Question about Cell Phones
I have a ademco 50P panel and a voice module. Previously I could arm and disarm system from any telephone. I recently canceled my landline, and switched to VOIP phone. I am no longer able to activate my system from my phone anymore. I was told the system is not compatible with VOIP but I see many mentioning it works for them on the internet. I notice the phone line in, is the disconnected line from thee landline, and attempted to replace it with a line from the current voip line into the RJ31x box, no luck. Not sure what else to try. I miss the feature.
SOURCE: setting up voip on nec ipk2 phone systems?
The easiest way is to set up a different extn number range for the sites, then in the system settings in the number scheme you programme the system with the ip address of the distant end against the extensions. Obviously you need a VPN between sites but it works really well as we have a number of installations like this
regards
Posted on Feb 27, 2008
  • 264 Answers
SOURCE: speedstream 6520 enabling voip connection to yahoo voice
You should log on to the GUI mode of the Router. There you should find the settings for the VOIP.
Also check this link and you should get the infor specific to the Yahoo VOIP
http://voice.yahoo.com/
Posted on Apr 29, 2008
ted1430
  • 339 Answers
SOURCE: 3 vlans, data,1; data 2,;voip,5. Ports carry voice
Here's what you need to do:
First, be sure to assign an ip address(in the proper subnet) to each VLAN.
Second, use the ip helper-address command in the context of each VLAN, the address used should be the address of the DHCP server
Third, Add a scope for each additional VLAN on the DHCP server.
The switch will route the DHCP request to the proper server based on the ip helper-address command parameter and based on the ip address of the VLAN that is passed tot he server, a DHCP address in the proper subnet is automatically configured.
Here is a sample:
ProCurve Switch 3500yl-24G-PWR# configure
ProCurve Switch 3500yl-24G-PWR(config)# vlan 33
ProCurve Switch 3500yl-24G-PWR (vlan-33)#ip address 192.168.33.254/24
ProCurve Switch 3500yl-24G-PWR (vlan-33)# ip helper-address 10.1.2.250
Posted on Aug 08, 2009
greg411
  • 45 Answers
SOURCE: how do I program the line redirection feature
If you switched phone companies and the feature stopped working you probably had Call Forward Busy/No Answer from AT&T. If you use the call forwarding in the phone it will use two phone lines for the entire length of the call. Call Comcast and have them add Call Forward Busy/No Answer and tell them the number you would like your calls forwarded to and the ring cycle (the number of rings on no answer).
Posted on Apr 19, 2010
SOURCE: Message Waiting Indicator (MWI) light stays on since VoIP
I have a fairly new Panasonic that can't seem to turn off the MWI indicator. My older Panasonic works fine. uVerse technical support says the newer Panasonic is incompatable with uVerse. They all worked fine on my former analog ATT line
Posted on Apr 30, 2010
I have a Ademco 6150 keypad and Ademco Vista 20 SE. I do not have the access code, installer code or master codes. When I power up the system I get a d1 and it says "armed". How do I set new codes?
Within 30 seconds of power up press *and # simultaneously. Display should say 20, if you press *20 1234 then *99 to exit programming. Your system should be disarmed and your install code should now be 1234. You can then use this code to change the master code.
Dec 06, 2017 | Ademco Home Security
My 5828V do not go to sleep after I change the batteries a few days ago. Please help
Is the 5828V connected to an A/C adapter? If so the screen will stay lit - this is normal. If you do not have an A/C adapter - try an arm/away then a disarm and see if that makes it go to sleep. ... and if you don't have an A/C adapter - consider getting one as the keypad will then report on system changes - something you are missing with a battery only powered 5828V.
I know on the Ademco Lynx-Plus keypad / the alarm panel - the display will stay lit after you exit programming mode until you do an arm/away and disarm so it may be the same with your 5828V.
Aug 17, 2014 | Honeywell 5828V - Ademco Wireless Talking...
We replaced defective 5828V which had burned out, though we had 1 year with it without any problems. This is on an Ademco 2100 wireless security system. The first replacement we received would randomly...
See if the 'disarmed ready to arm' status announcement on the 5828V only happens when you walk in front of a motion detector. If so - replace the motion detector with a new one as older motion detectors could cause this to occur on an intermittent basis.
Jul 23, 2011 | Honeywell 5828V - Ademco Wireless Talking...
I had installed a 4286 VIP on my Vista20P control panel.System works perfect on premises phone line. Off premises system takes phone code but will not take sys.code and aborts the call. Gave 2 sec. pause...
I'm not familiar with the 4286 but I have used the VM101 from myvirtualmonitoring.com before. It attaches to the panel and uses your internet connection to transmit alarm signals, send you text and email messages when events happen, and let you arm and disarm the system from a iphone or android. It may be a better solution for you.
http://www.myvirtualmonitoring.com
Mar 08, 2011 | Ademco 4286 Vip Vista Interactive Phone...
