Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Sub-Zero temperture fluctuation
The temperatures on both the 'frig and freezer on our Sub-Zero 650 have been varying randomly for some months now. The freezer is set for -5 but varies between -5 and -20; the 'frig is set for 34 and varies between 34 and 42. Sometimes both are at set temperatures and sometimes one or the other is off. Most times the freezer is colder than the set temp and the 'frig is warmer then set temp.
Any ideas? Sensors? - although one would think if a sensor was bad it would be either the frig or the freezer.
  • rockysma Feb 22, 2009
    I have a Sub Zero fridge Model 685 with the service words flashing which says it needs a new temperature sensor. I located the part #1063566 and need to know how to replace it. Is there a repair manual I can locate so that I can do it myself?
    Thanx for any assistance.
  • Sub-Zero Master
  • 5,568 Answers
Just posted this elsewhere and it sounds like the same problem:
As you probably know, the recommended temperature range is between 35-45 F so if your control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be an issue with Sub-Zero.
Posted on Sep 13, 2008
My 650 sub zero keeps alerting me to vacuum condenser even after I do so. What should I do?? My condenser is at the top of the frig.
I have found the users manual for this unit, and that my give you more information. Click HERE
Hope this gives you some relief
Joe
Aug 30, 2011 | Sub-Zero 650 / O Bottom Freezer...
Freezer reads 00 but the frig section reads 57....where is the line to the frig...seems that is plugged
i coud not see the model # of your sub zero . some models like th 550 / 650 use 2 compresors . freezer system maybe ok when fresh food is not . . first thing to do is ck the cond coil up on top and clean it and mk cure the fan is cooling the coil . you moy have a cold control failure . and the fresh food comp may be low on gas . these are the most common cause for your problem .. mm feed back pls ..
Oct 24, 2010 | Sub-Zero Bottom Freezer Refrigerator
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
We have our Sub Zero model 650 frig set to 35 degrees, our usual temp, but suddenly it won't get lower than 50. Freezer seems fine.
Check for a fan motor in between the freezer and the fridge. Or you have a block of frost in there shutting off air flow.
Jun 28, 2009 | Sub-Zero 650 / O Bottom Freezer...
Correct temperature for freezer & fridge
fridge should be about +4degC and freezer about -18degC
Sep 25, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero refrigerator freezes food
Hello. You need a new cabinet thermistor and while you are at it replace the evaporator thermistor. (The evaporator is the cooling coil behind the back wall of your fresh food section) . These sense the temperature in your frig. Both of them are behind the back wall of your fresh food compartment. You will need a wire crimper and a heat gun or lighter to heat shrink the wire connectors that come with the new ones.
Sep 20, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 561
You are number 3 in the series this AM-
As you probably know, the recommended temperature range is between 35-45 F so if you control will not allow you to set this, the sensor or associated regulator has failed.
This seems to be a problem with your brand; I'd check to see if there is a recall or factory 'fix' for this. They may have gotten a batch of defective sensors or controllers.
Aug 01, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 650 fidge holding at 53 degrees
Most likely you have a leak in the evaporator. Subzero warranties the parts for 12 years. Call them to find out what they will cover. They are agreat company and will be fair with you.
Jun 14, 2008 | Sub-Zero 650 / O Bottom Freezer...
Frozen vegtables within refrigerator (sub zero 650)
Replacing the light switch is not related to the temperature. Check the settings on your controls.
May 24, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
883 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
