Question about Motorola Lands Phones
I have a mirrson android phone? and it got water damaged.i put it in rice for a couple days and i tried turning it on and only a bright light comes on and goes off.. what is the bright light?
  • 87 Answers
This is the back light of the phone and is what is used for the display. It sounds like one of the layers of the display are not functioning. Unfortunately this is not something that is easily fixed. You'll want to bring it to a technician.
Posted on Mar 20, 2011
Water spilled on my huawei android
Water and electronics don't mix.
Immediately, (too late for that), remove batteries.
Wipe off any excess liquid with absorbent paper or cloth.
I have heard that if you bury it in rice overnight, with the battery out and cover removed; that the rice will absorb moisture.
Next day put the battery back in and turn on.
However if there was damage done instantly, you will just have a dry android that doesn't work.
Feb 02, 2015 | Huawei Cell Phones
Htc one how to dry it out after being drop in water
UGH! Sorry to hear that. You could try the old Bowl of Rice method, where you place the phone inside a bowl of rice, or inside a ziplock back full of rice, and then leave it there for a couple of weeks. (the rice is UNCOOKED!!!) Hopefully, that helps. If not, your phone might be toast. Check and see if you have insurance with your carrier, and whether they insure against water damage.
Jun 29, 2014 | HTC One X Android Smartphone Glamour Gray
Screen wont come on my galaxy s4
If your phone gets wet. Turn it off immediately and remove the battery. Let it dry out naturally for quite a long period. this can be aided by leaving the back of the case off and the battery out.
If an attempt is made to power the player on before it is dry, the probability is that it will short out inside and never work again.
There is a phone on the market that will work under water but I can't remember the make.
May 21, 2014 | Samsung Galaxy Player 4 8GB Android Tablet...
My Android Fusion was dropped in water and now won't turn on
Sometimes these things take a while to dry out before they perform the way they're supposed to. Stick it in rice for a few days more. I've had luck with placing it near NOT ON a heat source to aid in drying it out. You don't want to scorch the thing, but leave it in the rice for a couple more hours to days & see how that goes. You should be up and running in no time.
Oct 17, 2012 | Huawei At&t Fusion Prepaid Android Gophone...
Water damage to pba on my samsung galaxy ace
If there is still water in the phone, get a bowl and put some dry rice in it then the phone then cover the phone with rice and make sure it is completely covered. The rice will pull the water out of your phone. Leave it in as long as you can, preferably over night. You could also put your phone and the rice in a zip lock bag. It's more portable.
Feb 29, 2012 | Android Galaxy Ace
Iphone 3gs, had some water on the screen (not much), i checked it and everything was fine,,, includeing the brightness, then i put it down and didnt think about it,, went back late and the brightness wont...
your screen have been affected with water. When you accidentally drop your phone in water, DO NOT turn the phone on yet instead put the phone in a bag of rice, the rice helps to seep water. Since you turned on the phone already, there is nothing to do but get the phone repaired or replaced.
Apr 23, 2011 | Cell Phones
The phone got wet, the screen wont come on.how can I fix it?
Water is the phones biggest enemy. Usually what works is after it gets water contact. As stupid as this sounds. Put it in a tub of dry white rice for a couple days. Rice will soak up any moisture. Then it should work.
If it doesn't then the phone is probably damaged
Mar 22, 2011 | LG Shine KE970 Cellular Phone
Water damage
water damage generally = dead or unreliable phone. If you did all the stuff ... removing the battery and rice for a couple days ... you will probably have to replace your device.
Sep 27, 2010 | Sony Ericsson W890i Cellular Phone
Droped my i phone in water what do i do
Easy Steps to Follow for iPhone or iPhone 3GS Water Damage Below are 12 easy steps to follow if you're iPhone has experienced water damage. Read on below for more details on each step.
  1. Do not turn it on - that means, do not touch any buttons.
  2. Do not turn it on - that means again, do not touch any buttons!
  3. Do not turn it on - again, this will cause the phone to short circuit if there is ANY amount of water in it
  4. Take it out of the case and remove the sim card.
  5. Shake out any extra water.
  6. Use a blow dryer on low heat for about 15 minutes to try and blow air through it and get rid of some of the water. Make sure it is on low heat.
  7. Shake it out again.
  8. Put it in a bag of rice, make sure it is completely covered
  9. Leave it in the rice bag for 2 -3 days if your phone was in water for less then a few minutes and 6-7 days if your phone was in water for more than that.
    Each day, take it out of the rice and use the blow dryer on low heat again for an additional 15 minutes. Then, put it back in the bag of rice.
