Question about Boss AUDIO SYSTEMS CX250 Car Audio Amplifier
MY BOSS 1600 WATTS AMP JUST STOP WORKING IT JUST TURNED OFF WITH OUT MESSING WITH IT WHATS SO EVER... I REPLACED THE FUSES AND NO SIGN OF TURNING BACK ON????
5 Suggested Answers
  • 631 Answers
SOURCE: boss chaos 150 200 watt that shows light but doesn't produce sound
If this is the CH150, it's not bridgeable. Try connecting it normally (one speaker per channel) to see if it will produce output.
Posted on Dec 05, 2007
  • 518 Answers
DID YOU CONNECT THE JACKS FROM THE HEAD UNIT? JUST A THOUGHT AS THIS IS EASY TO OVER LOOK
Posted on Jun 13, 2009
craigperry23
  • 185 Answers
SOURCE: i have a boss rt645
That all depends on the wattage of the subs. also the independance of the subs. If your amp is 1400 watt, maximum you want is 2 600watt subs. if your subs are higher you will blow your amp eventually as your amp isnt powerful enough to pump out to that level.You should never have your amp fully turned up to max, 80% is perfect and will not make your amp blow. Hense why you want your subs less than the max output of your amp.
Posted on Mar 04, 2011
mr1967mejias
  • 637 Answers
SOURCE: when i hook up my
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you. Good Luck.
Posted on Dec 20, 2014
Why does my boss 1600 watt diablo amp cut off at high volumes
Chances are your speakers are running at to low of impedance. Check if your running aftermarket. speakers, if so they are probably wired in parralle. Change the wiring to "series"increasingly your impedance from 2ohms to 8, that should solve your issue.
Mar 01, 2015 | Boss Car Audio & Video
I have a 1600 watt boss chaos amp it has power no sound rca jack good fuzes are good no burnt smell every thing is good just dosent have any sound
You need to check the 2 sets of fuses on the face of the unit.
Try removing the fuses and resetting them.
Power hookup is 12+, remote power on and negative.
Apr 26, 2014 | Car Audio & Video
Protective mood on boss 1600 watt amp
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Might be time for an old s .A thumbs up would be greatly appreciated if this answer is helpful to you. protective-mood-boss-1600-watt-amp-zb4bomd1rt4qms0dqd12kkt2-2-0.jpg
Jan 16, 2014 | Car Audio & Video
Capacitor not working properly
the power side has to be in line with the battery power side! The ground side to ground! The power that ran from battery (fused) to the amp power is used and cap is tapped in line, on that power lead! that way your amp gets power with cap charging and stable voltage to amp! taking stress off your charging system and better sound! good luck!
Jun 09, 2017 | Pyle BZDBP212 Car Subwoofer
Best car amplifier
I've got a boss 1600 watt 4 channel amp ,720rms watts. up for auction on ebay right now that would work great. brand new in box. check it out. http://shop.ebay.com/?_from=R40&_trksid=p3984.m38.l1313&_nkw=boss+1600w+amp+4+channel+with+level+remote&_sacat=See-All-Categories
Oct 05, 2009 | Cars & Trucks
Speakers cut off when bass goes up
probably the amp going to safe or protect mode judging by the fact that you have 3 subs wired to it i would say it is not 1 ohm stable try disconnecting 1 sub and see if it still happens this will be running a 2 ohm load rather than 1 if it stops happening then you need to figure out a better wiring configuration that will work with your amp.
Jul 03, 2009 | Kicker ZX400.1 Car Audio Amplifier
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
Boss 3500 Watt Monoblock Amp stops putting out signal
What's the battery voltage across the B+ and ground terminals of the amp when the engine is running?
Does the amp go into protect mode when the engine is running?
Are you sure the head unit is still producing output when the engine is running?
Apr 09, 2008 | Car Audio & Video
Boss AUDIO SYSTEMS CX250 Car Audio Amplifier Logo
20 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
