Question about Garmin nuvi 205 GPS Receiver
I have a garmin 760. I updated the garmin today and now it is stuck loading maps and will go no further. It only shows up as a mass storage device on the garmin screen and my computer does not find it at all.
  • 1 more comment
  • rk4364 Mar 20, 2011
    neither one worked..............it just powers off
    i never saw a pre boot mode
    when i turn it on in the car while plugged into the 9v adaptor it will load half the maps then get stuck...........
  • 4,924 Answers
First ..try a Hard reset ..to get to the factory defaults of the device ...and see if this will work for you ...
To do so ...follow :
Turn off Garmin device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press "Yes" to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
this will erase user data ..and so ..but will reset it ..and it may start again ..
If not..maybe when you updated..you skipped some files or something ..and now you will have to do another trick ..and in this case..I found something ..:
1. Power off the unit.
2. HOLD down the power button and you will see "Pre Boot Mode" appear on the lower part of the display. KEEP HOLDING the power button down and the display will flicker, do this until the pre boot mode message disappears. This seems to take a long time (60 seconds at least).
3. Once the pre-boot mode message disappears release the power button and your device will perform some activities to recover from the above problem.
Posted on Mar 20, 2011
  • Catalin Turcu
    Catalin Turcu Mar 20, 2011
    the update wasn't successful and this is what causes the issue s...try to go on line again ..and make the update again with the online updater from the Garmin ...and see if it gets back ...cause from the computer you will not be able to change it ..without the wizard they provide...
Garmin nuvi 760 map update free download
Garmin Express Garmin Express but it probably won't be free. $50 for one time or $90 for lifetime... dont get the lifetime, get a new unit instead.
Jul 29, 2014 | Garmin Nuvi 760 Car GPS Receiver
Garmin shows picture of computer
When the Garmin shows the picture of a computer, it means that the Nuvi is in mass storage mode. This mode is used to load software and map updates to the Nuvi and will usually go into this mode when connected to a computer or improper USB cable.
If this is occurring when it is connected to the vehicle power cable, chances are that the vehicle power cable is the wrong one.
You may also want to contact Garmin Tech Support for assistance.
1-800-800-1020
Feb 23, 2012 | Garmin nuvi 1450 GPS Receiver
Garmin shows only device being reloaded/recharged
When the device shows that it is hooked up to a larger device, it is in mass storage or data mode and usually will do this when connected to a computer to receive map and software updates.
This will also happen if the Nuvi is connected with an incompatible cable.
Using the correct vehicle power cable will remedy this.
The Nuvi 300 is an old GPS and should probably be replaced with a newer model.
Jan 08, 2012 | Garmin Nuvi 300
My Garmin Nuvi 250 w gets stuck on the screen showing a picture connecting a computer to Garmin. I have it in my car and resetting hasn't worked. any suggestions
The nuvi is being put into mass storage mode (the mode used to transfer data back and forth to a computer). This is usually caused by using the wrong vehicle power cable.
The correct cable is Garmin part number 010-10723-06.
http://www.gpscity.com/garmin-mini-usb-12v-cigarette-lighter-adapter-for-nuvi.html
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
Garmin is stuck on loading maps and doesn't go beyond this point
If your device is currently experiencing the following symptoms it may need to come in for service/repair:
  • The device powers on and freezes at the Garmin logo with no trademark or copywrite info displayed on the device which normally shows up below the logo. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and freezes at the Garmin logo and then flashes a white screen briefly. The device then begins a loop of showing the Garmin logo and then flashes the white screen over and over again. The device will not display the Main Menu and will not go into Mass Storage Mode.
  • The device powers on and then freezes or shuts down when displaying the Loading Maps screen.
For service/repair of a device due to the three symptoms listed above please select "No - I would like to submit a follow up email" below this article. You will be taken to an email form that you can submit to obtain a Return Material Authorization number.
Please note: It is important to completely fill out the form with as much information as possible including:
  • Market Name: On the Road
  • Serial Number (listed on the bottom of the device)
  • Question Type: Repair Information
  • Provide a short description of your problem or question: nuvi frozen on Garmin Logo
  • Full Name
  • Contact Phone Number
  • Shipping Address
Nov 12, 2010 | Garmin nuvi 205 GPS Receiver
Screen is stuck on loading maps screen, garmin nuvi 1200
  • Full Name
  • Shipping Address
Nov 11, 2010 | Garmin nuvi 1200 Car GPS Receiver
Screen Acts likes its locked
Question: My nuvi 850, 855, 860, 865, 880, or 885 is freezing up or will not boot up past the Loading Maps screen.....
Answer: If your nuvi 850, 855, 860, 865, 880, or 885 is experiencing any of the following symptoms:
  • The touch screen is no longer responsive and the unit appears to be locked up
  • The unit will turn on however freeze at the point where it indicates that it is Loading Maps...
  • The unit takes five minutes or longer to be recognized by your computer as a mass storage device
A software update is now available for you to update your nuvi to correct these issues. Please use our WebUpdater program to install this update.
Please note: Due to this problem, it may take up to five minutes before your computer will recognize your nuvi as a mass storage device. This software update will correct this issue as well. //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 12/21/2009
Feb 07, 2010 | Garmin nuvi 885T GPS Receiver
Garmin Nuvi 760 memory card
Does the Garmin Nuvi 760 require an additional memory card for normal use?
The simple answer is : no it does not need and SD card to work
Jan 26, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
How to load maps from google to garmin
This solution works for more than the 760. i think it will work for all 6xx and 7xx series.
a simple solution to convert Google maps to Garmin routes and is found here:
http://www.elsewhere.org/journal/gmaptogpx/
In essence, you create your route in Google maps and then click the recommended url bookmark.
Save the GPX file to the Garmin device and from "My Data" (under Tools) convert the file to a route. You are done.
hope this helps pls appreciate by rating as fixyaa thanks
Nov 23, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin nuvi 205 GPS Receiver Logo
41 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
