Question about Sony Televison & Video
Sony Bravia LCD Digital TV model KDL-32V3100. I have had both digital and analogue channels until last night. Now I cannot get digital channels. I have tried Full Scan, Quick Scan and Manual Scan with no result. I have reset TV but still no digital channels. Help!
3 Suggested Answers
  • 17 Answers
SOURCE: I have a KDL-32v3100 Sony
You don't say how clear the analogue picture is. If it's snowy, or ghosting (double images etc) your signal may be too weak to produce an acceptable result for digital signals to work at all.
If this is not the case you may have a faulty digital tuner. This assuming that the set was working and then stopped.
Posted on Jan 19, 2011
dcramer531
  • 1654 Answers
SOURCE: Bravia KDL 32V2000 .Froze when
There is a tiny component in the digital tuner that may be the cause of your issue. That component is a surface mount fuse. Unless you are very confident with your soldering abilities you need to take your set to your nearest Sony authorised service centre for repair. Sony uses a "board level repair" policy for the digital tuners in their sets so there is no service information available for that part of the TV - meaning that if the service centre you take the set to want to change the whole board then that is because that is Sony's policy and that they are possibly not aware of the root cause of the failure being a 50c part. This fuse is very tiny and not an easy solder if your unexperienced but it can be replaced. There is also the option of using an external HD digital tuner. Not sure how old this set is but they have a hidden extended warranty period of between 1 and 3 months ONTOP of the current warranty for this issue. On the digital Tuner board there is an "F1" and an "F2" (very small fuses) on the circuit board. I don't recomend this but if you would solder across the fuse to complete the circuit you set will again pick up the digital signals but you wont have a fuse. If your hand and can solder a replacement fuse across the board that will fix the issue as well. I use a sat reciever box or you can use the cable box as an external tuner as well. This repair done by Sony will run around $600.00 for the newer digital tuner board.
Posted on Aug 04, 2011
How to use PIP show another channel in TV mode
Dear Ariesky
Your TV does not support this. Normally when SONY refers to PIP, they mean you can display another analogue ( CVBS - RGB ) or Digital ( HDMI ) input simultaneously. They do not mean you can dislay two normal RF channels together, this would require a second tuner, which this set does not have.
Regards
Nov 28, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia KDL-46V2000 LCD television. I was watching a digital program on channel. All of a sudden the screen frooze and I turn to another channel and the screen display no channel allocated. I...
I have the same problem, the only solution I found so far is to disconnect the TV from the mains supply - not very comfortable. The problem seems to happen more and more frequently.
Feb 08, 2011 | Sony KDL-46V2000 46 in. LCD Television
I have a KDL-32v3100 Sony LCD. only analogue channels are found. no digital channels are found. aerial is OK
Jan 19, 2011 | Televison & Video
My Sony Bravia television froze on a digital picture today and now when I change channels there is no picture and no sound. I tried to do a digital scan and it picked up no digital signals,. The analogue...
Your TV has a dual tuner - one for analogue and one for digital although they are contained on the same tuner board. It's possible that the digital tuner has failed, in which case the tuner board will most likely need to be replaced, but often this problem can be resolved with a "hard" reset. Turn the TV off and unplug it. Remove all the cables from the back, leave it for at least 5 minutes and then re-connect only the cable from the tuner source. i.e aerial/antenna. Make sure you are in Digital TV mode (DTV), then run the channel scan again.
If it works turn the TV off, re-connect all of your other devices and you should be able to resume using the TV as normal.
If this doesn't work, you may need to have the digital tuner replaced. The analogue and digital channel feeds are from the same source. As the analogue channels are working there is no obvious fault with the feed or cables.
Please try this first and then post back for further assistance if needed.
Regards,
BElectric
Dec 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have a Sony Bravia KDL-40V3000 but I cannot get any sound on the analogue channels. digital channels are fine. Only cables plugged in are ariel and power Please advise any solutions thanks
(1)Reset your tv from setup menu then auto tune analogu chanel.
(2)if still no sound then update your tv softwear from sony site.
(3)If still sound not then need to replaced main board problem.
Oct 20, 2010 | Sony BRAVIA KDL-40V3000 Television
Hi Digital channels lost and will not hold
this is a fault of your digital tuner on the mainboard on some models they can be replaced alone others you may need to replace the whole board
Apr 23, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Lost digital channels, only getting analogue installed new antenna, no help other sony lcd is working fine
Got to -
Menu -> settings -> set-up menu -. auto start up
Rescan your tv for all channels.
Any more problems, call sony. 08456000124 local rate number
Dec 12, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Can't get digitall channels
I have the same problem, If anyone could help it would be appreciated.... I have the coaxial cable plugged in which on another TV had all 85 channels, and I changed the TV from analog to digital and reprogrammed it but I still only get like 4 or 5 local channels?
Jul 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No Analogue or digital channels!
Hello - I just posted something too. Not sure if its the same problem as yours. If you get a response from elsewhere, please let me know. I'll do the same. In our case we have a blank screen with a bar running across the top of the screen reading 'No signal' on left side and 'C611' on the right side. The 611 might be the last channel we were on !
Mar 07, 2007 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Televison & Video Logo
71 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
