Question about APC Bt1000 Ups Replacement Battery Replacement Battery Battery
APC BT 1000, WHAT IS THE STANDBY TIME FPR USING 2 COMPUTER
    Scholar:
    New Friend:
  • 129 Answers
Hi Shaick,
1 to 3 minutes is about normal runtime for running two computers with monitors plugged into each... just enough time to properly power down the computer before power goes out.
If you need UPS, Surge, or Power Related help contact:
Daniel, daniel@psihq.com, with Power & Systems Innovations 800.260.2259 or go to our website: http://psihq.com/
•• If this helped - click YES :) ••
Posted on May 29, 2014
Apc beeping twice every 2 seconds
The battery inside the APC is "weak", and the "beep" is telling you to replace the battery inside the APC, or, maybe cheaper, to buy a new APC.
Feb 03, 2014 | APC BACKUPS ES BE550G 8Outlet 550VA 330W...
APC Back-UPS Pro 1000: The original smart cable from the UPS to the computer is a serial cable. I'm looking for a serial to usb cable to replace it (the macPro that it will protect does not have a serial...
This older model APC does not support USB and it is inlikely that even if you found a cable that would connect them that the electronics in this unit would play nice with USB. Might be time to consider an upgrade, although these are a great units they just do not have the compatibility with newer computers.
Mar 29, 2011 | APC UPS: BP1000 Back-Ups Pro (UPSAPC08AS)...
My ups 1000 watts suddenly get off for few minutes than again starts itself .it happens 2-3 times in 24 hours.
Back up devices on the computer creates copies of every new features that are performed. The backup devices default settings may allow to save data every often like 2-3 times in 24 hours. also, the backup devices save settings can be altered to suit user speciifcations. for example, important projects on important files may require to save every few seconds lest any malfuntion that occurs to the computer is misplaced. back devices are considered external structures and should be locate on the computer systems control panel area with a unique description. Clicking on the backup devices logos would allow to manipulate either create urgent backup or space the backup to make the computer faster where back becomes attainabel durign idle hours.( for example, set the computer backup to first tthing in the morning or last at close of computer usage.)
Feb 05, 2011 | APC Back-UPS RS 1000VA UPS System
APC XS 1000 UPS battery back up beeps three times every minute. "see manual" "AVR" flash in screen.
It is SUPPOSED to beep during battery supply power.
It drove me nuts,too!
I know it's running off of the battery!!!!!!
I have APC 550 and a 750. Both do it.
Not anymore.
I took it apart and mangled the beeper,inside.I used a dental pick and poked the diaphram inside of it.(power off)
Clicks,but no BEEP!
Barely audible,now. Done.
Sep 05, 2010 | Computers & Internet
Battery does not hold charge
Normally with 1000VA models, the battery will be user replaceable. You can order a replacement battery pack and replace it.
May 10, 2010 | APC Smart-UPS 1000VA UPS System
It is possible to attach the 120 AH battery with APC 1000 va UPS
YES IT IS POSSIBLE TO CONNECT A LARGER BATTER TO THE APC UPS. IT WILL ONLY NEED MORE TIME TO CHARGE THE BATTERY.
Apr 10, 2010 | APC Smart-UPS 1000VA UPS System
Want to replace batteries in my ups
APC BX1000 UPS.
First analyse with local UPS service engineer to find out the problem is related with UPS.
It requires 12 Volts batteries for this UPS Usage.
The batteries required are 2 Numbers.
Buy these batteries from authorized APC Vendors and these batteries are having 1 year warranty.
In case of any problem, these batteries will be replaced at free of cost.
To close this solution, please get in touch with Authrzed UPS Service Engineer.
Jul 11, 2009 | APC BX 1000 Back-UPS XS 1000 (APNBX1000)...
Apc ups 650va no power when connctd to ac/bt wd power in on batry
Check the relay Circuit. the relay switch must be faulty
Feb 24, 2009 | APC Back-UPS Pro 650 UPS System
APC Bt1000 Ups Replacement Battery Replacement Battery Battery Logo
126 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
