Question about Jenn-Air JGR8855BDS Gas Kitchen Range
We were told today that a Jenn-Air stove can't be converted to LP from NG because it is a pro model with high BTU burners. We were also told that not even a Jenn-Air service tech could do such a thing as conversions happen at the time of manufacture and can't be changed later, we'd have to order a stove specific for LP. Is this true? The model # PRG3010NP Serial # 10002131ER Job # 109777 We've converted other stoves to LP successfully. Thanks for any help! Erin
  • 2,841 Answers
You are being told the truth. They make 2 versions of Model PRG3010. One is Natural Gas and the other is LP. It had to be done at the factory.
Posted on Mar 20, 2011
Control knob doesnt adjust flame height?
Use a manometer to insure lp gas pressure is correct. The regulator for the stove may need adjusting. The air mixture adjustment may not be correct for PL as well.
Aug 18, 2014 | DCS Professional RDU305N 30" Pro-Style...
I am trying to convert a Jenn-air model # PRD3630NP from LP to NG I assume this model is convertable becouse it has a convertable reg on it. Do thay make a kit to do this or is it just a matter of ins
Jenn Air use to make a kit that had the proper orifices for the burners and the valves. The regulator is adjustable for the conversion by simply reversing the main screw. It was intended to be convertible. However, since the model is discontinued, you can no longer purchase the kit (or the backsplash). Apparently Jenn Air believe that when they stop making a product, no one will ever need a part for it again (cough, cough).
Good luck trying to track down a kit. I've tried everywhere in the country and a few shops in Canada. I have a gas appliance expert who thinks he can accomplish the conversion by getting a few of the parts from the LP model and then modifying the rest. The orifices are basically the same, only the LP diameters are different. Theoretically, the ports could be filled and redrilled, but the hardware store was fresh out of 1.07mm bits, so I'll pass on trying this on my own.
If anyone has a LP model they want to convert to natural gas, I'll gladly swap parts.
Jul 25, 2012 | Jenn-Air Kitchen Ranges
Conversion from electric to lp gas
Simple answer NO.
Unless Jenn-air has a conversion kit. (highly doubt this)
It would be a serious undertaking to switch out 2 burners for LP use.
Gas tubes, igniters, electronics, regulator, gas jets.
Not to mention the modifications changes needed to the stove top to make all this work. That gas regulator has to go somewhere and piping from tank/regulator/burners.
Not saying it can't be done mind you.
But think about it long and hard before committing to this job.
Small gas leak can become a huge headache later.
Oct 04, 2009 | Thermador PGR366 Gas Kitchen Range
What are the btu ratings for a jenn air model 720-0100 ng grill. i am converting this to lp gas...
does not matter just change out the orfices on all burners and back burner even if you have a IR buners, the orfices let enough gas in for your grill call jenn air they will sell you the kit to convert it over
Jul 29, 2009 | Jenn-Air Grilling
Convert Kenmore 790 from LP to Natural
The conversion manual that came with my 790 specifies 2.5 turns (approximately) from the LP setting to the NG setting.
Dec 29, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
How to convert from lp to ng
Yes,
I converted a Sam's Club Members Mark grille last year and just did some research on the internet and found a numbered drill size chart that gave me the correct drill size to use on each burner(side,main and rear)for the proper BTU supply for the size or BTU rating for your burner. I drilled them, All has worked well! I know Ducane will tell you not to do that, but I think it is a legal issue. If you have a problem, they don't to get a letter from your lawyer.
May 01, 2008 | Ducane 30400042 (LP)
Conversion
call the dealer and get a converter.
Apr 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Jdr8895aas
This is the solution to convert from LP back to natural gas that I posted as a comment on this thread:
After much work and little help from Jenn-Air or Whirlpool, I found a satisfactory solution. As many of you may have found out, Whirlpool does not sell the natural gas orifices to the JDR8895AAS separately as they do the LP conversion orifices. Instead, they recommend that you buy all 5 orifice holders that include the individual orifices. This would run about $120-150 depending on where you shop. If you want to take this route, the Whirlpool parts you need are:
1x740079621x740078132x740079611x74007816
Fortunately, because natural gas is denser than LP, the LP orifices can be bored out for a conversion back to natural gas. After a lot of homework I was able to find someone with the natural gas orifices for this stove that let me take them out to measure them. For some crazy reason, Whirlpool does not have this information:
Find a machine shop or a good appliance repair shop that has a wire gauging bit set. The natural gas orifice hole sizes are as follows:
Left front burner (16K BTU): 48Left rear burner (9.2K BTU): 54Center burner (5K BTU): 58Right front burner (12.5K BTU): 52Right rear burnger (5K BTU): 58
It cost me $25 to have these resized after I found the correct hole size.
Finally, to complete the conversion back to natural gas, you must flip the plastic screw-shaped piece by unscrewing the hex nut on the regulator at the back of the stove.
Hope this helps, because it took me a while to figure it out.
Converting aan LP oven to gas
In most cases the pressure regulator has to be changed or adjusted. The orfices on each burner, oven, broiler and surface burner may need to be changed also. Sometimes they can be adjusted. Sometimes the threads on the pipe are different also. This is to prevent accidental connection to the wrong fuel. The big difference is the gas pressure. LP is usually around 10 - 12 lbs and natural gas is usually around 3 lbs. Properly adjusted you will like natural gas much better than LP as it is slightly hotter. The information will be in the instruction book and also on the Jenn air web site. Whirlpool owns both Maytag and Jenn aire so check all sites. The conversion kit is usually less than $50.
Apr 20, 2008 | Equipex PZ-330 Electric Single Oven
Jenn-Air JGR8855BDS Gas Kitchen Range Logo
76 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
