Question about Vivitar ViviCam V15 Digital Camera
Need to learn how to set my camera up having a little trouble
  • Marvin
    Marvin Mar 20, 2011
    Please explain your dilemma
    Novelist:
  • 137 Answers
Here's the User Manual, Spec-sheet, and Warranty Downloads (in that order) scroll to bottom of page.
Vivitar v15 User Manual
Posted on Mar 20, 2011
Chevy express 1999 didn't start, i have a code p1336. i've change the crank shaft sensor but it didn't strat and i have a P1336 code again
Trouble Code: P1336
CKP Sensor System Variation Not Learned
Possible Causes:
Set the parking brake and block the drive wheels for safety. Verify the hood is closed. Read the trouble codes. If a code is set, refer to that code. Start the engine. Allow engine temperature to reach at least 158?F (70?C). Then key off. Select Crankshaft Position Variation Learn procedure on Scan Tool & start the vehicle. Apply the brake pedal firmly and verify the selector is in Park. Increase accelerator pedal position until fuel cutoff is reached at the test rpm (e.g., 5150). Quickly release the accelerator pedal after fuel cutoff is reached. The CKP system variation compensating values are learned when the engine speed (rpm) decreases back to idle speed and the procedure terminates. Read the trouble codes and recheck for DTC P1336. If DTC P1336 runs and passes, the CKP system variation "learn" procedure is complete. If not, look for other codes. If no codes are set, repeat the test procedure.
Jul 24, 2012 | Chevrolet Express Cars & Trucks
My camera over exposes everything - the shutter stays open for about 2-3 seconds. except when on video settings. No matter what I set it at nothing changes.
Looking down at the top of the camera, check the left knob. This is the exposure compensation dial. Adjust it to "0". If set one way or the other, it will make pictures darker or lighter. This comes in handy when the image has a lot of dark or bright areas - moving this dial will allow you to make the bright areas darker or the dark areas lighter when you camera's light meter is setting the exposure in a way you do not want.
If still having trouble, make sure the right knob (Mode) is not set to M or Manual. Switch it to Program or Auto and try taking a picture again. You might even want to set the outer knob (ISO) to AUTO as well to reduce the chances of an incorrect setting. If it now works as expected, but you want to shoot in M, you will need to learn how to use the meter to select the correct combination of aperture (f stop), shutter speed and ISO to obtain the desired results.
Oh, experiment with the exposure compensation knob when you have a chance, learn how it can help correct overly dark / bright scenes. Good luck!
Feb 14, 2012 | Canon PowerShot G10 Digital Camera
I need to change the menu language to English, as it turned to Chinese by mistake. Please help me. Thanks, El-sayed
Hello, That's the same camera I have! I can help you. Follow this sequence to reset all the settings so that the language becomes English:
  1. Turn cam on
  2. Press the "menu" button.
  3. Press right directional key (marked with the flash symbol)
  4. Press down directional key to go to the bottommost entry of the menu (which is the reset all option)
  5. Press the "set" key (in the middle of the directional keys)
  6. Press the up directional key and then "set" to confirm.
There. you're done. Now you don't have to learn Chinese to use your cam!
EXTRA NOTE: BTW just in case this applies to you too; When I first got my cam, I had trouble finding the timer option to time the shutter (1-2-3 click!) It's called "drive mode" in this camera.
May 07, 2011 | BenQ DC C1030 Eco Digital Camera
Understanding manual settings canon EOS450D
Have you read the owner's manual? The beauty of digital cameras is that you can try different things at no cost until you learn the procedure you need to learn. Experiment....have fun!
Jan 21, 2011 | Cameras
A little help if you would be so kind? I have just aguiered a Pentax ME super and am having a little bit of trouble understanding the light meter. The worse thing is I also have the manual, which you'd...
Hi Nathan,
Let's start shooting without film, first.
Example: shooting outside on a bright day, let says between 10:00 to 14:00 with some clouds.
Set camera ASA/ISO to 100
Set lens to the highest number, that's the largest F Stop number.
Set camera to P, which is program. Camera will select aperature and shutter for you.
All you need is the focus and look at those LED lights, to make sure it won't lit & flashing up at the top as well as on the bottom.
If you are viewing a image that is bight without clouds, then the Shutter should be 125 and the Aperature 16. If in the shade, it will be Aperaure 11.
Start with that first.
atdlee@netzero.com
Nov 21, 2008 | Pentax Cameras
Focus problem?
Hi
Yes, there is a 'macro mode' setting which is what you need to use to take closeup photos.
Put the mode dial on Auto in camera mode, and then press the 'macro' button, its the one with the little flower icon. The macro icon appears on your screen and you can now take closeup photos.
Have fun, darntoothysam com
Thomas
Sep 30, 2008 | Fuji FinePix S5000 Digital Camera
Nikon D80 display panel F--
The lens ought to be fully functional in every mode. But if you are in a pinch then Manual it is 'til you can get it sorted or serviced if need be...in which case you'll need to swithch the AF Mode lever (under lens release button )from 'AF' to 'M'. Have you cleaned the lens' electrical contacts? Examine but probably little need to clean the camera's electric contacts considering its' young age. Do you have access to another AF body on which you can test the lens and another AF lens to test the D80?
Please keep in mind that if the aperture is not set (locked) at its minimum, the error is a flashing fEE. When the body cannot communicate with the CPU in the lens, the error is F--, which means either the lens has no CPU or a bad electronic contact.
Aug 08, 2008 | Nikon D80 Digital Camera with 18-135mm...
Dark picture taking on stage
You need to run it with aperture priority, and have the aperture as wide open as possible (The lower the number the better). You've got the kit lens, which is a notoriously poor performer in low light conditions, you should consider getting one of the Sigma DG lenses.
The other alternative is to get as close up to the stage as possible, and use the smaller lens that would have come with the camera kit. It's a little faster.
Mar 20, 2008 | Cameras
Frustrated with learning the Canon rebel xti
I can tell you that the XTi is a very advanced DSLR camera and can't be learned overnight. I've been shooting EOS cameras since 1986 and it still took me about 2 weeks to master it. The manual that came with it is very informative and should provide a basic understanding of its functions. I'd recommend doing a Google search for free photo tips and training. I've got numerous links that I refer to from time to time when I need a refresher.
Dec 05, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
Blurred pictures Samsung L77
try placing the camera on a stable surface, ie a table and taking a picture
try also cleaning the lens with a soft cloth
hope this helps
Nov 18, 2007 | Kodak EasyShare C643 Digital Camera
Vivitar ViviCam V15 Digital Camera Logo
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
