Question about Refrigerators
There is a lot of ice in the freezer . I don't know how to remove it ? please help me.
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 20, 2011
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine. After pressing the ice maker reset button, I hear a ding don sound coming from the control...
It won't harvest ice on its own unless it detects a temperature of 10 degrees. The ding ding sound is the control letting you know that the ice maker is functioning fine. Remove the evaporator cover in the freezer and make sure the coil isn't frozen over and the fan isn't restricted from turning. Check the door gasket is getting a good seal. If that's all good replace the sensor on the ceiling of the freezer.
Aug 31, 2016 | Samsung Refrigerators
E442B Fridge is not cold & some ice build up in fridge. How do you remove the back of inside of freezer to check ice build up there?
don't mess about with it just remove items and get a new one sound like its leaked it's gas (BUT DON'T PANIC) its not harmful and its not going to blow up! you could call a engineer but a lot of the time your just as good putting that money towards a new one
your friendly domestic appliance engineer chris
Dec 05, 2011 | Refrigerators
The refrigerator part doesn't get cold and we have frost in the freezer
I wrote this little guide for another fridge question. But I believe it may help you as well. You may have several of these things going wrong. Hopefully you don't have to actually replace anything but the heating element. Check it out and let me know if it helps!
If the case is cracked or there is a leaking door seal this will allow moist air from outside the unit to come in and release its moisture. Cracks are easy to see. You can also inspect the seals fairly easily.
IF YOU TRY ANY OF THIS PLEASE UNPLUG YOUR UNIT AND TURN THE WATER SUPPLY OFF FIRST. thank you.
Freezers/fridges remove moisture from the air inside them while they work. At least in my unit the fridge and freezer compartments are connected by a couple little trap doors. One near the top works automatically. I assume it regulates the temp of the fridge part by using freezer air. The other is vented into the meat drawer at the bottom.
Moisture flows to the coldest part of the inside, much like humid air settles droplets on the outside of a cold glass in the summer. The coldest part is the coil assembly which would be behind a panel at the back of most freezers. Below this assembly and hopefully not covered by a panel is a drain hole. It needs to be clear for things to work properly. See if you can find it in the back bottom of the freezer.
If there is ice plugging it you need to clear it. Don't pick at it because the inside of a freezer doesn't like scratches and scrapes. Those create opportunities for rust if the unit lasts long enough. Put a few towels in the bottom of the freezer to catch overflow. Then pour the hottest tap water you can get slowly over the ice. Once it is clear the drain lets the water go into a pan underneath the unit and eventually evaporates. You will hear it when it clears.
Under normal operations this drain collects the water that freezes all over the cooling coils in the very back of the freezer. It is normally very little water. If it is blocked by ice this can point to a slightly bigger problem. You may want to see if you can remove the back panel of the freezer and check the coils for ice. This can a)take a while and b)have you removing a lot of assemblies just to get to one panel screw. So be prepared and don't start it when you have a freezer full of food. If you attempt it and find white fluffy looking ice all over your coils you will need to look below this stuff for an assembly that houses a heater. Mine looked like a long thin tube bulb, much like a halogen lamp. It's called the heater element and replacing it may just fix your problem. I got mine for about $50.
You might also want to make sure your fan and radiator assembly are clean. Inspect the air venting grill on the back. If that is gunked up or you can see that the radiator inside is gunked up, you should carefully remove the panel and vacuum as much as you can. This was a major problem for me because at one time because of indoor pets. If checked regularly it doesn't become an issue.
Anyhow, this is a lot of info, but I had to learn all this the hard way. Hopefully it will save you and others a headache.
Nov 19, 2011 | Kenmore Top Freezer Refrigerator
Kenmore refrigerator(model 10653606202) freezer is cooling, can hear the circulation fan' noise, also see defrosted water in the bottom collection pan. but the refrege is not cooling.
If the freezers is freezing everything and you can hear the circulation fan, maybe it is a defrost problem. Sometime ice will build up behind the rear panel in the freezer section that blocks either the chilling tubes to the refrigerator section.
