Question about Jensen Car Audio & Video
How do I bridge my jensen 200watt bridgeable amp
    Scholar:
  • 71 Answers
To bridge an amp, connect the negative speaker lead of a speaker to the negative terminal of the first channel, and the positive speaker lead of the SAME speaker to the positive terminal of the second channel.
Posted on Mar 20, 2011
How to bridge a 1 channel 1000 punch 55amp
You can not bridge a 1 channel amp. Bridging is when you combine the output of a bridgeable two channel amp into one channel, typically to power a sub woofer.
Feb 13, 2012 | Rockford Fosgate Car Audio & Video
How do i bridge all 4 channels on the jensen 400 watt 4 channel lxa amp ?
  • This amp is not "bridgeable" at all. You will either blow the front end or blow the low end voice coil in your sub.
Regards, Tony
May 24, 2011 | Jensen LXA400 Car Audio Amplifier
What fuse do i use for my Jensen 2 Channel Bridgeable Amplifier with 300 Watts Peak? thank you.
Watts = Voltage x Current
300 = 12 x Current
Current = 25 amps
Sounds like a 30 amp slo-blo fuse would be about right -- you could start with a 25 amp and see if that holds it.
Charlie
Jan 05, 2011 | Jensen XA2150 Car Audio Amplifier
How do i bridge my jensen 200 watt amp? its a 2 channel bridgeable.
Easy, you grab a dual wire cable (like the one in the back of your amp that runs to the speaker) and stick each wire on one end to the positives on your amp. Then, on the other end, twist both wires together to form one wire. Hook it into your positive connection on the sub(s). Repeat on negative side.
Aug 09, 2010 | Jensen Car Audio & Video
4 chanel amp I dont know how to conected,to radioand one subwoofer
Hello canelo63,
Your question appears under the product listing for the Dual XPA4100 but the in the text you say the amp is actually a Jensen, so it's not possible to provide specific connection information.
But most bridgeable amps can be connected to a single subwoofer and the other two channels used to drive a set of regular speakers. I'd connect the front speakers to channels 1 and 2 and wire the subwoofer to the bridge connections of channels 3 and 4. On the XPA4100, the bridge terminals are the first (negative) terminal on channel 4 and the last (positive) terminal on channel 3.
Hope this helps.
Jun 01, 2009 | Dual 2-Channel Bridgeable MOSFET Amplifier...
I have a Jensen A222HX amplifier. I want to hook a subwolder to it. How do I bridge the connection
Hello rcell66,
The Jensen A222Hx is an "old school" amp and the channels are probably not bridgeable. I'd recommend posting and/or researching your question on one of the "Car Audio" forums. Many of the members are old school trained and may even be able to locate a manual for Jensen's.
Hope this helps.
May 12, 2009 | Jensen Car Audio & Video
Bridging the Warrior IS600 Amplifier
No this amp can't be bridged but you can use a third party component that allows any stereo amplifier to be bridged. Try an electronics retail store such as Radio shack or similar for such a device.
Mar 04, 2009 | Audio Players & Recorders
Is it not bridgable
This amp isn't bridgeable. It's a mono amp (only one channel). You need two independent channels to bridge. Some mono amps are bridgeable if you have two identical amps but I don't think Kenwood recommends that with this amp.
Jan 27, 2008 | Kenwood KAC-9152D Car Audio Amplifier
Bridge a not bridgeable amp
It will probably blow a fuse or blow up completely.
When the output stages ar not lifted from ground
as is the case in a bridgeable amp bridging cannot
be done.
Jan 12, 2008 | Performance Teknique ICBM-782 Car Audio...
Car amp
if you are talking about speaker terminals i would have to know the model you are referring to. take a look at where the speakers hook up, you should have +-+- if it is bridgeable it will usually have markings below or above those that only show 1 + and 1 - ... connect your positive to the single specified and negative to the other specified... you may or may not be able to bridge it with a wire, without the amp model, i can not say for sure...
if you are talking about actual power connections, then yes you can bridge them, i have an old amp here that has 1 remote, 2 positives and a large negative.. i bridged the positives using 6 gauge wire and used a 2 gauge for the negative...
hope this helps,
trin
Nov 14, 2007 | Jensen XA92 Car Audio Amplifier
Car Audio & Video Logo
220 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
