Question about GE JVM1650 1000 Watts Microwave Oven
The interior lighting has gone out on my microwave.
  • GE Master
  • 9,098 Answers
It all depends on the model number, which you did not mention, so a generic answer is the best we can do.
Some models have customer-accessible covers to allow for replacement of bulbs, some do not. The owner's manual will show you that.
If it's not mentioned in the manual, then you have to remove the outer cover.
If that's the case, on an over the range model, it will have to be removed from the wall first.
You can download GE owner's manuals and installation instructions here.
You can download owner's manuals and installation instructions for several brands (including Amana, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You should be able to download your LG / Goldstar manual here. If not, you can contact them via that page to order one.
You can download Frigidaire owner's manuals and installation instructions here.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.
Posted on Apr 29, 2011
Has stopped working. light gone off at same time. plug fuse has not broke. any ideas ?
There is a fuse inside the microwave also.It is a ceramic fuse,usually 15A.It has to be replaced with another ceramic fuse of the same rating.Bear in mind,the fuse blew for a reason,so if it is the interior fuse replace it after a search for a fault.
Dec 17, 2014 | Microwave Ovens
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Microwave was in use and then shorted out. The breaker did not flip but microwave display went blank and interior light went out. Tested outlet for microwave and it still has power but now microwave is...
There are at least one or too fuses gone, the main fuse located on the main board or behind the control panel, and the thermal fuse located at top on the inner chassis that protects the magnetron, any more than that you are getting into serious money. Remember lethal voltages present when plugged in.
Jun 25, 2012 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Panasonic NNH965BF microwave starts but immediately shuts off
your mag has gone bad and possible that the inverter board as well, not really worth the hassel
Feb 06, 2010 | Panasonic NNH965BF Microwave Oven
Interior Microwave Light does not work
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number 721.63664300 at the Sears parts site.
May 11, 2009 | Kenmore 63662 / 63664 / 63669 Microwave...
American Home shield said that the waveguide is burnt
The reality is that microwave ovens have gone way down in price while repairs have gone way up. Go to a Walmart or a K mart and you will find many microwaves in the 50-90 dollar range. Even if you could have your current microwave repaired it is still ten years old, well beyond it's life expectancy.
Apr 30, 2009 | Frigidaire FMT116E1B Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Interior light gone out
There is usually a little window inside that might remove with screws, or even snap in. That should allow access to the lamp. Check the manufactures website under product support for more info.
Jun 24, 2007 | Neff H7871N2GB Convection / Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
74 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
