Question about Yamaha PSR260AD 61-Note Touch-Sensitive Portable Electronic Keyboard with AC Adapter
I have a yamaha psr 160 with no sound - Yamaha PSR260AD 61-Note Touch-Sensitive Portable Electronic Keyboard with AC Adapter
SOURCE: i need for :yamaha keeboard psr 9000 :danish manual
hej I asked my lokal store. thank ouy for answer. best regards poulc
Posted on Jun 27, 2009
  • 979 Answers
SOURCE: Yamaha psr-240 lights up but no sound.. no sound
try placing your ear on the speakers, adjust the volume control up and down several times, you should hear a humming sound that goes up and down. if not problem with the stage before the amplifier, that is the sound processor. if you dont hear the hum. problem with the amplifier and speakers, including the sound ports or jack. dissassemble the unit. look for loose connections from speakers to amplifier.
Posted on Jul 14, 2009
  • 1138 Answers
SOURCE: yamaha Psr-340
I don't have Cubase myself but there must be a track setting that allows you to monitor what you are playing live. Also make sure your keyboard shows up as the midi controller on the software. Your receive channel has to match the send channel of the keyboard. Make sure that synthA or synthB shows up as the sound source (audio out). XFi Midiport is your midi in but since Cubase already sees your keyboard your problem is an audio one not a midi one. Hope this helps.
Posted on Jul 24, 2009
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Posted on Feb 14, 2010
SOURCE: yamaha psr s900 screen/display gone bad
MR SATISH IF YOU WANT TO SOLVE THIS PROBLEM CONTACT:9887070565,94136768(ANAND NARWAL)FROM RAJPUTANA ENTERPRISES
Posted on Aug 07, 2010
Does it have an internal battery?
HQRP AC Adapter / Power Supply for Yamaha PSR ... - Fixya
www.fixya.com/search/...hqrp_ac_adapter_power_supply_yamaha.../60...
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, 600 related issues. ... is there an internal battery to protect memory and if so, do i need to replace it? yes there ...HQRP AC Adapter / Power Supply for Yamaha DGX-620 / DGX620 / DGX- ...
www.fixya.com/...hqrp_ac_adapter_power_supply_yamaha_psr/adapter
HQRP AC Adapter / Power Supply for Yamaha PSR-280 / PSR280 / PSR-290 / PSR290 Keyboards Replacement plus HQRP Coaster, adapter related ... need a new one, you could try to get a replacement from casio or try to get an ... It MAY appear to operate on DC BUT it can't generate the +/- voltages internally for sound .
Musical Instruments - Keyboard Accessories on Pinterest ...
https://www.pinterest.com/.../musical-instruments-keyboard-accessories/
HQRP AC Adapter / Power Supply compatible with Fulltone CATALYST / CHORALFLANGE Guitar Effects pedals Replacement plus HQRP Coaster by HQRP. $7.91. ... The MS-90 is a column monitor stand that features three internal channels - .... Yamaha SK88 Survival Kit for 88-Key YPG Series Keyboards by Yamaha.
Dec 25, 2015 | HQRP AC Adapter / Power Supply for Yamaha...
What's your problem?how can i connect my mic in YAMAHA PSR s710
I believe you must have a USB audio mic. If you do, plug it into the USB port in the back of the unit;
Aug 07, 2012 | Yamaha Music
Repairing Yamaha psr-12
If the power adapter is not the original adappter- check to make sure the polarity is correct- it should be marked on the keyboard near the adapter socket, and also on the adapter itself.
The keyboard should have an internal fuse- check that. Then with keyboard open, if the fuse is okay, trace the power flow from the power pack and look for broken wires, bad solder connections, stressed components like bulging capacitors, etc. It may have a burned out zener diode in the power supply regulator portion of the main circuit.
Mar 29, 2012 | Yamaha PSR-E223 keyboard
Yamaha PSR 740 Volume knob crackles when turned and the sound cuts out when played at higher volume
There is dust in the sliding mechanism, which can be cleaned with a good electronic cleaner, which does not evaporate when drying. If that does not work, replace the volume potentiometer, the `part behind the knob.
Dec 05, 2011 | Yamaha Music
I'VE A YAMAHA PSR S700. The problem is with it's screen. Whenever i start playing, the screen fades and then it comes and it goes and vice versa. This occurs almost two - three days a week. There...
Likely a connection to the backlight is being broken. Tap on the unoit and see if it pops back on. Illuminate screen with a flashlight and see if the characters can be seen when screen is faded. If they can, then the backlight is the problem... IF NOT then the display may be bad... This has been a problem and if you are under warranty, excersise it immediately... else replacement of the display is relatively expensive.
May 28, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
Yamaha psr-280 flashing display no key response or sound. Is it dead??
Your adapter should be a 12 volt DC delivering 2 amps (2000 ma). If the adapter is too small, you will have the symptoms you are seeing. Make sure the polarity is correct. DO NOT use the so called "universal adapters".
Apr 13, 2011 | HQRP AC Adapter / Power Supply for Yamaha...
The keys are broken and some at no sound can I order the notes and sound kit. Yamaha PSR-295 . Regards Elias
Hi, i think you can. You can go to any of the Yamaha companies around you area and explain to them the problem of the keyboard. They will give you good and quality replacement part for your Keyboard.
Make sure you go to only Yamaha company to avoid getting a wrong part for your Keyboard.Avoid road siderepairsforissue like this,it's more complicated to handle
I guess that will do.
Thanks for using fixya...
Jan 12, 2011 | Yamaha PSR-295MS Portable 61-Key...
Feb 12, 2010 | Yamaha Full-Size Keyboard
Psr-60 serial no 008012
Yamaha PSR 60. Power light comes on but no sound from any of the keys or anything else. Can anyone advise
Jul 28, 2009 | Yamaha Portable Keyboard
Yamaha PSR260AD 61-Note Touch-Sensitive Portable Electronic Keyboard with AC Adapter Logo
153 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
