Question about Vitamix 5000 Work Top Blender
When replacing the blade on a Vitamix 5200 do I need to use any type of lube on the retaining ring when reattaching?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
It says in the owners manual to use some food grade vegetable oil.That is what I did.
Posted on Apr 10, 2011
Vitamix blender recalls.
Important Vitamix Safety Recall Vitamix has issued a voluntary safety recall for the "64-ounce Low-Profile" container that has been sold with three of its blender models: the Vitamix 7500™, Professional Series™ 750®, and Professional Series™ 300®. A potential safety concern has been identified with the blades used in this specific container. If you own one of the affected blender models, please continue reading to learn how Vitamix will replace the blade in your container with an updated design.
If you have a question about this recall that has not been addressed in our FAQs, please contact us at 888-350-4386. Has your blender container been recalled? If you own one of the products below, your container may be included in this recall. You can quickly determine if your product has been affected by looking at the blade in your container. The part number and date of manufacture are etched on the top of the blade, under the logo. If the part number is 103208 A and the date of manufacture is before August 2013 (shown as 08-13), your container is affected and needs to be returned.
Container Blade Recall
Feb 15, 2018 | Vitamix Blenders
How to replace the blade assembly on my Vitamix commercial 4000 (stainless steel pitcher) I have the blade assembly but it's more complicated to replace than I thought. HELP.
there is a wrench (by Vitamix) for under $10. you can get it from amazon. it makes the job of removing a blade assembly much easier.
Jul 01, 2016 | Vitamix Blenders
Can the circuit board on the Vitamix be placed? I have a 5200 model which only runs on high. Changed the variable switch-no change to the speed.
Hello Melanie Richardson,
Looking around on the internet I did find parts houses
peddling parts...
But when I tried to go through the front door of VITAMIX... are interested in SERVICE (didn't seem all that WELCOMING to Do-it-
yourself OWNERS...
The short answer is yes ...
Vitamix 5200 Getting Started Machine
May 13, 2016 | Vitamix 5200 VariableSpeed Blender
Need replacement parts
they have an excellent customer service dept.
We own 2 of them. Great Product. We have one like yours the 5200, and the new 750. Awesome products, and they always are so helpful.
check it out here:
Contact Us Customer Service Vitamix
Aug 17, 2014 | Vitamix 5200 VariableSpeed Blender
Vitamix TNC 60 oz container leaks when in use. how to replace seal and or bearings?
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Oct 21, 2013 | Vitamix 5000 Work Top Blender
Leaking blender jar
Oct 30, 2012 | Vitamix Super 5000 Work Top Blender
I need to replace the speed control potentiometer. How do I open the case on this machine?
Hi there. I know you were looking for an answer 5 months ago. I didn't see the correct procedure listed. My speed control just bit the dust. Anyway, here goes: Pull off the rubber cover where the container sits. You'll see 4 phillips screws, unscrew them (you can leave them in place). Next, on the black drive wheel in the center, look to find a small triangle molded into the outside of the ring. Line it up with a small slotted opening just under the drive wheel. Use a small allen wrench which fits in and unscrews a set screw. You can lift off the drive wheel. Now you have to pull the top off. On mine, it took some time as I was trying to be careful not to break anything. With persistence the top will separate from the base. My super 5000 has a 2 wire speed control knob. Hope this helps if you haven't gotten an answer elsewhere or taken it to the shop.
Sep 16, 2010 | Vitamix Super 5000 Work Top Blender
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Mar 22, 2009 | Vitamix Super 5000 Work Top Blender
Older Vitamix Problem
I want you to try this,
1.Remove the blender jar from the blender motor .
2. Check the jar by turning the shaft by hand to see if it rotates easily. .If not, disassemble the blade and ring. Check for obstructions or misalignment. It is better to change the shaft which holds the blade......
If it fails you again, you have to contact with the service center or visit this site
www.vitamix.com/household/service/service.asp
Hope my info helps you,
Thanx for using fixya,
Waiting to help you from your comments.....
Oct 01, 2008 | Vitamix Super 5000 Work Top Blender
Vitamix 5000 Work Top Blender Logo
381 people viewed this question
Top Vitamix Blenders Experts
Marvin
Marvin
Craig Butler
Craig Butler
Holly...
Holly...
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
