Question about Moen 24 In. Towel Bar...
How do i remove a towel bar that does not have a set screw on the flange cover?
  • Ellis Hawkins Jan 07, 2012
    I just ran into this issue. The actually rosette slides over the mounting bracket. If it is made like mine you simple push up on the rosette and losen it from the mounting bracket. You may want to wiggle first if it seems stuck.
  • 2,100 Answers
I think you grab hold of the rosette closest to the wall and spin it off, it should expose the set screw. If that isn't it, one of those things will turn. Try a few different spots. hope this helps.
Posted on Mar 20, 2011
How to remove a towel bar with slot in bottom no set screw
Inside the slot there is a tiny set screw May be slotted head or allen screw .
Aug 19, 2014 | Moen 24 In. Towel Bar...
How do you fix a Moen Towel Bar when the mounting system has come apart from the wall?
There are larger screw-type anchors available at a hardware store. If the hole is a half inch, you can possibly use an expanding wing type "molly" anchor. it's hard to assemble the screws through the bracket, then put on the butterfly, and shove the folded butterfly into the hole, but it's doable.
Jul 28, 2014 | Moen YB2218BN: Brantford 18 in. Towel Bar...
How do you remove the eva towel rack holder
The Moen YB2824 is attached to the mounting bracket with a set screw through the base. You would simply need to loosen this set screw to remove item from the wall.
May 07, 2011 | Moen YB2818 Eva Towel Bar Bathroom...
I need to remove a Moen towel bar. It has a tab under the bottom but I dont know what to do
There should be a "set-screw" (a very small screw) at the bottom of base (fat part) of the towel bar. It screws in to hold the fat part of the bar to the "tab". Loosen the screw by turning it counter-clock-wise. Once loose, the towel bar will lift off the tab. Be careful not to lose the screw!
Feb 21, 2011 | Moen YB8086 Mason Towel Ring Bathroom...
How do i take front off side hub off toyota. i wanted to change the bearing but i can't take the wheel locks off or hub
IF EQUIPPED WITH FREE WHEELING HUB. SET THE CONTROL HANDLE TO FREE.REMOVE THE COVER BOLTS AND PULL OFF THE COVER.REMOVE THE CENTER BOLT WITH WASHER.REMOVE THE MOUNTING NUTS AND WASHER TO THE HUB BODY.USING A BRASS BAR AND HAMMER TAP ON THE BOLTS HEAD AND REMOVE THE CONE WASHER.PULL OFF THE FREE WHEEL HUB BODY AND GASKET. IF YOU DONT HAVE FREEWHEELING HUB. WHEN YOU USE BRASS BAR AND HAMMER TAP ON THE BOLTS HEAD AND REMOVE THE SIX CONE WASHERS.YOU NEED TO INSTALL TWO BOLTS TO THE FLANGE TIGHTEN THE BOLTS TO REMOVE THE FLANGE.THEN REMOVE THE GASKET FOR THE FLANGE.LET ME KNOW HOW IT GOES.
Feb 16, 2011 | Toyota 4Runner Cars & Trucks
How to remove towel bars and hooks from wall. No set screw visible. We did not install them.
Newer towel bars don't have set screws... Solution-slide off! There is an opening in the bottom of the bracket. Slide your flat head screw driver inside the opening and place pressure on the bottom. Make sure you place enough pressure to allow the holder to slide off.. Now pull on the holder and it will snap off...
Sep 23, 2010 | Moen 24 In. Towel Bar...
My towel bar is coming off of the wall and I need to tighten it to the wall. How do I do this?
Towel bars usually have a base that attaches to the wall with a screw. To expose the screw, you must loosen and or remove a small screw on the underside of the mounts. Once the screw is exposed just tighten it.
Jul 29, 2010 | Moen 24 In. Towel Bar...
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
Epson Aculaser C9100 Colour Laser printer
If you changed the bottle and rebooted the printer with no change, it could be that the sensor for the bottle may be faulty. Try cleaning it:
1. Remove the CASSETTE ASSY.
2. Open the COVER ASSY FRONT.
3. Remove the two screws (silver, flanged, 8mm) that secure the COVER over the sensors. Remove the Snap from the main unit Frame, and remove the sensor COVER.
4. Use a paper towel or cloth to clean the sensor area of any dust or toner
Nov 08, 2007 | Epson Aculaser C1100 Printer
Moen 24 In. Towel Bar... Logo
648 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
