Question about Sony BD Remote Control for Playstation 3
Controller will not connect to system - Sony BD Remote Control for Playstation 3
    Problem Solver:
  • 14 Answers
Did you go to settings, accessory settings, register BD remote control, then press start and enter?
Posted on Apr 30, 2011
Code reading is 1447 is it the same as 1440?
No these are 2 different fault codes, although they are related to the same system
EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
Nov 02, 2016 | Cars & Trucks
P0701 tranny code
Possible causes
- Open or short transmission control system circuit
- Poor transmission control system electrical connection
- Check powers and grounds to Transmission Control Module (TCM)
What does this mean? What does this mean?
Possible symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
Read more:
P0701 Transmission Control System Range Performance
Jan 13, 2015 | Cars & Trucks
Controller comes on but want connect to system
Have you tried the sync/pair buttons on both the controller AND the 360? (be sure to hold the buttons until the lights spin)
Mar 26, 2014 | Microsoft Xbox 360 Wireless Controller
Diagnostic code p0701
P0453 means EVAP emission pressure sensor high input. Possible causes:
- Faulty Evaporative Emission System (EVAP) Pressure sensor
- Evaporative Emission System (EVAP) Pressure sensor harness is open or shorted
- Evaporative Emission System (EVAP) Pressure sensor circuit poor electrical connection.
Code p0701 means Transmission control system range/performance. Possible causes:
Aug 27, 2013 | Cars & Trucks
My son has a xbox360 and were trying to get xbox live to connect and it wont we had it working just fine on his brothers hes not home so we hooked it up to the other xbox 360 and it wont connect
1 Disconnect all accessories and wired controllers from the Xbox 360.
2 Hold the "Guide" button down for three seconds on any wireless controllers, then respond to the prompt on your television screen to disconnect the controllers from your system.3 turn on the wireless headset by pressing the "Power" button in the center of the earpiece. 4 Press the "Connect" button on the front of your Xbox 360 system. 5 Press the "Connect" button on the wireless headset. The ring of lights around the power button of the Xbox 360 system should spin and blink once. One of the lights should remain lit up, indicating the port number that the headset is using. If you do not see any lights on the system, you may have a faulty wireless headset.6 Press the "Guide" button on your wireless controller to reconnect the controller to the Xbox 360 system. If you are using a wired controller, you can plug it back into the system.7 Press the "Connect" button on the top of your wireless controller to sync the controller with your system. You should see the connection light around the "Guide" button on the controller light up, indicating which port you are connected to. You should also see a corresponding port light in the ring around the power button of your Xbox 360 system 8 Press the "Connect" button on the wireless headset until the port light on the headset matches the light on the controller and Xbox 360 system. For example, if you are the first player, the light for port number one should be lit up on the Xbox system, the controller and the headset. When all lights correspond, your headset should be properly connected.
Sep 29, 2011 | Microsoft Xbox 360 Console
We can not connect the controlers to the xbox 360 but they will connect to others can you help with this problem??? we recently got it fixed because it had a red ring
Turn your system on and turn the controllers on, when the controllers are blinking the four green lights, press the small white button to the right of the second memory card slot. The 4 green rings around the power button with rotate clockwise. Now press the small white button next to the left bumper on the controller. Both the system rings and the ones on the controller will blink in unison and that controller will be connected to that system. Repeat for as many controllers as you have. Hope this helps.
Nov 23, 2010 | Microsoft Xbox 360 Console
I connected my dualshock to one PS3 and now it wont connect to the other, it will only charge when plugged in.
When you connect the controller to a PS3 system via cable it pairs with it. And the only way that controller will work with another system is to plug it in also and let it pair with that one. That way when you turn the controller on it wont power up two systems and browse two systems at once. This is the way that Sony designed the controller.
Oct 31, 2009 | Sony Dual Shock 3 Controller for...
Rs2100 bookshelf stereo
The Audio System does not respond to the remote control.
1. To reset their connection, turn on the remote control and switch the Audio System to Standby mode.
2. In Standby mode, press and hold both INFO and SOURCE on the front panel of the Audio System. It is reset to default when"RF ID clear" displays.
3. Press and hold both PROGRAM and SELECT on the remote control. When “ID claer” displays on the LCD of the remote control, the connection is reset.
4. By now the remote control and the Audio System should be connected to each other. Press and hold PROGRAM and SELECT on the remote control again. When
“ID Locked” displays on the LCD of the remote control, the connection between the remote control and the Audio System is locked.
Jun 06, 2009 | RCA RS2100 Shelf System
MY REMOTE ALWAYS SHOWS ME REM506....
May 07, 2009 | RCA RS2100 Shelf System
No Audio Out through the Optical OUT jack
just press the DVD button on the remote contol and you will be ok.. :)
Jun 16, 2008 | LG LHT734 System
Sony BD Remote Control  for Playstation 3 Logo
561 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
