Question about Acer Aspire 6920 Notebook PC
Hi, I have a problem with my acer aspire(6920),when i connect my notebook to a power supply it keeps restarting,but if i take out the incoming power and use only the battery it works fine...
    Master:
  • 346 Answers
Hi Roe - It then is almost certain that the problem is your external A/C adapter. Until this gets sorted out I wouldn't keep plugging it into the laptop...it may be capable of doing damage to your PC. There is also a possibility that is the A/C circuity inside the machine.
The easiest thing to do (if you have the ability) is to use a voltmeter and measure the actual current coming out of the adapter. Most people don't have access to one so I'd recommend you take the adapter to a local electronics store (Like Radio Shack in the U.S.) and ask them to check the current (It should be outputting 19Volts DC @ 3.42 Amps or something very close.
The above assumes the machine is out of warranty. If not, obviously you should give Acer tech support a call and proceed there.
Should you discover that it is the A/C adapter and is out of warranty you should purchase a replacement adapter such as the ones listed HERE and you'll be back up and running.
Thanks for inquiring at Fix Ya
Mikeywaf
Posted on Mar 20, 2011
    Master:
  • 344 Answers
You must have a short in your power supply. Is it the original power supply? If it is not then I would suggest that maybe you have the voltage and or amperage set wrong. If it is the original Power supply then Have you or someone you know take a volt meter and check it for proper voltage at the connector.
Acer Aspire 6920 Restarts in Normal mode and works only in safe mode
Sounds like the MBR ( boot files) are corrupted. Try formatting the hdd before you instal again. I'm sure you have a restore sector on the hdd in which case, if you have done anything to that then you'll need to have the restore disc set which usually comprises of the restore disc and the drivers disc. Either way....just make sure you format c and not d which is usually the resore partition. Good luck
Nov 24, 2013 | Acer Aspire 6920 Notebook PC
My acer 6920 restarts automatically when AC power pluged in.. it runs fine in safe mode and on battery too it runs fine..... what to do ?? service center says d mother board is causing problem but no...
Start your system in Safe mode.
and try to restore your system for previous date.
If your are not compatible with how to restore, Go to the link and follow the steps.
http://support.microsoft.com/kb/306084
Otherwise you can try to reinstall the OS.
Thanks for using FixYa.
May 17, 2011 | Acer Aspire 6920 Notebook PC
Where is wireless capability switch on acer aspire 6920
Acer's website supplies a generic manual for the Aspire series, which may help: http://v.gd/eoMupe The manual refers to a "switch near the keyboard". If the the switch is not present on your particular model, the alternative appears to be to control settings through the "Windows Mobility Centre" software. Again, you can download that from Acer, here: http://v.gd/FDzpCr
Feb 28, 2011 | Acer Aspire 6920 Notebook PC
My Acer aspire 6920 laptop keeps freezing . It will load up fine and then after about 5 or 10 minutes it freezes and says the programme is not repsonding. Noting will work i.e. the mouse won't move,...
HI, what program is show this message? is it always the same program? if so try uninstalling that program and reboot the laptop to see if it will freeze up.
Dec 20, 2010 | Acer Aspire 6920-6621 Notebook
Acer aspire 6920 laptop some times automatic restart. in normal mode hang when connected ac adapter
It appears that some of the the Windows files are corrupted on your computer, you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as
soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
NOTE: This will erase all the datas on the computer.
Thanks and regards,
Jitha
Nov 24, 2010 | Computers & Internet
Hi i put my acer aspire 6920 through a restore to fatory settings, it restarted itself and now it starts up as fair as the logo and then all that happens is a flashing line in the left hand corner please...
The BIOS can't locate the boot loader so windows can't be booted. It's a bad install, do the recovery procedure again. If it fails again then the hard disk is defective, replace it before reinstalling one more time.
Sep 06, 2010 | Acer Aspire 6920 Notebook PC
ACER ASPIRE 6920 DVD NOT WORKING/CD WORKING
I have Acer aspire model . I was also have same problem & these days also. But you just install a DVD nero writer & get the noise little down, That's all.
I think its a Acer - point.
Jan 30, 2010 | Acer Aspire 6920 Notebook PC
How to reformat my acer aspire 6920
when on a restart press "alt+F10" easy as that :P
the cd is alredy inside your comuter just its hidden. after u hawe done so its just as heaving a cd in your drive :P have fun
May 15, 2009 | Acer Aspire 6920 Notebook PC
Acer Aspire 6920 Notebook PC Logo
300 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
