Question about Microwave Ovens
What is the sq ft storage - Microwave Ovens
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that will help you to get better results from your question onFixya.
How to ask a question on FixYa
heatman101
Posted on Mar 20, 2011
15x14x9=how many cubic feet?
Square feet is calculated L x W so 10x10 would be 100 sq. feet, Cubic feet is calculated by L x W x H so 15 x 14 x 9 = 1890 cubic feet
Feb 22, 2015 | Microwave Ovens
What is the cu. ft. of a Quasar mqs0963e microwave oven?
About 0.8 cu.ft. - internal dimensions: 8inch x 13inch x 13 inch
Feb 02, 2015 | Microwave Ovens
I need to replace my over the range GE microwave Model # JVM1330WW002 and don't know what size/capacity it is?
Get cubic foot size by multiplying height x width x depth.
Divide that by 1728. If oven is 12 x 12 x 12 then it's exactly 1 cubic ft.
If 6 x 6 x 6 then it's 1/2 cubic ft or. 50 cu ft
Nov 28, 2014 | GE Microwave Ovens
What is the wattage of a goldstar ma- 960m microwave
The Goldstar MA-960M (also 961M and 963M) is 850W, 0.9 Cu.ft. The MA-1080M (1081M and 1083M) is 850W, 1.0 Cu.ft; MA-1280M (1281M and 1283M) is 900W, 1.2 Cu.ft; MA-1523M is 900W, 1.5 Cu.ft. Source: Technical Specifications listed in original user manual for MA-960M.
Jan 31, 2014 | Goldstar MA-960M Microwave Oven
What will the size wire will i need to wire up to consumer unit
It depends on if you are running a 220 or 110 volt supply. Assuming that your supply is 110 volt and your microwave draws about 2000 watts, that would mean that you need a wire with a cross section of about 2.5 sq, mm to allow a safety margin. If your mains are 220 volts you can use 2 sq mm or a little less - say 1.5 sq mm to be on the safe side. (On 220 volts a microwave draws aprox. 2 amps for every 200 wats output and 1 sq mm wire can carry 10 amps - as a rule of thumb. At 110 volts these figures are roughly double).
Feb 13, 2011 | Microwave Ovens
How many watts does Emerson MW8675W Microwave have?
Is the cubic foot size of the microwave on the name plate?? It seems that with Emerson the size relates closely to the wattage .. 0.9 cu ft is 900 watts, 1.1 cu ft is 1000 watts .. 0.7 cu ft is 700watts .. That would be the closest info I can get.
Please vote !!
May 10, 2010 | Emerson MW8675W Microwave Oven
Instruction book in English for Family Chef model FT 338 Purchased in France this week by English family.
It seems there is no English language instruction book for the Wirlpool microwave FT 338. However, the nearest UK equivalent is the FT 337, and the only difference is the lack of the "Crisp" plate.
I suggest you download the FT 337 instruction book in English from the Wirlpool.Uk website, and also the FT 338 insytruction book in French from the same source, which means you only need to translate a few lines of French into English to have the full instructions.
Feb 19, 2010 | Microwave Ovens
Micro is turning on ok and working but not heating up,what would cause that? light is on ok and plate is turning, just not heating
How old is your m wave? Sounds like you need to replace it .You can get a new one from Wal mart for under 75.00.and that will get you the big 1 sq.ft one..I once broke the plate in my m/wave and believe it or not they wanted more for the new plate than I paid for the M/wave BEFORE you do that check your power level settings perhaps it was turned down
Jan 28, 2010 | Sanyo EM-G2585W Microwave Oven
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
12inches
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Jun 03, 2008 | GE JE1540 Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
