Question about Datel Action Replay for Nintendo DS
I have installed the software correctly and updated it with the latest patch but the card isn't recognized by windows 7 and wont read it
I need a manual
James: I could not find one for you either. However, I do know that on my own computer, I can't switch a mouse without restarting my computer or it does not recognize it.
May 25, 2015 | Pixxo MA-9EG5 Black 2.4 GHz Wireless...
Tip
Quicken will not print more than seven checks.
You may run into this problem if you use the 2005 or 2006 version of Quicken’s personal finance software (such as Quicken Basic, Deluxe, Premier, Premier Home & Business). If you try to print eight or more checks at once, they won’t print.
According to Quicken Help & Support, Intuit fixed this problem for both the 2005 and 2006 versions of Quicken. You’ll need to download and install the latest patch, which includes the fix for this problem. Quicken offers manual and One Step Update methods to update your version of Quicken with the latest patch. You’ll need an Internet connection to download the patch. If you have a dialup connection, connect to the Internet before you start any of the update methods below. Once you complete the patch installation, Quicken will be able to print eight or more checks.
To read Quicken’s solution for this problem, visit www.quicken.com, click Help & Support, and then select 2006 For Windows (make sure Quicken For Windows and Quicken 2006 appear in the Product fields). Next, type 2997 into the Search field and click Search.
Update Quicken 2005 manually
Visit Quicken Help & Support, select 2005 for Windows, and enter 3810 in the search field. Open the How Do I Manually Update Quicken 2005 For Windows To The Latest Release? link. This page has all of the patches for Quicken 2005. However, you only need to download the patch that has the highest R number. The latest patch carries all of the data from the earlier patches. In this case, you will want to download patch QW05R5PATCH.exe.
Click the file’s link. If you have Windows XP, a File Download – Security Warning may appear. Click the Save button. In the Save As window, choose a location to which you’d like to save the file and then click Save. When the download completes, simply double-click the file to start the patch installation.
(NOTE: This method involves downloading and installing a single patch file. If you don’t have an Internet connection but have a friend who does, you can download the file to his PC and then burn it to a CD [assuming your friend’s PC has a CD-RW]. Use the CD to transfer the file to your computer.)
Update Quicken 2006 manually
Visit Quicken Help & Support, select 2006 for Windows, and then enter 3796 in the search field. Open the How Do I Manually Update Quicken 2006 For Windows To The Latest Release? This page has all of the patches for Quicken 2006. However, you only need to download the patch that has the highest R number. The latest patch is QW06R3PATCH.exe and carries all of the data from the earlier patches.
Update Quicken 2005 Or 2006 With One Step Update
You can also update your version of Quicken using One Step Update. You can start the update by clicking Online Menu and then selecting One Step Update. Next, uncheck any checkboxes that appear and then click Update Now. The tool will download and install the latest update for you.
by: -micromaster
on Mar 19, 2008 | Intuit Quicken Basic 2004 (028287007543)...
I re-installed the operationg system (Microsaoft Windows 7) for Asus N5S3. It asked me to install the intel card and the Nvidia card; after intalled them the Nvidia is read as a driver in the Device...
Certain video cards are only compatible with certain processors on motherboards. AMD CPUs work with Nvidia and Intel CPUs work with certain graphics cards also. Are you sure it's even compatible?
Dec 29, 2011 | ASUS Computers & Internet
Video drivers windows 7 HP Mini 2133
For this occurs it isn't correctly installed to system so you need to download the video drivers and install them to the laptop and update to latest version and the problem will be solved.
Remember to download the correct video drivers or go device manger the display adapters and update
and select option search automatically and install driver software to your laptop.
Sep 12, 2011 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
Unable to burn discs using Corel Video Studio X2. Program all OK until final phase of burning. Using Windows 7 on new PC. Could problem be Windows 7? Any help appreciated.
Make sure that you have all the patches installed from Corel's site, there is a known issue that the buttons will not show up on Windows 7 unless you have the latest patch.
If you have all the update installed there could be a few different issues.
1. update direct x from Microsoft
2. Make sure your video card drivers are up to date
3. Try rendering the project first and then burn the rendered file to the DVD
4. Try burning a Disc image, the option is on the final burn screen, if you are able to create the disc image try a different burning software that you may have installed on the system
Sep 11, 2011 | Corel Video Studio Pro X2 for PC
My tuneplus is not recognizing my ipod...what is the deal?
you'll need to have latest version 2011.01.19.0
the problem with the outdated version is that it was incompatible with the updated iTunes. and so anyone with iTunes 8 and higher won't be able to use Tuneplus. luckily, Broderbund/Mediashop managed to fix this. Though it seems the updated version isn't available through normal means of "Tools" then "Check for updates". so here's what you do, uninstall your current version of Tuneplus. then download and install this updated patch.
Mar 29, 2011 | Broderbund TunePlus for Apple iPod Full...
My laptop which has windows 7 on it does not recognize mmy dongle
there is an update for windows 7 and dongles at the husqvarna viking website.
From Husqvarna Viking website -
When installing the 4D Embroidery System onto Windows 7 computers, the dongle drivers may not initially work correctly, as the 4D Embroidery System installs a set of dongle drivers which were created before Windows 7.
Download and install the latest dongle drivers prior to installing the 4D Embroidery System. Failure to do this, may result in the "Dongle driver not found (E0009)" when you try to open the 4D modules.
Please follow the steps below to install the latest dongle drivers BEFORE installing the 4D Embroidery System
  1. Download and install the latest Dongle Drivers.
  2. Insert your 4D Dongle.
  3. Install your 4D Embroidery System software (and all updates).
  4. Open your 4D Embroidery System software to confirm that your dongle is working correctly.
If you installed the 4D Embroidery System software before installing the latest dongle drivers and if you experience problems such as the error message "Unable to start hasplms service..."; download and install the latest Dongle Drivers.
link to latest Dongle Drivers - http://vsmsoftware.net/downloads/HASP/HASPUsersetup.exe
Husqvarna Viking - http://www.husqvarnaviking.com
If you are still unable to get it to work, visit your local authorized Husqvarna Viking dealer. Most stores have staff who are eager to help but you might want to call for an appointment
Good luck..
Feb 13, 2010 | Husqvarna Designer I
Loaded autodigitizing onto our new computer with Windows 7. Everything loaded just fine but when I try to open program it does not recognize the dongle.
There is an update for dongles and windows 7.
Info on Husqvarna Viking website - http://www.husqvarnaviking.com
Link to dongle drivers - http://www.vsmsoftware.net/downloads/HASP/haspusersetup.exe
Good luck.
Feb 09, 2010 | Husqvarna Designer I
For Singer Futura CE 250. New laptop with windows 7? Loaded software & tried 64 bit Vista update patch - it doesn't work. Is the newer patch available for download? Can't use Live Update because...
Update with WIndow 7 support is already available at:
http://www.futura-support.com/downloads/ce150.html
If you applied wrong patches you will have to uninstall Futura, reboot, install from the beginning the basic version and then apply an update 3.0.0.9
Jan 03, 2010 | Singer CE350
Datel Action Replay for Nintendo DS Logo
22 people viewed this question
Top Datel Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Martin Murray
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
