Question about Sony KP-53N77 TV
We need to clean our Sony KP-53N77. We have some spider webs inside the protective screen and our color is a little fuzzy. We have never had the mirrors cleaned. How do we access the areas to clean and is there a danger of shock even if the TV is unplugged?
Remove the back hardboard cover by removing all the screws and lifting the cover up and toward you.
Mirror will be above but usually doesnt get dusty. Try not to touch it if you can. Same with back of screen. If you have a spider web just use a soft dry cloth to wipe it away.
You will likely find the upward facing lamp lenses covered in dust. Clean these with a soft cloth moistened with glasses cleaning solution. Glass cleaner works too.
Posted on Mar 20, 2011
  • Big_Petey6 Mar 20, 2011
    There is a risk of shock from the large capacitors on the circuit boards. These are the small canisters soldered onto the boards. They can hold a charge for some time. Just don't go out of your way to touch the exposed wiring and it goes without saying thay you will unplug the tv and let it cool before opening it up.
I have a sony kp-53n77 rear projection tv i cleaned the lenses but i still have alittle to much red how can i clean up the color
Older projection set:
Not knowing exactly what it looks like I suggest two things: first in the menu look for convergence to see if it is off adjustment wise--it can be adjusted in customer mode to see if that helps.
Also either turn color all the way off (Black and white) to see what color the screen is with no color--if somewhat red you will need to turn the red screen control down--I can tell you where and how.
If screen is too red, red will be the prominent background color with color off or on.
Another easy way to LOOK is go to an unused video input---should only see "Input 1" for example in green and rest of screen should be black and not red to any degree.
Let me know with a comment here what you find.
May 02, 2012 | Sony KP-53N77 TV
Spider webs in tv
Easiest way to deal with this is unplug set and remove the back cover. The area inside is fairly open---with a swiffer type duster reach in carefully and remove all the spider webs. Go easy along the inside of the inner screen so you do not scratch it or damage it.
Let me know if you have questions.
If this helped you rate this solution as I do this here for free.
SD TECH
Dec 08, 2009 | Sony KP-51HW40 51" Rear Projection...
How doI take the cover off to clean the inside of the protective screen? sony KP-53v80
I removed about 6 or so screws took back cover off and used a duster to clean the inside screen it cured my cobweb problem.
Sep 12, 2009 | Sony KP-53V80 53" Rear Projection...
I have a spider web behind the screen, how do i
sometimes on sony TV's on the sides you will have a door, that you can open with a screwdriver. if yours have it you might be able to dlean all that web from both sides, if not its a little bit more complex.
Jun 25, 2009 | Sony KP-53HS30 53" Rear Projection...
Words (movie descriptions etc.), just became fuzzy this week and the color is mostly ok when there is a close up on the screen, but watching something like a B-ball game is a little out of focus. I did the...
Sounds like you need to clean the lenses and reflective area inside your set. It is easy and all you need is a screwdriver, windex and a paper towel. UNPLUG YOUR TV.   Take off your screen and screen protector and safely set them aside.
Clean only the lenses ( glass part) and the reflective mirror type area on the top of the inside of your set.  It will look like new. You need to do this at least once a year.
Mar 13, 2009 | Sony KP-51WS510 51" Rear Projection...
Possible spider web inside of reprojection Tv
Yyou can clean screen's internal side by takeing off back cover of tv. Belo is picture how to open back cover.
Sep 24, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony kp-46wt-500 tv help
if your set has auto focus try activating it if not you require a convergence alignment.
Apr 13, 2008 | Sony KP-53N77 TV
Kp-53n77 color 53
Try resetting to factory settings via tha manual at this link.
It will download onto your computer in PDF form.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=KP53N77&LOC=3
Mar 11, 2008 | Televison & Video
Scratch on the screen
Unfortunately, no. The protective screen has to be replaced. Is it a scratch for sure, or possibly a spider web inside?
Feb 25, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-53N77 has no sound, no picture. Just a red blinking light.
How many times does it blink? It should blink a series of blinks pause second then blink again if it is in protective shutdown. Try to count the blinks then let me know if ts putting out a code or not.
Jan 24, 2008 | Televison & Video
Televison & Video Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
