Question about Craftsman Tools & Hardware - Others
It was working fine.Turned it off.The next time I went to use it,it would'nt start. Not a noise, nothing.I checked the brushes and the wiring. Only thing Ican think of is the switch.
    Sergeant:
  • 259 Answers
Check the switch with a ome meter.
Posted on Mar 20, 2011
Kitchenaid professional hd mixer does not turn on
Check that the motor brushes are not worn out. Under the black screw caps one each side of the motor. Note that the brushes have one corner shaved off, they only fit properly one way.
Remove the back cover (one screw at the top) and check for a broken or fallen off wire. If that doesn't solve it then you are going to need a multi meter and start testing for a break in the circuit.
Nov 18, 2017 | KitchenAid Food Mixers
Intermittent starter issues. On my boat it very hard to access the starter and solenoid. When my boat starts it runs perfect. I can start and run it and shut it off numerous times. Now twice it has refused...
replace the solenoid,but,if you are worried about being stranded,while you are there,replace the starter and on all connections,use electrical grease,to keep corrosion away,always use lock washers so nothing gets loose too.
Jul 20, 2015 | Cars & Trucks
No longer turns on
check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Mar 25, 2014 | Waring JEX 328 Health Juicer
Suzuki wagon r+gl check engine light keeps flashing and wont start after battery change
the engine (there are more than one engine)
has a distributor.
"have spark at coil down to dizzy but no spark at plugs"
this can mean only 2 things.
1: spark wires are dead. all 4, kinda hard to believe huh?
2: the dizzy is way off time. so time the dizzy and now spark
lands on each wire term.
if not a dizzy engine, post exact version of engine and country.
Apr 14, 2013 | Suzuki SX4 Cars & Trucks
My 2006 chevy trailblazer 2wd 6cyl wont start. makes clicking noise, then nothing lights/radio etc work but wont start what is it
You got a jump and it ran fine? It's your battery. The lights and radio are much easier for a battery to handle than spinning a car engine. Again, if all you needed was a jump, you have a bad battery.
Jan 20, 2018 | 2006 Chevrolet Trailblazer
Im working on a 2005 Kia Optima 2.7L I did a timing belt i had to take the heads off and have them done it's a interfernce motor and bent valve's, after i get it all back together i go to start it ...
probably no circuit for the crank sensor from wires not connected or the cam position sensors not connected
possible that the immobilizer is activated from a disconnected battery
do a compression test because if you fitted the heads then turned the camshafts over to get the valve timing before backing the valve adjustment right off you will again have bent valves
Oct 21, 2017 | Cars & Trucks
Model-- Melodie airpool ll & hydromax [utsn] The pump was working ok during the last use, it did make a bit of a strange sound for a second but worked fine untill shut off. The next time we went to...
Well it sounds like you tried resetting the system and that failed you the next thing to do is test the air pump and make sure its working. I would try cutting power to it and then turning it back on but I am sure that will not work, now this noise you heard or strange sound is the pump. Now i would start at the pump, check any fuses on the unit if any and at the last resort local repair.
The error code you got did not make sense to me on where the true problem with the power lies. But I would check the pump you be happy you did. You might have something that got jammed in it, this could be anything with the pump at this moment. But for my efforts tonight in trying to locate you root problem please do click the accept button. You can also follow up with me as well.
Thanks for using fixya.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Feb 16, 2010 | Maax Melodie Hydromax Whirlpool -...
1998 ford tuarus se won't start
needs a starter- or cable- if you had to tap on it for it to work its junk-
May 27, 2009 | 1998 Ford Taurus
2005 Jeep Grand Cherookee sometimes won't start
This could be something simple. Your starter draws far more power than anything except for the a/c clutch (not in play here) Since all accessories are functioning, it's likely that the battery terminals are oxidized. A high-draw item will actually break the connection temporarily. This condition will also change with humidity and temperature. Remove them and use a small wire brush or sandpaper to clean the battery posts and the inside of the connectors on the wires themselves. If you have done this and still have a problem, then you should start looking for other larger problems.
Good luck
Jan 08, 2009 | 2005 Jeep Grand Cherokee
Tools & Hardware - Others Logo
182 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Mike
John Trevino
Jay Finke
Jay Finke
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
