Question about Texas Instruments Computers & Internet
Outputs of TI analog 500-5016 do not change when inputs to Ti 520 controller are changed. Mother board consists of power supply , TI 520c controller, TI 500-5016 analog output, TI 500-5009 analog input, Ti 500 digital 32pt input ,TI 500 digital 32pt output Tried different TI 500-5016 analog output module with no change or improvement
  • Texas Instru... Master
  • 12,061 Answers
Hi, The VERY first thing we MUST check, is the PSU, check this exhaustively, even if possible replace with a know good, as if this isn't 100% A OK, NOTHING else can be..then well ADC 101 says that if there is NO output from the ADC, then this can only be due to 2 reasons, one, it is Inhibited, two, there is NO DATA to be converted/coming out? We need to find out why?
You need to use a 'scope and view the input and output signals along with the lines that control the IC, data flow, Inhibit etc, and see if all the lines are in the correct logic states, work back along either the control lines or signal, and work out why either it is inhibited or lacking signal.
Also check that you micro, isn't inhibiting it either?
Start at the beginning, where the analog signal is presented, and follow a line(s) along through the circuit with the 'scope, checking where they enter the conversion IC, then look at the Output(s) and see whats what, now if all control lines are set OK, and there is NO output then that IC must be faulty... anyway follow the signal along and see why it's not working..
unfortunately there could be many, many conditions that can cause this type of thing, one simply? must work through each block of the circuit, isolating sections if possible and viewing the activity on a 'scope to see where it all goes wrong. checking the voltage and signal levels are correct.
Posted on Mar 20, 2011
Computer don't start,
If it doesn't start at all, check motherboard for a short by unplugging the processor power cable (4 pin normally), and turn the computer on. If the fans start rotating, it is probably a short. If that isn't the problem, check for cables that should be connected, and test the processor in another computer. Hope it works (it did for me)
May 27, 2014 | Powerspec G213 Desktop Computer; Intel...
I want to upgrade to the new GeForce GTX 550 Ti by Nvidia, but I don't know if my HP Pavilion a6042n has a slot for it. Do you have a picture you can circle the slot so I'll know where it is on the mother...
Hi bain_j,
your motherboard has a slot for this. I have encircled the slot on the picture I have attached. Also I checked and the current Power Supply that came in with your HP Pavilion will not be able to support the card. You would need to get a new power supply unit preferably around 600 watts and with a PCIE 6-pin power. I hope this helps. Please let me know.
Janc30
Mar 23, 2011 | Computers & Internet
What kind of batteries and where can I find batteries for my TI-30A?
I hope you mean the TI-30XA, since TI never released a TI-30A.
The TI-30XA uses two A76 batteries, also known as 357. You should be able to find them at just about any department, electronics, or office-supply store.
Here's the full scoop on changing batteries:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=71660
Oct 21, 2010 | Texas Instruments TI-30XA Calculator
New power supply does not work...is it the motherboard
well there are two ways to to figure out which item is broken first you can hook up the power supply and test the pins in the plug with a voltage tester to see if it has power. I do not recommend this approach if you are unsure of what you are doing the voltage coming from a computer power supply is very dangerous. the second thing you could do is attach a different power supply to *********** board if ti works the mother board is good and it your power supply that is busted. Also make sure to check the back of the power supply and make sure it is set to 110 and 220 voltage because this can cause your power supply to not function correctly. It will be a little red switch on the back that says 110v on one side of it and 220v on the other.
I hope this helped.
Thank you,
Norse
Jul 03, 2010 | EliteGroup L7VMM2 Motherboard
D865PERL won't power on after power loss. i have two doing the same thing.
Hello there:
The first thing i would check is the power supply if this is not working it needs to be replaced
Also you can unplug the power from the computer and open the case and find the power supply cord that connects to the mother board and dissconnect ti from the mother board ,
now press in on the computer power button and hold for 30 seconds and do the same for the reset button if it has one this will release any (ESD that may have built up ) now just reconnect the motherboard cord that you dissconnected earlier and plug in the power cord to the computer and try to restart
OK? I hope that this has been very helpful for you
Best regards Michael
Nov 16, 2009 | Intel D865PERL Motherboard
Computer won't power up
This happens sometimes due to SMPS failures. Try to change with other SMPS with same watts.
If it happens same then the problem with the board.
Try to consult a technition.
Thanks & Regards
Nanda Kishore
May 21, 2009 | HP Pavilion 520c PC Desktop
How can I convert 1 GB Ram into Mother Board 810 E?
YAS IS GOOD YOU CAN UPGRADE YOUR MEMMORY TI 1GB ALL YOU NEED TO DO IS GET THE EXACT TYPE OF WHAT YOUR MOTERBOARD IS USING eg IF YOUR MOTHERBOARD IS USING DD RAM GET 1GB DD RAM IF IT SD RAM YOUR BOARD USES THEN GET SD RAM. IT GONNA BE FINE WHEN YOU UPGRADE IT WILL PARFECT YOUR PC PERFORMANCE.
Nov 20, 2008 | Intel Motherboard
TI 810 Blowing F2 fuse
Try Changing the bridge rectifier near the transformer.
Dezzi
Dec 30, 2007 | Texas Instruments TI 810 Matrix Printer
Inspiron 6400 DC input fault
please remove the power supply pin from the mother board short the pin witres colured green and black if the power supply is working then there is no problem with the power supply check ur memory card to if the pwoer supply is working iff its ok and still not working contact a chiplevel engineer to correct the mother board as there is problem with powersupply section in ur motherboard
Oct 22, 2007 | Dell (8N816) Motherboard
Computers & Internet Logo
128 people viewed this question
Top Texas Instruments Computers & Internet Experts
Bapco
Steve
k24674
Are you a Texas Instruments Computer and Internet Expert? Answer questions, earn points and help others
