Question about Raymarine C70 GPS Receiver
My c70 today, went from normal operation to a screen full of flickering vertical lines. Any clues as to what is wrong??? Cheers Peter
    Problem Solver:
  • 6 Answers
The cause: damp.
Easy solution: press on left side of screen. Voila!
Longer answer:
The connection between screen and computer is made bij means of a long, small horizontal strip with multiple connections in the vertical plane.
The strip sits loosely between the left side of the screen and the print.
When damp occurs the connections between the screen and the computer can be lost.
Helping to re-establish the connection by means of light pressure on the left side of the screen solves the problem.
Posted on Jan 26, 2014
I have the same problem and I think it is caused by the sun (heat) on the screen plus it being housed in a sealed plastic mounting " Box" which is attached to the steering station on my sailboat. The box has no ventilation access. When it is a hot day it goes vertical and then overnight it cools down and works fine the next day.
Lousy product design in the first place plus the box is asthetically nice but not suitable even though it appears to be specifically meant for the C70. Rebooting the system as suggested by Raymarine does not work - it wont react as it is too hot.. I once hired a local technician to check it out - $100 later, he had taken it apart and put it back to together and it worked again - obviously it cooled down when open.
Raymarine products are not on my wish list - never again. I have no idea as to whether drilling a few holes in the sealed box would help but dont want to risk getting moisture in there.
Hope this helps. Geoff. S.
Posted on Aug 09, 2011
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. Has been fine . Goes away once in a while. An Ideas what is wrong ?
Main power supply regulator board can cause this. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. any Ideas ?
Vertical lines showing up after being on for awhile
Eh, I can't be too sure, but it sounds like it's either a heat issue, a signal issue, or a backlight issue. Either way, if it's still under warranty I'd send it in.
May 06, 2013 | Sharp LC60LE835U AQUOS Quattron 60" 3D...
Good morning When I switch on my C70 i have not the normal screen, only vertical lines. Sometimes the screen works, but next time the same problem appers...vertical lines e can't use it. Can you help...
I recognize the problem. It mostly occurs when the plotter is exposed to moist during some days. The contactstrip which connects the computer to the screen gets moist and does not conduct in an optimal way. The result is a non readable screen with stripes
The solution is simple: press on the edges of the screen and the contact is re-established.
Oct 04, 2010 | Raymarine C70 GPS Receiver
LCD monitor have Vertical lines and black colour become greenish
normally the 19" resolution can support up to 1280*1024, but if it comes with vertical lines in full screen, it might indicate the panel is no longer to work and probably it's time to replace new one.
Aug 12, 2009 | Neovo S 19 19 in. Flat Panel LCD Monitor
PROSCAN 42' LCD COLOR TV MODEL 42LA45H
I am sorry Sir, the display panel is bad. If you purchased it new, it should under factory's warranty. Please call Proscan for a warranty repair.
Proscan Customer Service:
1-800-968-9853 (US and Canada)
May 31, 2017 | Proscan 42LA45H 42 in. LCD TV
Screen flickers and goes stripey
YES THE PROBLEM IS WITH THE CONNECTION
Sep 15, 2008 | Toshiba Satellite A105 Notebook
Screen flicker, color swirls
Mine does the same has done since new, It was sent back and when returned it still does the same. If i tap the top of the screen it comes right again for about 10 miniuts
Jan 22, 2007 | Neovo F-417 17" LCD Monitor
Raymarine C70 GPS Receiver Logo
413 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
