Furnace wont restart in the middle of the night..when safety switch is reset furnace kicks back on. dont know why the furnace wont restart in the middle of the night
    Problem Solver:
  • 3 Answers
Please provide the make and model number and specify the location of the safety switch you are talking about.
Posted on Mar 21, 2011
    Sergeant:
  • 259 Answers
If it is oil fired furnace I would change the nosel and filter and make sure the electrodes are set right.
Posted on Mar 20, 2011
Intertherm furnace ignitor will not kick on
furnace operation= call for heat- inducer blower motor energizes- pressure switch makes- after a few seconds ignitor activates.
If this series of processes is not whats happening the furnace may be going into a code safety. Call to discuss further=913-557-9111
Feb 25, 2014 | Intertherm 56000 Btu Gas Furnace
Furnace will not ignite. Inducer motor and blower motor kick on at the same time. Safety switches have been checked. Circuit board and igniter assembly is good.
what brand furnace is it? is there any blinking light on the control board? is the tube going to the pressure switch blocked? there should be a tube going from the pressureswitch to the inducer motor housing take it loose from the inducer and check for obstruction there,dont blow back into the switch.
Dec 11, 2010 | Heating & Cooling
Furnace wont ignite
check all safety switches located at burners and draft hood its a little round disc with a button that can be pressed to reset it.if there is an inducer motor check to see if the pressure switch is being pulled in it might be weak or you might have a clogged chimney.
Mar 22, 2010 | Heating & Cooling
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
Furnace won't kick in when thermosat is turned up. Was able to get furnace going by jumping wire on control valve , but it has kicked out in the middle of the night. Had a tech over to look at it and he...
If this is a High Eff. Furnace, sounds like the pressure switch is holding furnace out. Check to make sure Intake vent is not plugged. Make sure
that the exhaust vent is not getting backpressure from
windy outdorr conditions.
Jan 08, 2010 | Heating & Cooling
Furnace not cycling properly.
you might want to check the filter, if the filter is restricting the airflow the furnace will over heat and it will shut down. if you turn it off and on it will reset it and it will try again. Pull the filter out half way and try that, if it runs fine then clean the filter or get a less restrictive one.
Feb 06, 2009 | Coleman Propane Forced Air Heater...
Thermostat seems to be working, furnace does not always turn on
Joss sounds like the anticipator setting on thermostat i would replace it with a digital it will be more actturat . The furnace has to go over temp setting to turn off
Jan 15, 2009 | Honeywell Electronic Programmable...
Will not kick on at times.....
YOU MAY HAVE TO ADJUST THE INDUCER A HAIR!
Dec 10, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
93 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
