Question about Kitchen Ranges
How to change out the light bulb - Kitchen Ranges
  • bjdalton1 Mar 20, 2011
    I want my money back. This was a stupid answer.
    People, this is a microwave! There is no simple little shield with 3-4 little screws. The bulb is behind the infrastructure.
  • 4,323 Answers
Hi
Please check this video for bulb replacement, it's an example though:
Hope this helps...please post back with manufacturers name and model no. for further assistance.
Daniel
Posted on Mar 20, 2011
  • 10,865 Answers
Hello bj... the kitchen range light bulb unscrews like most bulbs in a counter clockwise direction. Make sure you replace it with another oven bulb which is designed to withstand heat. Joe
Thanks for choosing Fixya!
    Genius:
  • 1,739 Answers
The oven light bulb is normally protected by an oven proof lens that is held in place by a metal frame and two small screws. It is installed from inside the oven.
You will likely need a Robertson or Phillips screwdriver to remove the screws. Once the lens is removed you simply unscrew the light bulb and replace with a appliance bulb designed for oven use; most hardware and department stores with a reasonable selection of light bulbs will stock these.
Replace the bulb, test to make sure it is working, and then replace the lens, metal frame and screws.
  • Lance Hill Mar 20, 2011
    If you post back with the brand and model name/number of your mcirowave will see if we can help further.
    Sorry but you did not specify your problem was with a microwave and it was posted in the kitchen range category. How to know?
Need the light bulb for the 6005 Elna. I've had this machine for many years and its been a real work horse, but now the light bulb has gone out in it.
Looking here, it looks like a capless bulb like in cars.
Lamp Socket Unit Elna 395723 43
In fact it is, a 12 volt 5 watt capless auto bulb
Changing the Light Bulb The sewing light is located behind the face plate. Unplug
the machine. Remove screw cap and screw. Pull away
face plate.
Pull out light socket. Pull out light bulb. Push in light bulb
with pins aligned to holes in light socket. Push in light
socket.
Replace face plate, screw and screw cap.
NOTE: Only use same type light bulb rated 12 Volts, 5
watts
6005 Elna light bulb Google Search
similar
ELNA 6200 Instruction Manual Changing The Light Bulb Feed Dog
Feb 05, 2018 | Sewing Machines
How do change a bulb in a classicflame 23ef010gaa
How to Change a Light Bulb in your Electric Fireplace
www.electricfireplacesdirect.com/changing-fireplace-light-bulb
Changing a light bulb within an electric fireplace is not hard, but we ... ClassicFlame23" Fixed Glass Spectrafire Infrared Quartz Electric Fireplace Insert - ...
Oct 29, 2015 | Cars & Trucks
How to change bulb
You can change the bulb from under the bonnet there should be a black rubber cover on the back of the light were the wires connect to the light bulb unplug light pull rubber cover remove metal clip then change bulb.
Aug 17, 2014 | BMW 318 Cars & Trucks
52" Vaxcel Fresco II Oil Burnished Bronze Finish Ceiling Fan cant change downlight
why not, cant you figure out how to change a light bulb? Look carefully at the way it is made, look for screws to remove a plastic or glass cover to get access to the downlight ,which i assume is a light that points down.
worst case senario is you have to read the owners manual under how to change the light bulb
or call up customer service and ask them how or at least how to call techinical service.
In all fairness , a down light may not be a light bulb that points down , but some kind of compact flouresent light bulb.
check if vaxcel has a web site. they might have instructions on how to change a down light bulb.
Feb 23, 2013 | Hampton Bay 24002 Ceiling Fan
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Right brake light is out and don't know which bulb to change
Have someone apply brakes. Observe which bulb lights in the left light housing. This is the bulb you want to replace.
May 07, 2009 | 2002 Jeep Grand Cherokee
CHANGING HEAD LIGHT BULBS IN 2002 CHEVY S-10
Right behind the light there should be 2 clips pull up on those and the headlight will come out to change the bulb
Dec 13, 2008 | 2002 Chevrolet S-10
Change ford festiva front light bulb
Hello, the front light bulbs are easily changed by twisting the plastic holder in the back of the lamp that holds the bulb counter-clockwise. You turn it about a 1/4 turn and then it pulls out and you can switch bulbs. Do not touch the new bulb with your fingers because oil from your fingers will cause the bulb to burn out quickly.
Oct 20, 2008 | 1993 Ford Festiva
Kitchen Ranges Logo
1,420 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
