Question about Eljer Whirlpool In-Line Heater- 494-1550-00
On installation where doest the grond wire go
  • 43,501 Answers
Attach it to any part of the metal box where the power comes in...or to the ground wire of the power feed..
heatman101
Posted on Mar 20, 2011
Electrical ProbProblem
coils burnt on these at times, also check for grond strap coil grond into cap (is itmissing strap?) check 2 wire harnesses inside dist.
was it running before and is it running now?
Jan 02, 2014 | 1992 Cadillac DeVille
Why sound do come out thru my speakers
bad grond look for black wire from the stareo and re conegt to a beeter grond
Apr 13, 2013 | Denon AVR-987 7.1-Channel Home Theater...
Windsheild wipers just quit working
check your fuses that are in your paneling under your steering wheel and double check ur power and grond wires
Dec 17, 2012 | 2003 Cadillac Deville
90 astro, gas gauge goes to full then drops when shifted into gear to near empty
The grond wire near the transmission mount has failed. The crossmember that goes under the rear transmission mount has the wire harness for the fuel pump and the gas gauge on it. This grond bolt is a steet metal bolt screwed into the top of the cross member near the middle of the vrhical on the passenger side. To repair this problem find this bolt and unscrew it, clean the cross menber and the bolt and the wire. ( they might look clean but they need scraped off) to make sure you fix it I attach another peice of wire under this same bolt and run it up to the battery box. following the negitive battery cable it attaches to the body near ther battery with another bolt . clean this connection also and then attach your new wire to your newly attached wire. It's possible to fix it just cleaning these and other ground connections till you find the one thats not making. The japaniese cars always already have these ground wires on all cicuits and don't have these kinds of problems like this american one does.
Jun 10, 2011 | 1990 Chevrolet Astro Extended
There was no grond bus installed
You can buy ground busbar at home center or electric supply and install in main box.
Or go back to seller and swap out for new box that is complete.
Feb 16, 2011 | Siemens Murray 125 Amp Circuit Breaker...
In regard to windshield wiper motors.On the plug that plugs into the motor,there are 4 wires.what ones are grond and positive.
power wire is dark blue. There is no ground wire. Ground is taken from the chassis. See diagram below and let us know if you have more questions.
Dec 22, 2010 | 1991 Dodge Dakota
The check engine light is on. i tried talking with the ECM with a mt 2500 snap-on scanner.the scanner reads no communication. do the haynes manuals have wiring diagrams,and because the ECM;S are under the...
Check the fuses. you will have one for ecm, also check the cigarette lighter fuse. they some times the dlc in with that fuse. it is best to remove the fuse when checking, I have found that they loose contact and removing them fixes problems. Haynes manuals do have electrical for the computers.
Nov 17, 2010 | 1998 Jeep Grand Cherokee
I can't play a dvd all that happens is sound you can hear the dvd but you cant see it
Was this unit recently installed. Has it played before. Be sure that the wire to the parking break is also connected. These dvd players will not play if the brown wire is not connected to the grond side of theparking break. If you need more info, please feel free to ask.
Nov 19, 2009 | Alpine IVA-D106 Car DVD Player
Starter removal 1996 s10
disconnect your batterys grond cable first. Next remove the wiring from the starter. Next you will need to remove the two starter bolts running upoward to the engine. Take note if any shims are there which I doubt. Reverse proceedure to install
May 29, 2009 | 1998 Chevrolet S-10 Pickup
Gfci breaker for spa
gfci's are designed to trip if they receive voltage on there ground/neutral side, therefore my vote is for Smithbrother I would say there is probably a partial short somewhere in you system.
Mar 15, 2009 | Spa Parts Plus GFCI, Circuit Breaker, 30...
Eljer Whirlpool In-Line Heater- 494-1550-00 Logo
139 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
