk please let me know.
Aug 31, 2010 | Microwave Ovens
Model # trt18GREW5 ice maker will not make ice, and no water flowing thru valve w/ water supply on and water tube to ice maker disconnected
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Water doesn't flow unless the ice maker calls for water which it does immediately after dumping the previous load of ice.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Dec 18, 2009 | Microwave Ovens
Ice jam in haier freeze
No you can use a hairdryer to melt it.
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Dec 12, 2009 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