NEW SYSTEM w/ 6160keypad... booted up/ pressed 1 & 3 before 50 seconds/ entered 16 & */ is now showing... ****DISARMED**** Ready To Arm i try to hit the code 4112800 & system...
Seems like the installer code was changed. Try 5160+800. If that doesn't work, you may have to have an alarm company check out the system and see if they can reset it for you.
Jan 26, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
Hi. I have the ademco vista 20P panel. I want to be able to get notifications on my smartphone when the alarm is tripped.Is the GSMX what I need do this? I also want to use power from the panel for the...
Check out http://www.myvirtualmonitoring.com. They sell an IP alarm transmitter that will send you notifications for alarm events. The transmitter includes a free iphone and android application that lets you arm and disarm your alarm panel remotely, as well as see an event log. Very good price, better than the price of a GSMX, and more features.
Jan 05, 2011 | Ademco GSMX Digital Cellular Communicator...
I recently had a home security system installed including two Ademco 5804 wireless remotes. The installer did not give us a users manual and ewe are having trouble using the remote to arm the system.
A common problem that I see with customers and these remotes is that they dont hold the buttons down long enough. It should not be like a tap, more like a press and hold for about 2sec. GL
Dec 18, 2010 | 5804 Wireless Key
Dont know the reset code or anything about home security alarm sy
need to know brand name of system. IE Ademco, bosch, DS, it will be on the inside of the alarm panel.
Apr 23, 2009 | Electrical Supplies
Replaced the alternator, now anti theft won't disable
The ignition lock anti-theft switch (19A438) detects if the ignition key cylinder is broken or "slam pulled" during a theft. The ignition lock anti-theft switch is always monitored by the remote anti-theft personality (RAP) module. This allows the alarm system to be triggered in the case that the ignition lock anti-theft switch detects tampering of the ignition key cylinder (even in the event that the alarm is not active at the time).
Refer to the Section 501-14B for more details on the keyless entry remote transmitter (15K601).
The door open warning lamp switch (14018) communicates to the RAP module through the generic electronic module (GEM). This input to the RAP will cause the anti-theft alarm to be sounded if the anti-theft alarm was armed.
The door disarm switches are assembled into both LH and RH lock sets. The door disarm switch must be triggered before the mechanical lock unlocks. This is to prevent the anti-theft alarm from activating when it should have been disarmed.
The RAP module controls the anti-theft system and is the brains of the keyless entry system. The RAP module communicates with the GEM to request that the interior lights be turned ON/OFF with use of the keyless entry remote transmitter, and the GEM communicates to the RAP to inform when the door is opened. Refer to Section 418-00 for inter-module communication.
The RAP module has three wire connectors attached to it:
  • The antenna for the keyless entry remote transmitter.
  • 26 circuit connector (C256).
  • 22 circuit connector (C257).
In addition to the perimeter alarm that uses the door open warning lamp switch, the RAP module also uses the ignition lock anti-theft switch and the autolock/relock feature to prevent theft of the vehicle. For a full description of the autolock/relock system, refer to Section 501-14B .
The THEFT LED is found on the instrument panel between the tachometer scale and the needle pivot point. The LED is illuminated during prearming and flashes when armed or triggered.
Prearming and Arming the System
The system can be armed if:
  • The ignition is OFF.
  • The PANIC alarm is OFF.
  • All doors are closed.
There are two ways to prearm the system:
  • Press the LOCK button on the transmitter.
  • Open a door, press the power door lock button and close the door.
After 30 seconds the system will be armed and the theft indicator in the cluster will flash every two seconds.
Disarming an Untriggered System
An armed system will be disarmed with one of these valid actions:
  1. Pressing the UNLOCK button on the transmitter.
  1. Placing a key in the door and turning to UNLOCK.
  1. Turning the key to RUN or ACC.
The anti-theft alarm can be triggered by the following conditions:
  • The ignition cylinder is damaged with or without the RAP being armed.
  • A door is opened without disarming the armed RAP module.
The remote transmitter can activate a panic alarm which is similar to an anti-theft alarm, but does not deactivate the starter or cause the theft indicator to flash.
Disarming a Triggered System
If the system has been triggered, (the horn honks, the lights flash, and an external starter interrupt relay is engaged), the system can be disarmed by:
  1. Pressing the UNLOCK or PANIC button on the transmitter.
  1. Putting a key in the door and unlocking the door.
  1. Turning the ignition to RUN/ACC (Turning the key to RUN/ACC will not disarm an alarm that has been triggered by the ignition lock anti-theft switch.).
Apr 10, 2009 | 1997 Ford F150 Regular Cab
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Mar 02, 2009 | 1998 Ford Windstar
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