You will need to remove the food from the freezer, then remove the shelves and inside back panel of the freezer. If you see a lot of ice, that is probably your problem. DON'T use water to defrost, either unplug and let it set with the door open or hurry it up with a hair dryer.
It also means your defrost assembly has stopped working and will need replaced, but the unit will work without it for several weeks before the ice build up redevelops.
Jun 07, 2011 | Refrigerators
Deepfreeze not working after defrosting
I think the problem happened during defrosting. i will tell the important steps that should be done while defrosting. Check whether you done the same steps or not.. If you done the wrong steps kindly contact the Shop where you buyed and tell them to replace with your guaranty(if available).
Here are the steps. Shut off the power to or unplug your freezer. It can't defrost if it's still running. Find the drain hole near the bottom of the freezer and put a plate or towel underneath it to prevent water from getting on the floor. Open the freezer door and remove all the food. Remove any baskets or other removable items from the freezer as well.Take the spatula and scrape away as much ice as you can from the walls of the freezer. This is cold work; I recommend gloves if you have any. After you scrape away as much as you can, use the dust pan and bowl and take out as much of the ice that has accumulated on the bottom of the freezer as possible. Replace the baskets or shelves in the freezer and shut the door. Turn the freezer back on. Put the food back in the freezer in an orderly manner where things can be found when you want them. Put items you hope to use soon in the freezer above your fridge or in a place inside your deep freeze where they will not be forgotten and used soon.Remove all of the excess water from the bottom of the freezer. You may use a kitchen towel for that; squeeze it into the bowl so you don't get water all over the floor. The water will be extremely cold. Once all of the water is gone, wipe down all interior surfaces of the freezer with paper towels. You don't need to use spray cleaner in the freezer unless there is some type of mess that was caused by food spilling.
  • Fill up the large container with warm water. Pour it along areas that still have a lot of ice buildup. Let it sit for a minute or two. Then take the spatula and scrape off any loose ice. The ice is likely to come off in big sheets Once again, remove the ice and water from the bottom of the freezer. Repeat this process until all of the ice is removed from the sides of the freezer.
  • If you liked my solutions, kindly do rate me ..
    Thanks..
    May 20, 2011 | Refrigerators
    My freezer started getting a lot of frost and ice around the top close to the henges. Now I am getting a lot of ice in the bottom of this freezer. I can break up the ice and remove it and it will be back...
    there are only 2 reasons this happens but one cause (defrost element not working) 1st we check the defrost timer is working if not replace it if it is working go on to the last fault it can be - depending on the freezer it will have 1 or 2 defrost elements when one blows the ice will slowly build up if they both blow then the ice will build up within days unless you know your way around a multimeter it will be very hard to determin witch unit has blown in 70% of cases its the element but a service tech can tell you in a matter of minutes to save you time and money i would get a quote to get a tech in but now you know what to look for
    best of luck to you
    please remember to rate this repair .thank you
    Aug 03, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
    Ice build up on freezer floor.
    Hi, If ice is building in the freezer, you have a defrost drain hole plugged. Unplug the Fridge and then remove the rear panel off the freezer. There you will find ice built up in rain. Remove the ice (hair dryer works best). Once the ice is gone, you need to make sure the drain hole is open all the way. A baisting serringe with hot water works really well.
    I hope this helps. Please let me know if I can assist you further. Please rate my answer so I know how I am doing.
    Thanks
    Vic
    May 22, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
    Hoshizaki F-800 MAH
    check their web site. can get lots of info. their tech support line is worth the wait. 1800-233-1940
    Sep 06, 2008 | Hoshizaki Freezer Commercial Ice Machines...
    Gss25jfmc side by side
    it is not defrosting as it should.
    • possible causes:
    1. bad defrost timer/control board
    2. bad defrost heater (in freezer)
    3. bad thermo switch in freezer
    If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
    Aug 11, 2008 | GE GSS20IEM Side by Side Refrigerator
    Refrigerators Logo
    32 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
