Question about Dell F3534 Touchpad
When I am typing into my email account my cursor will jump into other lines and worst of all - a line or a chunk of text will get highlighted and then as I am typing on it will delete it. My other Dell computer would do that but this newer one is worse, My neighbor who has a different kind of computer has the same problem.
  • salton1 Mar 20, 2011
    Is it because I am touching the keypad when I am typing that this happens.I have several friends with the same problem so it must be something we are doing when we type. If that is the case - I have seen a utility called TouchPad Pal which disables the touchpad when typing.
    I have no stuck keys. My antivirus is McAfee - just installed and working fine. The touchpad driver says it is the lastest version.
  • 4,281 Answers
Make sure that there is not any key jammed on keyboard also make sure that when you type email your fingure don't touch the touchpad.
Reinstall touchpad driver.
Then if still same then need to restore computer on previous point.
Also scan computer with updated antivirus.
For that go to start menu->accessaries->system tools->system restore.
Then restore to previous date.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Mar 20, 2011
  • yes it is possible if your hand touch the touchpad or left click then this problem occurs.
Samsung labtop cursor jumps around when typing causing all kinds of problems including highlighting and erasing entire lines or sentences!
Press Fn & F10. This disables the touchpad. You will have to use arrows or a mouse to move the cursor. This helps when you are doing a lot of typing. Press the same keys to enable the touchpad when you are finished typing.
Jan 21, 2012 | Samsung N150 (36725723009) Netbook
What says home or end keys
it is primarily used to return the cursor to the beginning of the line where the cursor is located. When the text is not editable, the home key is used to return to the beginning of the document; this can also be done in editable text if the key is pressed along with control.
The home key can also be used to highlight all the characters before the cursor in a certain line if pressed along with shift in editable text.
The home key will take you to the beginning of the line you are on - try it, type a bunch of stuff then hit the Home key and you will be brought to the beginning of the line. If you are in a multi-line document, hitting CTRL+Home will bring you to the start of the entire document.
Similarly, the end key will take you to the end of the line while CTRL+end will take you to the end of the document
Hope this helps. Please rate my response.
Thanks.
Have a good day
Dec 18, 2010 | HP 381068-001 Pavilion ze2000 Keyboard
I want short cuts in ms word
You can use this
Ctrl + A Select all contents of the page. Ctrl + B Bold highlighted selection. Ctrl + C Copy selected text. Ctrl + E Aligns the line or selected text to the center of the screen. Ctrl + F Open find box. Ctrl + I Italic highlighted selection. Ctrl + J Aligns the selected text or line to justify the screen. Ctrl + K Insert link. Ctrl + L Aligns the line or selected text to the left of the screen.
Ctrl + M Indent the paragraph. Ctrl + P Open the print window. Ctrl + R Aligns the line or selected text to the right of the screen. Ctrl + T Create a hanging indent. Ctrl + U Underline highlighted selection. Ctrl + V Paste. Ctrl + X Cut selected text. Ctrl + Y Redo the last action performed. Ctrl + Z Undo last action. Ctrl + Shift + F Change the font. Ctrl + Shift + > Increase selected font +1pts up to 12pt and then increases font +2pts. Ctrl + ] Increase selected font +1pts. Ctrl + Shift + < Decrease selected font -1pts if 12pt or lower, if above 12 decreases font by +2pt. Ctrl + [ Decrease selected font -1pts. Ctrl + Shift + * View or hide non printing characters. Ctrl + Moves one word to the left. Ctrl + Moves one word to the right. Ctrl + Moves to the beginning of the line or paragraph. Ctrl + Moves to the end of the paragraph. Ctrl + Del Deletes word to right of cursor. Ctrl + Backspace Deletes word to left of cursor. Ctrl + End Moves the cursor to the end of the document. Ctrl + Home Moves the cursor to the beginning of the document. Ctrl + Spacebar Reset highlighted text to the default font. Ctrl + 1 Single-space lines. Ctrl + 2 Double-space lines. Ctrl + 5 1.5-line spacing. Ctrl + Alt + 1 Changes text to heading 1. Ctrl + Alt + 2 Changes text to heading 2. Ctrl + Alt + 3 Changes text to heading 3. Ctrl + F1 Open the Task Pane. F1 Open Help. Alt + Ctrl + F2 Open new document. Ctrl + F2 Display the print preview. Shift + F3 Change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word. Shift + Insert Paste. F4 Repeat the last action performed (Word 2000+) F5 Open the find, replace, and go to window in Microsoft Word. Ctrl + Shift + F6 Opens to another open Microsoft Word document. F7 Spell and grammar check selected text and/or document. Shift + F7 Runs a Thesaurus check on the word highlighted. F12 Save as. Shift + F12 Save. Ctrl + Shift + F12 Prints the document. Alt + Shift + D Insert the current date. Alt + Shift + T Insert the current time.
Oct 11, 2010 | G7 Productivity Systems VersaCheck For MS...
Jumping cursor of a
Hi! I think youre probably having a jumping cursor where the cursor jumps from one place to another while typing an email or something. You may got to control panel - hardware - mouse then look for the check box that you can tick on that says "Tap off while typing" and this should fix the problem. Thanks for visiting FixYa.com!
Jun 04, 2010 | Dell Inspiron 1525 Notebook
General question
the preferred documentation or medium must be highlighted with the mouse cursor and a left click . hold the button on the mouse down while dragging the mouse across the screen
So now that your email address or text message or whatever you need copy and pasted is highlighted you need to copy it.
copy is achieved by holding down the control key labeled ctrl as well as the c button simultaneously - ctrl + c.
paste is then performed by left clicking with the mouse cursor in the area you would like to paste your selection. and Control + V
Mar 10, 2010 | Computers & Internet
I have an Acer laptop. While typing the cursor suddenly jumps up a couple of lines, or suddenly may highlight a phrase, causing instant erasure of the previously typed material. Why does cursor continually...
your palm might be hitting the touchpad causing your mouse cursor to move and jump around... try to type with only your fingers hitting the keys and the back of your hand raised and not hitting any part of your laptop... hope this helps....
Nov 10, 2009 | Acer Aspire 5315 Notebook
Cursor jumping, pages scrolling on own
bad mouse action , no other words need be said just that.
NO OP SYS STATED BY YOU< XP?
if the mouse is a wireless mouse, the battery is dead.
if the 1 mouse is wired it is bad.
if there are 2 mice connected , shut one down 2mice not allowed.
if the mouse pad is enabled then that is 2 mice if usb mouse used.
and not ever good to do that,
disable one of the mice. (easy no? rules)
i disable my LT here, , in control panel, device manager , mouse pad synaptic or what ever it is.
RC right click disable, it , I hate mice pads././/
Feb 28, 2017 | Compaq NX9005 (dk993ar) PC Notebook
My cursor jumps ever time i try to type and will jump to another line, like now, it jumped to, "and will"
I thought the problem was fixed but I spoke up to quick.
The problem with the cursor jumping to another line, continues.
The $9.95 I payed was for not.
I can't type this without the cursor going to another line I
have already typed.
Jan 16, 2009 | Computers & Internet
Cursor jumps erratically
Most likely, your wrist is gently touching the touchpad, and your computer is interpreting it as a 'tap,' and it so happens your cursor was located several lines up.
Or if you use a separate mouse, is it on a wood or uneven surface? This will cause it to jump up those few lines and again, your wrist (or if you have big hands like I do, the bottom of your thumbs) will tap it.
Apr 02, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
187 people viewed this question
Alun Cox
