Question about Frigidaire FMV156DC Microwave Oven
I don't know how to replace the charcoal filter on my Frigidaire FMV157GC microwave. There's also food between the grate and the glass on the microwave door. Help !
    Genius:
  • 1,739 Answers
This is billed as the Use & Care Manual for the Frigidaire FMV156DC Microwave Oven:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Springfield/316495004en.pdf
Not sure it is the correct one but you will find instruction for cleaning the exhaust filters on page 19.
Below is the Use & Care Manual for a model direct from the Frigidaire site:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316495057en.pdf
This is more helpful as on page 20 it includes illustrated instructions for removing the charcoal filter to change the oven light. Disconnect from power, remove the ventilation grate at the top to access the charcoal filter, slide back and lift to remove. With the grate removed carry out any required cleaning.
Posted on Mar 20, 2011
Frigidaire microwave oven
Hello - This may or may not be specifically for your model, however these are generics instructions that I found.
To replace the light bulb to the over the range microwave you will need to follow the steps below:
1. To replace light bulb, first disconnect power to the microwave oven at the circuit breaker panel or by unplugging.
2. Remove the vent grill mounting screws.
3. Pull the vent grill away from the unit.
4. Remove the charcoal filter by pushing it inwards, then turn and pull it away from the unit.
5. Open light cover located behind filter mounting by carefully pulling up on the front edge.
6. Remove old light bulb and replace only with equivalent 30 watt bulb available from part distributor. Bulbs are also available at most hardware stores or lighting centers.
7. Replacing the microwave oven light cover by carefully pushing into place. Replace the charcoal filter. Push the vent grill back into place (engaging both the bottom and top tabs) and replace the vent grill mounting screws.
Note: DO NOT USE BULB LARGER THAN 30 WATTS.
Oct 27, 2012 | Frigidaire FMV152K Microwave Oven
We installed new microwave and don't know where the charcoal filter goes
Open the door and take off the upper side barre. and you are in bussnis
Sep 28, 2011 | Samsung 1.8 Cu. Ft. Over-the-Range...
What is the part number for the charcoal filter.
For a Frigidaire FMV156EM (which is made by Sharp), the charcoal filter is Sharp part number RK-240 also known as PFIL-B016MRE0.
The first part shows up in simple Google searches, so feel free to pick a vendor that shows up there.
But my best suppliers don't show it, and the second part number is only in the service manual, so it must be a proprietary number.
Otherwise, you can search for your nearest service / parts supplier for Frigidaire here.
The owner's manual is here, and that will help you in changing it.
Dec 31, 2010 | Frigidaire FMV156EM Microwave Oven
I was trying to clean charcoal filter, now not sure how to put back. Should it be horizontal or lil' slant position!
Charcoal filters cannot be cleaned. They must be replaced.
I'm assuming you have a Whirlpool brand microwave since you posted in a Whirlpool microwave category.
You can download free owners manuals and installation instructions for several brands (including Amana, Frigidaire, Jenn-Air, Kitchenaid, Litton, Maytag, Roper, Tappan, Thermador and Whirlpool) here.
You can find handy exploded views and order parts and accessories (such as charcoal filters) by entering your full model number here.
Sep 27, 2009 | Whirlpool MH1150XM Convection/Microwave...
Where is the charcoal filter?
There is no charcoal filter unless you replaced the standard filter with a carcoal filter. Also, it may have m=been changed to a charcoal filter if the unit was alterd during installation as a re-circulating vent, not vented to the outside via the roof or wall.
The filter (Charcoal or not) is on the bottom of the unit. Put your head under the microwave and look up, there it is.
Apr 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
DOOR REPLACEMENT
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Jan 14, 2009 | Frigidaire FMV156EM Microwave Oven
I was boiling water on the electric range beneath my FRIGIDAIRE FMV157GC 1.5 Cu. Ft. Microwave Oven when there was a loud snapping/popping noise occured. I immediately shut off the microwave and thought...
I would say the transformer for the power supply has probably shorted, or another major component in the power supply has shorted - This may be repairable if easily spotted, but most likely will not be cost efective.
Sep 04, 2008 | Frigidaire Microwave Ovens
How to clean the air filter of my goldstar microwave model # MV1526B/01
That sounds like the charcoal filter. It cannot be cleaned, and must be replaced. From the owner's manual:
CHARCOAL FILTER REPLACEMENT
If your oven is vented inside, the charcoal filter should
be replaced every 6 to 12 months, and more often if
necessary. The charcoal filter cannot be cleaned.
To order a new charcoal filter, contact the Service
Center.
1. Remove the two vent grille mounting screws.
(2 middle screws)
2. Tip the grille forward, then lift it out
To get a new filter, you can try local appliance parts stores or see customer service or find servicers here: http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Apr 13, 2008 | Goldstar MV-1526 Microwave Oven
Frigidaire FMV156DC Microwave Oven Logo
380 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
