Vizio tv model M261VP HDMI not responding "No source" While there is a source(checked with other TVs)
3 Suggested Answers
SOURCE: vizio vw42lf hdmi problem
The factory menu won't help you diagnose anything. If you are having issues on both HDMI ports, definitely check the cable and that the output works on the DVD player, try this on another TV if possible. If all else fails, call Vizio @ 1-877-MYVIZIO and they will send one of us techs out to replace the main A/V board, that should resolve your problem.
Posted on Aug 21, 2008
freelance-au
  • 131 Answers
SOURCE: i cannot get a picture on the screen of my tv. I
Hi
Firstly and would remove all the leads from your TV and check them. If after checking your HDMI leads etc... and its still the same then i would reset the TV to the original Samsung settings. This is completed on your remote control by the following........
Turn your tv to standby, on the remote when in standby press the keys on the remote in the following order........ INFO.........MENU..........MUTE.........POWER ON.
You will now notice the picture comes on with the engineers settings in the background. With the direction keys on the remote scroll down to number 12 (RESET) Then press OK or the right direction key, Your tv will switch off and load the Samsung factory settings. Switch the TV back on and go through the setup procedure.Once completed then try your HDMI again.
If it is still failing then there is a strong possibility that your Eeprom IC on your main AV Board is corrupt and needs replacing. This should only be attempted if you have good soldering skills as they are Surface mounted and very small.
My advise if your skills are not that good is just to replace the main AV board (Scart Board) these usually sell for around £50 but WILL solve your problem.
I have gone trough everything i know here that would cure the fault, most times one of the above three will cure this, but im afraid other times its just time for a new AV board.
Hope iv helped some people out here.
Any comments or thumbs up appreciated.
Posted on Nov 18, 2010
When selecting the source, HDMI 2 will not highlight, Only TV. HDMI cable connected to box and to HDMI2 port on TV
You have to check the HDMI cable. In Samsung tvs the HDMI sources only highlights if the a proper HDMI sources is connected to the corresponding HDMI port of the tv. Also check by connecting any other device which have and HDMI connectivity to the HDMI 2 port.
www.electro-medical.blogspot.com
https://www.facebook.com/electromedservices?fref=nf
Oct 02, 2015 | Samsung UN22F5000AF 22 LED 5000 Series TV...
How do I respond to a "NO SIGNAL" message?
Without knowing the TV make or model this will be a guess.
If your TV remote has an "Input Select" or "Source" button, pointit at the TV, press it and make sure the input source is set to TV or Television.
Later model TVs can have multiple input sources like HDMI, VCR, DVD, etc. They are also sometimes listed as Input 1, Input 2, etc.
Jul 24, 2015 | Televison & Video
Can't figure out indoor antenna input
first off . Indoor antennas are only good for the closest tv stations and you still have to do a channel search thru the main menu .
Oct 12, 2017 | Vizio M261VP 26" LCD TV
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Jun 24, 2011 | Vizio 42 in. LCD TV
My Vizio M261VP picture and sound went off last night but the power on white light on the corner of the frame kept blinking. Once before I unplugged this unit for a while and this fixed the problem. ...
If its something your comforrtable doing remove the back cover and test the power supply voltages, I think you will find at least one is missing, and in that case replace the power board
Nov 29, 2017 | Vizio M261VP 26" LCD TV
A message is on my screen that says, "Video 5 HDMI is not supported
Whatever you have plugged into HDMI 5 is set to a resolution that exceeds the TVs ability to display. Try setting the source to 720p or 420p
Mar 12, 2011 | Vizio M190VA 19 in. LCD TV
My Vizio M261VP was purchased three weeks ago. A week ago, the audio on channels other than the digital HD channels are very low. For example, an analog channel or Netflix via the VIA the volume needs to...
I would return the Set ASAP! TV has a factory defect,take it back and get you another TV,
and If it happens to do the Same thing Then Company might have more then several TVs that must be returned to Factory.
I had a Friend of mine who bought a new Tv got it home it had a problem she took back 3 TVs and they all where doing the same thing.She just got her money back and went to another store.
But they did Offer Her Another Set from company.
Feb 27, 2011 | Vizio M261VP 26" LCD TV
My vizio 42" all of a sudden lost sound on the
I can see good video, but I hear no audio with my XWH200 adapters?
Published 11/21/2011 06:46 AM
Updated 11/21/2011 02:26 PM
While most HDMI sources work with good audio and video, we have a compatibility issue with audio from a few specific products (eg, DirecTV HD DVR satellite set-top box, DISH Networks satellite set-top-box, and TiVo Premiere XL cable set-top-box). If you are experiencing problems with no audio or muted audio with one of your HDMI sources, then please try changing the audio settings on your problematic HDMI source to PCM or LPCM. Then turn off the TV, remote power from the WirelessHD adapters, and power off the HDMI source. Now power everything back on. If you are still experiencing no audio then please write down the model number of your HDMI source with no audio and contact VIZIO customer support.
Oct 27, 2010 | Vizio VW42LF 42 in. LCD HDTV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
