Question about Toshiba e-Studio 161 Copier Copier
Light copy then developer quantity very low. - Toshiba e-Studio 161 Copier Copier
  • 132 Answers
IF YOU YOU HAVE DONE MORE THAN 50.000 COPIES WITH THAT DEVELOPER MATERIAL REPLACE THE DEVELOPER MATERIAL. BUT CHANGE THE SEALS AND MAIN CHARGE GRID. THAT SHOULD SORT YOU OUT. ALL THE CONSUMABLES ON THAT MACHINE IS 50K COPIES
Posted on Mar 20, 2011
I changed the drum and added developing powder and did the reset but it still is printing blank copies on my bizhub200
Developer may is not of good quality or quantity, so can not reading proper Toner voltage ratio
Aug 04, 2016 | Konica Minolta bizhub 200 Printer
Why does the oil indicator light not come on when the oil is low?
Oil pressure sending unit may be bad or the wiring could be corroded/damaged. The light bulb may be burnt out. What is the vehicle info ?
May 19, 2016 | Cars & Trucks
How kyocera works
developer and toner are two drifernt things you have to check to see if the developing unit is installed correctly
Jul 27, 2014 | Kyocera Km-3060 Mfp Copier Copy Machine...
Minolta di183 cof32 code
Man!!!!!!!!!!!!!!
Start first bye buying a new drum, cleaning blade and developer. Hope fully you did not destroy the sensor on the bottom of the developer unit it has a ribbon cable. You need to clear the counter for developer drum first in service mode. Then replace the developer and drum and cleaning blade together as one!!!!!!
Then run the required F-8 procedure in service mode.
Sep 08, 2017 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub 362 code 2557 for what
It's toner density sensor problem but first of all check if there is sufficient amount of developer and toner. Low quantity of developer/toner in developing unit also cause this problem.
Reference
Jun 05, 2011 | Konica Minolta Bizhub 362 Copier
My FW780 will not make copies. Only white paper comes out after attempting to make a copy. No toner exhibited on the paper. I get no 'low toner' messages or warning lights on the control panel. What...
Check the developer motor maybe the developer is not functioning
or the primary and transfer corona needs cleaning as this cause the hi voltage leakage to ground
so hi voltge is produced results to no copy.
Jan 25, 2011 | Ricoh FW 780 Black and White Copier
My sharp copier ar 5316 has printed 0nly les than 1600 pages and now showing toner cartridge low, even les than 10%
please check the devoloper , if the quantity is lessthan the specified the same quantity will be filled with toner.
Oct 23, 2009 | Sharp AR-5316 Advanced Digital Imager...
Keep copier ready; disable powersave option
This is going to be a user program:
1) press and hold both light and dark keys
a) the 2 buttons to lighten and darken copies
b) hold both for 5 sec until indicators light up
2) use the left copy quantity key show 2
3) press your copy key
4) use the right quantity key to change to 2 (max 90 sec)
5) press the copy key
repeat step 2 but change to 3 with left quantity key
press the copy key
change right number to (4 = 60 min, 1 is default at 5 min) then press your copy key.
Once done press both light and dark key again to exit
Note*** changing shut off timer and preheat will effect copy lamp ready state. Every 60 sec or so the scanner will move and reset. Some people do not like the noise is makes all the time. If you don't you can always change it back to the defaults. 2=0 and 3=1.
Oct 12, 2009 | Sharp AL 1631 Copier
Sharp 7900 black copies and low developer
The problem is the drum blade is going bad.This machine is about 15 years old not worth the time or money plus alot of parts are no more.
Jan 24, 2009 | Office Equipment & Supplies
Sharp ar-m237 copier
Direct light can effect the copies. Your unit may also need developer as well. If the developer is low or gone out of the unit, light copies will appear as well.
Jul 10, 2008 | Sharp AR-M237 Copier
Toshiba e-Studio 161 Copier Copier Logo
82 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
