Question about Peavey Delta Blues 115 30w All Tube Combo Guitar Amplifier
It rattles....even with the grill off....sounds like tubes rattling but I can't tell
    Problem Solver:
  • 13 Answers
There could be a small tear in the plastic liner over the speaker. If thats the case you can try pressing some cotton on it and then put the grill back in place, or find some fabric glue and glue a thin peice of fabric over the tear.
Posted on Mar 20, 2011
  • jaz90 May 07, 2012
    Mine rattled pretty bad until I tightened the power amp chassis screws up a little, 4 on top of cabinet and 2 on each side, made a big difference
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
Mar 20, 2013 | QSC Audio Products QSC HPR153I 12 SPEAKER
Hey my ax260 strings rattle alot mainly the bass strings? and every time i touch the coil tap knob a ugly sound comes from the amp its not even a year old yet and never been knocked over or droped could...
Strings "rattling" is usually guitar setup. This has to do with string height and POSSIBLY the neck truss rod. For the latter, have a guitar shop set it up for you. Hum from touching a knob is likely a broken ground wire in the cavity of the guitar. Also view videos on YouTube search "Guitar setup"
Apr 27, 2011 | ESP Ltd EX-50 Electric Guitar
Hello, well i just bought this week an MB4410 marshall and it sounds a lil bit distored even at low volumes and on the clean modern channel, i just wanted to know if thats how the amp should sound like or...
First make sure your guitar can't "hear" the amp as the sound can rattle the strings and have a form of feedback. Stand with your back toward the amp for example. If that doesn't help, take your guitar to the dealer and try it on another of the same type... see if it does the same. Also where you use it, make sure nothing is rattling in the area that can fool you as to how it sounds...
Apr 10, 2011 | Marshall MB4410 Bass Combo Amplifier
JRX125...there was a rattle/noise that indicated blown driver on midrange horn...replaced drivers, noise still occurs. discovered loose 1/4 in jack to tip of plug...tightened fit, but didn't trust...
The noise MIGHT be a resonance in the cabinet. The way to find out is to sweep a frequency upward to see if something rattles at certain frequencies... Don't be surprised to find several. Within the cabinet are the usual culprits: Wires rattling against the cabinet, loose debris, grilles and the logos on them, circuit boards with crossover hardware, cabinet wood that is not glued and rattles against itself. Things like bass port tubes can rattle.
Find an audio generator and sweep the cabinet from 50Hz to 10KHz and you will be surprised. Some speakers may have resonances as well. Expect things in your room to start rattling as well.
This is really the only way to find the problem. PLEASE wear hearing protectors at levels above 90Db.
Mar 27, 2011 | JBL New Jbl Jrx 125 Dbl 15 2 Way Speaker...
I have noticed a buzzing sound generated from the amplifier when I play my low e string
Several possibilities come to mind:
The speaker is driven too far mechanically causing the voice coil to go into a non-linear region.
The cabinet, stuff inside, grille cloth, or even a logo on the cabinet is resonant and rattles.
Your guitar setup is not quite right leading to "fret buzz"
To troubleshoot, reduce volume and see if that helps...
Mar 04, 2011 | Roland Cube 40XL Guitar Combo Amplifier...
Hi, I just got a new williams allegro digital piano, and the right speaker sounds noise with low keys.
If this is a brand new unit, exercise your warranty!
BUT FIRST see if packing material worked through the speaker grill... you know littel pieces of the packing peanuts or otherr contamination that sits in the speaker cone and rattles.
Feb 12, 2011 | Williams Allegro 88-Key Digital Piano
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Hi, I recently bought a fender hot rod deluxe which gives a very noticeable static sound. On the clean channel with the volume up to 4 it will be very audible. Is this normal or should it be brought to a...
Hello. You might have a "Tube rattle" problem. This is very common in these amps.
google "tube rattle" and you will find alot of people having the same issue.
There is some rubber tube dampers that you can buy to stop the rattling.
Hope this will help
/Daniel
Sep 23, 2010 | Fender Hot Rod Deluxe Guitar Combo...
I've got a Behringer Ultrabass Bb410 1200w 4x10 Bass Cabinet in which 2 of the speakers rattle. I know the speakers have been removed and rewired. How can I get an internal wiring diagram to check...
The cabinet is listed as a 4 ohm unit.
We would exoect to see four, 4 ohm speakers in series parallel or four 16 ohm speakers in parallel.
If teh unit seems to rattle, first put an audio oscillator into it and sweep the frequency. It is common for grilles and also logos attached to them to rattle.
Open the unit and power each speaker the same way individually for a test.
I suspect you will find either the grille or mounting hardware is actually doing the rattling OR possibly the wires inside are vibrating.
If the sound is a scratchy buzz, then the speaker(s) have probably had voicecoils damaged by overheating.
In this case, buy 4 new speakers and replace all. It is not likely to find replacements for the Buggera brand they put in these cabinets. Also the word on the web about that brand of speaker is not very good.
Sep 21, 2010 | Behringer Ultrabass Bb410 1200w 4x10 Bass...
There is a loose part in my Mini-Colossal that causes a slight rattling when playing a middle E. The rattling subsides when applying slight pressure to the power amp tube. I?ve since replaced the tubes,...
If this is a vacuum tube unit, SOME vacuum tubes will have spacers within them that can rattle. You cannot get into the tube of course to correct the problem. Replacing the tube MIGHT find one that does not have the loose parts in it.
Feb 19, 2010 | Peavey Jsx Mini Colossal Guitar Amplifier
Peavey Delta Blues 115 30w All Tube Combo Guitar Amplifier Logo
123 people viewed this question
Top Peavey Music Experts
Michial Gueffroy
Ben Armstrong
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Peavey Music Expert? Answer questions, earn points and help others
