Question about Protron PLTV3250 32 in. LCD Television
Power just cut off and will not come back on. I see that this is a comon problem with this model from what I have been reading.
  • 11,361 Answers
Check the power supply; look for bad caps with leaking/bulging tops, check to see if you have standby +5vdc at the power supply connector, the front red indicator will not be on if you do not have this +5vdc standby voltage due to shorted out Q7 and ZD4.
http://s807.photobucket.com/albums/yy352/budm/Protron%20PLTV%203250/
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Power supply: http://www.google.com/products?rlz=1T4GGIH_enUS282US283&q=pltv+3250+power+supply&um=1&ie=UTF-8&ei=9lIDTL7XO4fcM7HA-Ds&sa=X&oi=product_result_group&ct=title&resnum=1&ved=0CCgQrQQwAA
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 21, 2011
    Scholar:
  • 90 Answers
Yes your right about that and it works on all type of electronic TV. You see the TV has this electronic board and it powered by DC. And the source of it is the power supply.
if you have encountered a dead set TV or On and Off in your unit try to check the power supply.
It may have some bulgy capacitor or leaky one. This causes insufficient power output or fluctuation that causes the unit to trip. Defective power MOSFET for swicthing, open fuse, etc. But don't worry these problems are repairable. Once it fix your TV will works as new.
Well good day...
Posted on Mar 20, 2011
  • Protron Master
  • 5,568 Answers
In many sets, this is an indication of a failed power supply voltage.
There are at least two supplies in every set; one is active always so the set can receive commands from the remote and requires minimal power and rarely fails.
The other is turned on when the set is to be used and this one, is the likely culprit.
The type of supply used in modern sets is called a 'switched mode' power supply that operates at higher (than audible) frequencies in the range of 50,000 cycles and up. The supply first makes DC voltage from the AC input of 100-220 volts, then chops it at the elevated frequency.
This design is much more efficient than the older type of 'linear' supply but is more complicated and critical in the quality of parts used.
These modern supplies are fussy about the quality of certain components and most will eventually fail due to crappy electrolytic capacitors, a part used for filtering and in feedback paths and they, by nature, don't really like these higher frequencies; they tend to break down chemically and lose their value until finally not performing as capacitors any more.
This causes the supply to fail at starting up and more rarely, to cease operating while in service and sometimes develop internal losses that cause it to heat up and burst or at least bleed chemicals either of which causes their final death.
There are capacitors that are more resistant to this kind of decay but cost 2-5 times as much as common types and with the severe price competition in consumer electronics, manufacturers save where they can and use parts that will at least survive the warranty period.
I suggest you contact the service center for your area and inquire about the cost of board repair or replacement. If the latter, keep the failed board since there are small shops (I was one before retirement) with the skills to repair these at a more reasonable cost.
Before opening the back of your set, pull the plug and allow to sit; preferably overnight.
There are nasty voltages inside that you want to avoid.
The main power supply is often on a separate board, will have larger-than-average parts on it, with cylindrical parts (mostly capacitors) and some larger squarish parts (chokes and transformers) and most likely a 'heat sink,' a finned aluminum structure with parts attached to it.
Look for a tag with a part number on it and have this available when you start looking for service or new board.
If you believe you have identified the supply, look for a fuse which may be any of three cases but will be marked with a component number such as "F1." With any kind of meter, this can be checked for continuity, then replaced. If it blows a second time, it will need repair.
These assemblies are nearly always only plugged into the rest of the set with clearly dissimilar plugs so incorrect connections are somewhat prevented.
If you are unsure of yourself, take several pictures of this area before disconnecting anything that you can then refer to if uncertain.
Remember, many assemblers of most of these just recently came in from small farming villages in Asia so assembly is kept simple.
Good luck-
How do i cut ac belt in a chevy metro 2001
the a/c belt is the smal belt that goes to the a/c compressor and you want to know how to cut it , easy just grab a very shar rasor blade , knife or sisors and use then to cut the belt ( not a rocket science )
just take comon sence
May 06, 2012 | 2001 Chevrolet Metro
After self cleaning not heat up
There is most likely a thermal fuse in the back of the oven. When this blows it cuts the power to the elements. This is very comon after self cleaning. Take the back off the stove, locate the fuse and check for continuity. (Turn off Power) Hope this helps. Google search thermal fuse for your brand of oven to get an idea of what the part looks like.
Apr 23, 2012 | Refrigerators
My radio cut out speakers all the time i removed it and the wiring is stil factory so it must be in the radio is this comon?
I would check the connector on the back of the radio, assuming you checked the speaker wires already.
Jul 18, 2010 | 1991 Honda Accord
JBP78 won't heat, breaker ok, stopped after auto clean
I need the Model # off the machine to help you.
Most comon problem with Electric range if The TOC or hi limit fuse after a clean cycle. This is usualy located in the rear of the machine behind the back pannel.
As always disconect the power to the machine befor trying to fix.
Jan 11, 2010 | GE Spectra JBP78 Electric Kitchen Range
Shuts down on its own
very comon the crt is shorting out and not avail crt are not made any longer
Dec 02, 2009 | Televison & Video
Power outlet in back seet does not work, Windows are unlocked
This may be a simple fuse issue; very comon for power outlets. I' start by checking this out. If not a fuse you may have an open wire that will need to be traced down.
I hope this may have helped,
Tom
Oct 06, 2009 | 2004 Maybach 62
Newer hp 6300 when I print some lines are unreadable, others dark
Dear sir; this is a very comon problem,most people don't know how to take care of, now power on, open the cover until cartridge move and stopin the middle, then UN-PLUG (not turn off) the power cord,let the cartridge stay in the middle,now push cartridge all the way to the end opposite of cartridge seat,use Q-tip with water to clean print head cleaning blade,may be also you can see a ink sticker, remove it, make sure cartridge print head is ok,let me know the resolve. GOOD LUCK !!!
Dec 19, 2008 | Office Equipment & Supplies
Motor cutting out
BMW CUTS OUT
A few things to check.
  1. Is fuel pump delivering enough fuel.
  2. Is injectors clean. Perhaps dirt in fuel. replace fuel filter
  3. Air leakage at top air intake of manifold at ICV idle control valve. Two hoses inside this housing prone to perishing.
  4. Throttle position sensor faulty.
  5. Mass air flow sensor faulty.
  6. ICV faulty or dirty. comon fault on older e36.
Havent done it yet but ICV is easy to clean according to internet. instruction available at bmw e36 blog. All off above can be tested by yourself according to manual.
Nov 12, 2008 | 1999 BMW 323 Series
Ford focus 1.8
anyone that can afford to code read for free needs there head looking at my equipment has cost me thousands of pounds and returned me a lot more !!!!!! does the rev counter do funny things as well ? ...
Oct 15, 2008 | 2000 Ford Focus
Hints for service
comon fault in it , as the picture stucks it is a weak heads you can get better result by cleaning the guides and if not so change drum heads regards , plz don't forget to rate thx
May 02, 2007 | Panasonic NV-MD9000EN Mini DV Digital...
Protron PLTV3250 32 in. LCD Television Logo
83 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
