Question about Microwave Ovens
My koro espresso machine says es out of use. How do I fix it and what does it mean?
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Jun 29, 2011 | Microwave Ovens
We have a 12 cup Mr. Coffee about a year old. We put 4 scoops of coffee in and the appropriate amount of water. Every day, the filter overflows and grains of coffee get into the pot. How do we keep this...
Because I own a espresso company,I believe I can help you. There is several things that can cause a coffee machine to over flow. 1, putting to much coffee in, where water can not drain through filter. 2. The grind of the coffee, if it is ground to fine, like ground for espresso, will not allow coffee to flow through filter , drip machine that are not under high pressure like espresso machines have to have ground more course. 3, wrong type of filters, not fine enough for water to flow, or made for high pump pressure machine such as espresso machine . 4, putting to much water in, is not an issue on a mr coffee, because even if you fill it to full cup line, it would have nothing to do with filter over flowing, besides the coffee grounds always absorb some of the water anyway. In conclusion, my positive professional diagnose is Grounds of coffee to course, and 4 scoops seem a bit to much for a filter of a mr coffee machine that holds only 12 cups. To test this is make a pot same way and use only two rounded scoops and see what happens, if does not over flow that solves that. But your saying I want it stronger, believe me I know. I too like my coffee strong and a flavorful . I have that solved too. Go to a good walk in espresso shop, like a star bucks, tell them you want some good strong blend and have it ( Ground for Drip) and then still only put two rounded scoops, it takes less do to the blend and kind of coffee. Please let me know if my advice worked, thanks mike. oh notice my screen name of mc1 bean, now you know, I know what I am talking about :)
Jun 07, 2011 | Microwave Ovens
Hi I have a Lavazza Modo Mio Type SIN 029. I find that after I have primed the machine and followed all of the instractuion that my espresso is cold to luck warm. If left for 10 seconds it would be...
Pod machines never make boiling hot coffee but this sounds like the heating unit isn't working. I am not aware of anyone that repairs this sort of thing other than the actual manufacturer. If it is new take it back to where you bought it. If not, it might be cheaper and easier just to buy a new one.
Jan 16, 2018 | Microwave Ovens
What does it mean to descale my tassimo? the yellow light is on and the screen keeps saying "descale". thanks
In order to keep your Tassimo machine operational at full order, it is important to descale it every three months. Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Tassimo machine is intended for this specific use only. Mix the descaling product directly in the water container, following the instructions provided on the descaling packaging. Then replace the water container on the machine. Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down and close the brew mechanism. As soon as the AUTO light illuminates, press and release the start/stop button. This will fill the brew cycle with descaling solution. Empty the cup and let the machine stand for 15 minutes. Then open the brew mechanism and close it again, leaving the cleaning disc in place. Repeat this step two more times for maximum descaling effectiveness.
Discard the remaining descaling agent from the water container, rinse it well and refill with fresh, cold water. Clean the machine by flushing water through it in the same manner and emptying the cup as it fills. Make sure that all the descaling solution has been completely rinsed away, and then flush two full water containers through the machine before using it again. Remove the cleaning disc, rinse and refill the water container and your Tassimo machine is ready to use. Also, before you descale your Tassimo machine, always unplug it. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Tassimo machine. This method works for most espresso machines, including some of these popular models: the DeLonghi Magnifica EAM3200S, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5400, Gaggia 74507BCN Classic, Krups EA8080 Espresseria Automatic, DeLonghi PrimaDonna ESAM6600, the BC0255 DeLonghi coffee machine and the Krups Nespresso CititZ XN 7006.
May 16, 2011 | Microwave Ovens
I am looking for replacement bulb that is found under the microwave 125 volt 25 watt appliance bulb and can't find them anywhere
Most appliance repair workshops will have this type of bulb. Check the base, is it ES, Small ES, Little ES or a manufacturers special.
Contacting the manufacturer will guarantee a spare part.
Hope this helps.
Jan 02, 2011 | Microwave Ovens
Saeco Royal Professional Espresso Machine Problem IT KEEPS GIVING ME ENERGY SAVING. WHAT DOSE THAT MEAN? I HAVE FORGOT T TURNED ON THESE MORNING. THANKS
There is a main switch on the lower left side, as well as a standby switch on the front. Make sure the main switch is on, and the press the power button on the front. It will warm up & be ready to make a cup of coffee (about 30 sec.) when you select one of the coffee (cup) buttons.
Dec 15, 2010 | Microwave Ovens
The metal sleeve that fits over the frothing arm on our Breville Espresso machine, went down the disposal and got damaged. I can't find a replacement for it!
Here you go: http://www.ereplacementparts.com/breville-800esxl-diecast-espresso-machine-parts-c-116052_116055_116066.html
It's part number 156. Check it out on the diagrams they provide to verify. I have the same machine and am missing the exact same part, so I know exactly what you are talking about!
Nov 02, 2010 | Microwave Ovens
I would like to buy a breville cappuccino maker but hear the dial at side gets stuck and breaks easily,even when cleaned well after use. Has this been rectified. Doreen
Hi, apparently Brita, that owns Breville, did not fix the problem yet.
I can see that complains keep coming.
The problem is apparently on CM8 and CM9, the more expensive Cappuccino Maker BES200XL
does not have the problem.
One suggestion, Breville are nice budget coffe maker, if you want to spend some mor money on a better product buy a Gaggia or something similar. Italian coffee makers are usually the best for espresso/capuccino. If you want a Breville buy the ESP8XL Espresso Machine.
Here is another good brand.
Sep 13, 2008 | Microwave Ovens
Microwave Ovens Logo
328 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
