Question about Whirlpool Washing Machines
Whirlpool Serial # CK5151376 It will fill with water and wash b ut does not spin. It sounds like the power shuts off. Is it the timer?
Chances are the timer is defective. You can have it repaired at a good price which is cheaper than a new one. I just replaced mine lately for 65$,and the washer is working like a new one. Go to a part supply store and they will sent it for repair. It took me 4 days to get it back.
Posted on Mar 20, 2011
Whirlpool washer won't wash or spin or dump water
usually a broken lid switch if it fills with water and then nothing,set the timer on spin and pull out the timer,open the lid and stick a screw driver into the hole where the plastic acuator on the lid goes into the hole and push down easily and see if washer will run this is where the lid switch is and it's only a safety switch so when the lid is open the washer won't run,if not push up and down on the switch and listen for a clicking sound,no click switch is bad part number 285671,watch video
http://www.youtube.com/watch?v=Ag1eT5PrMnE
Apr 06, 2013 | Whirlpool Washing Machines
Won't finish the final spin
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Post further comments for more information ....
Good Luck!!
Thanks
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The washing machinge is not completing the complete cycle
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stops in the middle of wash cycle
Hi!
If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Stuck in spin
Hi!
If the Washer is stuck in spin then either the timer or a cold-water supply problem is causing this :
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance, then you need to replace the timer.
Do rate the solution as FixYa and revert for further clarification.
Thanks
Rylee
Apr 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Long cycles on my whirlpool duet washer
Apr 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
As washer was on final spin cycle it sounded like a belt came....
Apr 01, 2009 | Kenmore Washing Machines
Whirlpool WTW5800SW doesn't always agitate
Sounds like you may a bad lid switch. Do you hear any clicking noise when the lid gets shut. The clicking noise is the lid switch activating.
Dec 26, 2008 | Whirlpool WTW5800SW
Whirlpool Washer will not progress to the rince cycle.
that is either a problem with the timer , or with the cold water hose at the back of the machine, see the following:
I quote from : The cycle doesn't advance
The cycle doesn't advanceWhen the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It'sthe timer, if your washing machine fills with water and beginsagitating, but the timer never advances--or if the washer is in a spincycle and the timer won't advance. Then you need to replace the timer.
  • Itmay be a cold-water supply problem, if the washing machine fills withwater, agitates, drains, and spins, but then doesn't fill with rinsewater. See There's no cold water.
  • Nov 20, 2008 | Washing Machines
    Whirlpool AWO3761 stuck mid-cycle
  • Jul 06, 2008 | Whirlpool AWM6100 Front Load Washer
    Washing Machines Logo
    12 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