  10. After 2-3 days you can check to see if it is still wet by shaking it a little to see if any water comes out. Sometimes, water may not come out so if you want to be sure, leave it there for 4-5 days.
  11. After you've left it in the rice bag for enough time, then try and turn it on to see if it works.
Remember: This is not foolproof, but it has worked for many people. The whole point of putting it in rice is to help it dry and remove the moisture.
What to do if you just damaged your Apple iPhone or iPhone 3GS First, do not turn the phone back on. By instinct, I wanted to turn it on to see if it was working. However, if you do this, the phone will short circuit because you are putting electricity through it while there is still water in it. Water in an electronic device may not break the item. However, too many times, people turn on the item right after to check if it is still working. The act of turning it on causes you to put electricity through it. Before, when it was off, no electricity was running through it. By putting electricity through something that has water in it, you will cause the item to short circuit.
I repeat this a couple of times just so everyone understands. If you can dry out the item and remove the water, it just might work. The water will eventually cause the electronics inside to rust, but it may not cause the item not to work.
So, after not turning on the item, what do you do? You try to dry it out. You let it sit. Some people recommend putting the iPhone in rice. Take a large amount of rice, put it in a gallon ziploc bag, and then stick your iPhone in the middle of it. You don't have to wrap it or anything, the rice won't damage it. See the video below for an example of how you do this. Basically, the rice will help to **** the moisture out. If you try this method, change the rice each day. Another method is to apply some form of heat against the phone - whether it is your blow dryer or a small room heater. You want to run low heat air through it for 30 min. to an hour every couple of hours. This will help dry out the moisture. Your entire goal is to help remove the moisture. Until you know the moisture is completely gone, do not turn it on. Depending on the amount of water, some people have recommended waiting anywhere from 2 to 7 days.
Finally, after doing all of that, slowly turn on your phone. Surprisingly, for many people, these methods of waiting and drying out the phone completely worked. Many people online had accidentally dropped their phone in the pool, tub, sink or some other source of water. For us, none of this work since the phone had been washed and sat in water for more than 30 minutes. However, if you drop your iphone into water for only a few seconds or a minute, then, a lot of times, drying it out will cause it to work again.
Apple store policy and procedures for water damaged iPhones or iPhone 3GS water damage One other tip. If it doesn't work, or it doesn't work right, you can now get it replaced for $199 at the Apple store. Previously, they wouldn't replace it since water damage automatically voids the warranty. Yes, the 2 year or 1 year warranty you have is not safe if you get water damage. There are 4 sensors on your phone (picture examples are below) - 2 that you can't get to while opening, and the other 2 that you can see. The first one is in the small round hole on top left of the phone (the earpiece hole), and the other one is in the bottom middle that separates the connector. If you shine a light and look at either of these, the sensor will be pink if water has touched this area. Because of this pink sensor, the folks at the Apple store will not honor your warranty which is what happened to me and my boyfriend.
But, the good news for us all is that Apple has now changed its policy. If you have a water damaged iPhone (pink sensors!), Apple will now allow you to replace it for a refurbished phone for a lower cost. It's $199 for a refurbished phone and the warranty is only 90 days, but this is a huge difference between the full price of $599 or $699 contract free phone that we had to pay to replace the water damaged phone. Also, don't forget, if you've bought your phone from Best Buy or used a credit card that offers protection, you may be able to get some of your money back or get the phone replaced for free. Don't miss out on these options since you will have to pay to replace the water damaged phone.
Repair OptionIf your sensors are pink and your iPhone is not working even after you've tried to dry it using the steps above, then you may want to consider sending it to a repair shop. Millieamp is a service that can potentially repair your damaged iPhone. For a small fee, they will first start out by evaluating the damage. Then, they will let you know how much they think it will be to repair. At that point it is up to you to decide if you want them to repair the phone or if you want to buy a new one. It is worth having them take a look in case they are able to repair the phone and you don't have to buy a completely new one, especially if you just bought the phone. Check out their iPhone and iPod repair services. They just might help you save a bundle.
Regards
Iversh
Jun 26, 2010 | Apple iPhone 3G
I have a LGvu with water damage, can it be fixed?
depends on how much water got in it and after if you tryed to turn it on it will burn everything in the phone ,if its light water damage then remove battery then but it on the heater for two day and let it dry out then but battery back in and see if it works if not then it wont be repair cause to repair all that will cost more then a new phone ,if my info was of any help to you please leave a comment ,thankyou.
Sep 02, 2009 | LG Vu CU920 Cellular Phone
Lands Phones Logo
20 people viewed this question
Top Motorola Lands Phones Experts
Marvin
Marvin
David Payne
David Payne
Are you a Motorola Lands Phone Expert? Answer questions, earn points and help others
