Question about D-Link DIR-615 Wireless Router
My wireless network is visible but when I try to connect with the correct password , it doesn't connect because of an error. The only way I can get it to work is to change the password everytime, then a few hours later that password doesn't work.
    Sergeant:
  • 192 Answers
To see if your router is working properly press and hold the reset button. This will reset your router and it will have no password requirements. Connect to the network and see if it continues to drop the connection. If so, you have a bad router. If not connect to the router with the supplied cat-5e cable open an internet window and type 192.168.0.1 in the address bar. Select admin as the user name and leave the password blank. Then follow the set-up wizard.
Manual can be found here. http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Posted on Mar 20, 2011
Error 102-2931 on wiiu
  • Power cycle your home network.
  • If your wireless router or access point is unresponsive, power cycling these devices may resolve your connection issue.
  • Ensure you are using the correct password for your Wi-Fi network.
  • If your wireless router or access point is secured with a security key or password, review this password to ensure you have entered it correctly in the Wii U.
  • Create a new connection on your Wii U.
  • Create a new connection on your Wii U. This will ensure you are connecting to the correct Wi-Fi network and the Wi-Fi network is currently visible to your Wii U.
  • Check for wireless interference.
  • Wireless interference can result in a weakened connection between your Wii U and your wireless router or access point. Review your Wi-Fi network's setup to ensure an optimal wireless environment.
    Still Not Resolved:
    • If the issue persists, please contact at 1-800-255-3700. Specially trained representatives will be available to assist you, 6:00am - 7:00pm (PST), seven days a week.
Dec 02, 2013 | Nintendo Wii U
Cannot connect to wireless network and the
if you are entering the access point details manually ensure you have the correct encryption type selected (WPA, WEP etc) as you will not be able to connect unless you tell it the correct type.
if you are connecting to it from a selection of visible wifi networks you should try entering the password in a note (to ensure it is indeed correct) and then copying and pasting the password into the relevant password prompt box
Sep 11, 2013 | Apple iPad Mini
I have a windows 8 gateway laptop(NE71B Series) and its seems as if my wifi switch is disable. Anyone with a bit of advice on how to resolve this problem would be very helpful.
Recently had a coworker bring me a Gateway NE71B laptop.
Complaint: No wireless even using a VZW 4GLTE hotspot.
Observations:
; All drivers and devices are functional with no errors or conflicts.
; Wireless adapter has power and is not in Airplane mode.
; No wireless networks are visible even though there are normally as many as 12 networks available within the area.
; Wired Ethernet adapter works without issues.
Solution:
Turns out the BIOS was v2.05. After updating the BIOS to v2.13, wireless connectivity is functional. All locally available wireless networks (SSIDs) are visible.
Notes of caution:
; A failed BIOS update will invalidate your warranty per Gateway chat support rep.
; Ensure you have a fully charged battery before updating the BIOS.
; Ensure your AC adapter is plugged in and functional prior to starting the BIOS updater.
Jan 22, 2013 | Computers & Internet
WIRELESS GATEWAY
How to View or Change Your Wireless Network Password
Symptoms:
You have lost or forgotten the password to your wireless network
You have lost or forgotten the password for the router, access point or other network device
You left the default password or used a weak password and someone has hijacked your network
Depending on the router, you can either view or reset the wireless network password (also referred to as the passphrase or security key) if you can log into the router. Some routers mask the wireless network password, so while you cannot recover it, you can enter and save a new password.
If you cannot log into your router because you have forgotten the router password or your network has been hijacked, please refer to "Lost or forgotten password for router or other device" below.
To view or reset a wireless network password:
Launch your Internet browser and type http://www.routerlogin.net in or http://192.168.1.1 or http://192.168.0.1 the address field for your browser. Enter the router's username and password.
The default username is admin, the default password is password.
From the left-hand navigation menu of the Router administration interface, select Set Up > Wireless Settings
Note: On some routers this option will be under BASIC > Wireless.
From the center screen, you find the current wireless security settings under the Security Options heading.
If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Read more about Securing your Wireless Network.
If you cannot log into your router:
- If you were routed to the NETGEAR website or getting the "Page cannot be displayed" message when trying to login to router, make sure you are connected to the NETGEAR router. Check your wired connection and make sure cable is securely plugged in and LED is on. If wireless adapter is on, make sure you are NOT connected on a different wireless network.
- Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default access information to reconfigure your router settings. NOTE: Restoring factory defaults on a device will erase any customizations you have made. You will lose any configurations saved to the device!
See the following articles for more information:
Secure Your Wireless Network: WPA/WPA2 (Recommended)
Reset and Restore a NETGEAR device to Factory Default Settings
Default Password for NETGEAR devices
Jul 19, 2012 | Gateway Computers & Internet
I am trying to connect Netflix to my Wii and I keep getting error code 51330 and 51331. I don't know what these errors are. I am trying to set up with wireless internet.
From Nintendo:
Error Code 51330, 51331, and 51332
    It appears that the wireless security pass code for your home network may have been changed or is entered incorrectly on the Wii console. Click here for more information about WEP and WPA security, including how to access the settings for your Access Point.
If your wireless network password isn't wrong, reply. Hope this helps somewhat.
Jul 21, 2011 | Nintendo Wii Console
What is my password for a wireless connection?
Give this a try;
  1. Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password ispassword or 1234 unless it has already been changed.
  2. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings.
  3. From the center screen, select your encryption type from under the Security Options heading.
    • If the wireless network passphrase is visible, review it and use it to log devices onto your network.
    • If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
Mar 16, 2011 | NetGear DG834G Router
How do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
Mar 07, 2011 | Microsoft Xbox 360 Console
Xbox 360 wireless adapter doesnt work the light on the back just stays red and i dont get how to make it work
Hi. You just need to configure your adapter. It is not broken, it just needs to be set up properly. For information on how to do this, please see: http://support.microsoft.com/kb/908877
Feb 28, 2011 | Microsoft Wireless Network Adapter Xbox...
We cannot log on with the assigned password
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin)and password by default the password is 1234 unless it has already been changed
from the left-hand navigation menu of the router manager,select wireles set up>wireless settings
from the center screen,select your encrytion type from under the Security Options heading
if the wireless network passphrase is visible,review it and use it to log on devices onto your network.
If it is not visible you can change your wireless passphrase but changing your passphrase will cause you to lose your wireless connection
Connect your computer to the router using an Ethernet Cable before entering a new passphrase into the text box and clicking apply.
If you cannot log into your router:Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
hope this helps
Dec 30, 2010 | NetGear WNDR3400 N600 Wireless Dual Band...
Hi i am trying to access my home wireless network using my laptop. I get authentication error. I can connect to my home network by it says it is Unidentified Network for one and then it does not connect to...
you will be havin a wep or wpa security for wireless connection..type in that correctly..if u had forgotten it then connect ur laptop hardwire to ur router and configure router setting...type in 192.168.1.1 in ur browser address bar..ur router page will open..generally, by default password for router page will be "admin" or "password".. username will be "admin"...if u hav any issues then get back to me..
Jun 11, 2010 | Intel PRO/Wireless 3945ABG Network...
D-Link DIR-615 Wireless Router Logo
69 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
