Question about Nintendo Wii Console
Wi not accepting commands from remote - Nintendo Wii Console
  • 50 Answers
Hi there
you have the sync error
This needs to be repaired.
you can send the console to Nintendo for free if in warranty, if out of warranty then this will cost you around $150, the whole process will take 4-6 weeks
I prefer the Wii repair guide Method, download the guide and follow the simple step by step instructions and fix the problem in less than an hour, no hassle, low cost everybody is happy.
Best Regards
WiiRestore
Feel free to leave a comment if you need assistance
Posted on Mar 24, 2011
Element 40 led will not accept any remote control codes supplied by element technical support also Comcast technical was at my residence for 1hr tried 5 different remotes nothing works?
Hi Larry,
What did the Comcast Tech say in the end? In such cases either the remote senser inside the TV goes bad or the micro processor stops accepting the command. Unfortunately there is nothing you can do about it yourself. Ask the Comcast or someone else who can fix it.
Apr 13, 2015 | Element ELCHW402 40 in. LCD HDTV
Samsung tablet will not accept wi fi password,the model is sm-t330
first forget the wi-fi network than try again manually .
Feb 09, 2015 | Samsung Tablets & eReaders
Wharfedale dvdr24hd169f stays in standby no displays wont accept commands
The problem is in the power supply board, often caused by a defective capacitor that becomes open, cap value is usually around 1000uf and sometimes shows a bulge at top leaking contents, if you are handy with a soldering iron replace part with identical value and voltage rating and observe the polarity.
Jun 09, 2012 | Wharfedale Televison & Video
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
I can't return to command mode dvd3 (default) from dvd1. Now my remote is useless and I can't find a way to bring up the main menu so I can get back into command mode dvd3.
Slide remote lower cover and look for DVD Command mode set switch, set it to DVD-3 position, your RDR-VX530 will accept remote commands.
Thanks.
Dec 21, 2010 | Sony RDR-VX530 DVD Recorder/VCR
When i press the remote all i get is DVD 3
Your player has been set on remote mode 3, you need to change remote control itself on remote-3 so unit can get remote signals.
Set the command mode for the remote so it matches the command mode for the recorder.
Hold down ENTER.
While holding down ENTER, enter the command mode code number using the 3 number button.
Hold down both the number buttons and ENTER at the same time for more than three seconds.
Remote control has been set on mode-3, now player will accept remote commands.
Hope this will help you.
Thanks.
Nov 24, 2010 | Sony RDR-VX525 DVD Recorder/VCR
Vip 211 will not accept remote commands.
Hi orly227217 my name is Mike Houston of DISH Network customer service. And when the receiver is not accepting commands from the remote we need to re-program the remote to the receiver. What we do first is go to the VIP 211 and select the "system info" button and then we want to press the "menu" button. Then you will see the remote address in the white box at the bottom of the screen, then press and release sat button 1 time then press the record button 1 time. After that you will have seen the remote address change.
Dec 23, 2009 | DISH Network ViP 211 DTV Receiver
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
Remote won`t work
Do you have a "universal" remote or a "learning" one. What brand and model is the remote? The learning remote must have the original one to properly program the codes you need....accordianman
Apr 24, 2008 | RCA VR349 VHS VCR
Nintendo Wii Console Logo
56 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
