Question about Whirlpool Dishwashers
My dishwasher doesn't clean the dishes very well. It drains well. It used to work fine. Something's happened in the last 30 days where it leaves grease and mess all over the plates. There is water. he soap dispenser is working. What trouble shooting tips can you share with me.
  • Whirlpool Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Posted on Mar 20, 2011
I have a maytag quiet series 300, dishes dont get clean on top rack and sometimes it doesnt drain. do i need to clean some trap or drain?
Check the screen area around the sump right below the lower spray arm if it is built up with lime deposit then the wash pump is starving for water and cannot pump water to the upper spray arm this would also starve water to the drain pump.
Mar 06, 2014 | Dishwashers
Dishwasher won't drain completely. Several inches of standing water left after last cycle
Sounds like the wash/drain selector valve might be stuck. my Kenmore operating solenoid rusted and hung up. I cleaned and oiled it up. You can also have something that got into the valve and it won't close, or an obstruction in the drain hose or the drain pipe connector. Something is restricting the flow or the pump itself may have a bad impeller. Does it wash with vigor or has it lost a little oomph and sound different? Does it leave any debris on the dishes?
Jan 25, 2012 | Dishwashers
Built in dishwasher. Dishes are clean but leaves the interior dirty. Have cleaned it with dishwasher cleaner, then a few weeks later its grubby again.. This has just been happening in the last few...
Check your drain hose to make sure no water from the sink is draining back into the dishwasher.
If it is,re-hook the drain hose up high under the sink.
Next.
Start the dishwasher without dishes or detergent.
Once the fill and was cycle begins,open the door and por in 1 quart of WHITE vinegar and resume the wash cycle to completion.
Mar 19, 2011 | Kenmore 15769 Built-in Dishwasher
My dishwasher is leaving water in the bottom after finished. The dishes are not cleaning. Are the two related?
Yes more than likely you have a restriction in your pump/drain. you will need to remove the drain cover in the bottom of the dishwasher and clean it out
  • Empty the dishwasher and remove the dish racks so that you can easily locate the drain inside your dishwasher. The drain is under a drain grate, usually at the back of the dishwasher.
  • Remove the drain grate by either popping the grate out, or by unscrewing the screws holding it in place. Different types of dishwashers will have different options.
  • Use the soapy water and the toothbrush or scrub brush to clean inside the drain area and the grate.
  • Rinse the drain area with clean water. Then replace the drain grate.
  • Pour ½ cup of salt, 1 cup of baking soda and 2 cups of vinegar into the drain (in that order). The mixture will bubble. This will clean the drain and the drain hose.
  • Wait until the vinegar/baking soda mixture has stopped bubbling. Then pour 1 cup of bleach into your detergent dispenser. Replace the dish racks and run the empty dishwasher on a regular cycle. This will clean the entire machine
  • If this does not solve the issue your drain hose may be plugged or crimped and lastly your pump may be failing.
    Feb 11, 2011 | Microwave Ovens
    Dishwasher won't drain. this has been an ongoing problem since about 6 months after we bought it. a repair person came out and said it was our fault because we clogged up the drain. this was not true. ...
    This happens to me about every year an a half. The drain in the dishwasher is clogging. You can purchase a cleaner to open it up. I took mine apart an was shocked at how much stuff builds up an cliffs the drain an will not finish draining the machine. Dishes are clean but not all the water leaves, after a while it leaves more water. It takes to washing with the special detergent you can buy. It's not your fault it's the way they are designed an it has to be done on mine about every year or so. You can find the stuff you need where the dishwashing detergent are sold. It's just a cleaner an Clorox mixed that breaks that junky build up.
    Jul 21, 2017 | Whirlpool GU3600XTV Dishwasher
    There is a lot of crud in the bottom of my dishwasher. It is 4 years old. the dishes are not clean.
    Hi
    Thanks for using FixYa. Check the water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible.
    This would have happened as the dishwasher was overloaded with more than prescribed number of dishes. Check the spray arm and pump cover for splits or leaks. As the dishwasher is not draining properly, this issue is related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
    Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Jan 21, 2010 | Dishwashers
    DISHWASHER MODEL # KUDS03FTBL2 WORKED VERY WELL UNTIL TWO TO THREE DAYS AGO DISHWASHER NOW LEAVES MASSIVE FILM AND DEBRIS (LOOKS LIKE FINELY GROUND UP GRAVEL AND DIRT) OTHER DISHES AND SILVERWARE HEAVILY...
    There is a product out called the dishwasher filtration system. it filters the water going into your dishwasher reducing the hrad minerals that leave that white residue. it is very affordable and works amazing. it goes right under the sink and is easy to install. go to www.dishwasherfilter.com for more info on it.
    May 01, 2009 | Dishwashers
    Water not draining out after wash cycle
    frigidaire dishwasher model#MDR251RER0/serial#TH84453602 not completely draining. I hear when it the drain cycle begins but does not empty completely out.
    Jan 05, 2008 | Frigidaire 24 in. GLD2150RCC Built-in...
    Dishwashers Logo
    321 people viewed this question
    Top Whirlpool Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
