Question about Sunpak (611-284) Tripod
The bolted screw on my 7500 TM has been cut in half. I am unable to screw my camera onto my monopod now. How can I replace it? Or is that even possible?
    Sergeant:
  • 192 Answers
Sure just go to any store and pick up a cheap monopod/tri-pod and replace it.
Posted on Mar 20, 2011
How do I change the thread size on my monopod?
You should not need to change the thread size on your monopod. All tripods, monopods, cameras and other accessories have standard fittings. Check that you haven't accidentally crossed the threads on your Panasonic which would make it difficult to locate the threads to tighten it.
Also, check that you are not trying to screw the monopod into the hole. Some cameras have a smaller hole beside the tripod thread.
You may be able to contact your monopod manufacturer in case they supply an adapter that wasn't supplied with your monopod.
Sep 18, 2014 | Manfrotto 290 Series 59.4" Monopod
I have a QS-TM and I want to know if there is an attatchment to let me use this tripod for a canon camera?
Tripod mounts are standard size for most cameras, there are strictly speaking 2 sizes but it is unusual to find a modern camera with the wrong size; it should screw directly into the camera (assuming you have a "standard" mounting plate with the tripod!) If it is too large/small you need an adapter, 3/8" to 1/4" or vice versa, but that would be unusual. Most 35mm camera bodies accept a 1/4" diameter, 20 thread-count screw
Jan 11, 2011 | Quantaray Photography
How is the camera mounted on the tripod? I do not kow how to screw camera onto mount base
Cameras have a threaded hole underneath. See this photo:
10ef583.jpg Tripods have a threaded screw with a large thumb wheel to lock it in place. See this photo.
That's all there is to it. Good luck.
Thanks for using Fixya.
Dec 21, 2009 | Bower Photography
Attachment at base of camera - SLIK 88M
The standard tripod screw mount is 1/4"-20tpi. 1/4"-20 UNC will also work. You should be able to find such bolts at your local hardware store.
Jul 27, 2009 | Nikon Slik 822 Tripod
Need manual for kodak Gear Tripod 60'' or instructions about it's
Look at the bottom of your camera and you should see a hole where a screw would screw into. That should be the screw on the top of your tripod.
Mar 17, 2009 | Tiffen Kodak Gear Mid-Size 60" Tripod with...
Panning Head came off of new Quantaray QSX 900TM Tri-monopod
It's supposed to come off.  There is a 1/4" screw stud on top of the monopod that it tightens onto.  This is how you change heads if you want to use a ball or other head.
Feb 08, 2009 | Quantaray 7-Inch Digital Picture Frame -...
Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Mar 16, 2008 | Bogen Communication Bogen Manfrotto 3047...
Kalimar Pro V-40 Tripod
If you have lost the screw no problem. Take the camera with you and go to you r local hardware store and fit it with a new bolt or srew.. It will be a standered size and thread. I loose this part all of the time
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Dec 26, 2007 | Kalimar V-20S VIDEO TRIPOD
Sunpak (611-284) Tripod Logo
135 people viewed this question
Top Sunpak Photography Experts
Andrew Taylor
Andrew Taylor
richie46
Jay Plesset
Are you a Sunpak Photography Expert? Answer questions, earn points and help others
