Trying to use this product and get a 43 code and it dont work how do i fix this.
  • Computers & ... Master
  • 27,725 Answers
You might need to update the driver or reinstall it
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
Posted on Mar 20, 2011
91 3.1 car starts and runs fora minute then dies code 43 came up( fixed wire kn Sen.) now 21and 43 came up?
You didn't say what the make and model are, but if code 43 is a knock sensor issue I guess its a GM product.
Code 21 means the TPS voltage was too high, and code 43 means the knock sensor voltage was too high or too low.
Neither code would kill the engine. Just turn the warning light on.
If the throttle position sensor failed, you would get the effect of stalling on acceleration.
You may need to narrow down the possible causes to spark or fuel, and in the end it could be the engine computer. It could also be a relay or other electrical component.
Apr 08, 2016 | Cars & Trucks
How do I fix my ipod when my computer say error code 43?.
Some users have problem or reported that their iphone not syncing error code "43"if you are trying o solve the issue If the Error "43"occurs while syncing content other than music, then perform the same steps above but uncheck the content that stops syncing with Error"43".If your problem does not resolve the issue, attempt https://www.apextm.com/apple-customer-service/.
Jan 11, 2015 | Coby MP815 Digital Media Player
Error code 43
Code 43 is almost ALWAYS a driver problem, not necessarily an external driver, it could even be one of Windows' own. There is a well-written (in my opinion) page at http://pcsupport.about.com/od/errorc/a/code-43-error.htm which discusses the error and how to fix it in simple, step-by-step fashion.
Code 43 errors can be frustrating and time consuming to troubleshoot, but take you time, work it step by step, and best of luck to you.
Oct 21, 2013 | Western Digital My Book Essential 500GB...
How do I fix the msi motherboard windows 7 USB error 43?
How to Fix a Code 43 Error
  1. Restart your computer if you haven't done so already.
    There is always the chance that the error Code 43 you're seeing on a device was caused by some temporary problem with the hardware. If so, a restart of your computer might fix the Code 43 error.
    Note: Some users have also reported that powering off their computer completely (not just a reset) and then turning it back on has corrected their Code 43 issue, especially if it exists on a USB device. In the case of a laptop, turn it off and remove the battery, wait a few minutes, and then put the battery back in and start the computer.
  2. Did you install a device or make a change in Device Manager just before the Code 43 error appeared? If so, it's very possible that the change you made caused the Code 43 error.
    Undo the change if you can, restart your PC, and then check again for the Code 43 error.
    Depending on the changes you made, some solutions might include:
  3. Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a possible solution to a Code 43 error.
    Important: If a USB device is generating the Code 43 error, uninstall every deviceunder the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
    Note: Properly reinstalling a driver, as in the instructions linked above, is not the same as simply updating a driver. A full driver reinstall involves completely removing the currently installed driver and then letting Windows install it over again from scratch.
Sep 16, 2012 | MSI INTEL G41 INTEGRATED VGA-MATX 2DDR3...
I need to know what the code for a 1993 honda accord it flashed 4 slow then three short fast flashes, my car has been lagging really bad and i dont know exactly what i need to do to fix it i was told it is...
Found this for you on the web. Good luck.
c/p;
What is code 43?
Code 43 is "fuel supply system."
This code will trip when the ECU and the readings from the o2 sensor don't get along(in layman's term or easy enough for Si Speed to understand biggrin.gif) read the above two threads).
How to diagnose and fix?
First things first, when was the last time you changed your O2 sensor? Start by replacing that first because most likely, that's the main culprit. Now, you may wonder why doesn't the CEL indicate code 41(heated o2 sensor)? Usually when the o2 sensor is completely dead, that code will trip. Also, even though the o2 sensor is working, the voltage or ground isn't 100% Because of that, it will correlate with code 43.
If replacing the o2 sensor did not help code 43 to disappear, next thing is to replace your fuel filter. A clogged fuel filter will also trip code 43.
Next up, did you install an aftermarket Fuel Pressure Regulator? I have a few friends with 3rd gen Preludes and both of them installed aftermarket FPR's and they too, trip code 43. Him and a lot of people who install aftermarket FPR's mess with the PSI and that will cause code 43 to appear(on a stock ECU mind you). Bring it back to stock PSI to help fight code 43.
Those are the 3 main culprits that will cause code 43 from my experiences. Injectors, spark plugs & wires, most likely anything "fuel' related that isn't working properly will also cause code 43.
May 03, 2011 | 1993 Honda Accord
Fix code 43 for dell inspiron 1501
You may have to go to Dell Website. http://www.dell.com.au Go to support then in the search type in Fix Code 43. Comes up with approximately 25 solutions, I am fairly sure one will suit you. These are drivers etc to update your system.
Jan 22, 2011 | Dell Inspiron 1501 Notebook
My NVIDIA GeForce 8800 Ultra has stopped because it has problems Code 43. What is Code 43 ? How to fix it ?
Code 43 means that one of the drivers controlling the 8800 notified the operating system that the device failed in some manner. Check the hardware documentation for more information about diagnosing the problem. You can also download the latest drivers for the 8800Ultra from the Nvidia website.
Just select the following for each heading:
Product Type: GeForce
Product Series: GeForce 8 series
Product: GeForce 8800 Ultra
Operating System: Whichever Operating System you are using
Language: English (US)
Then click search and finally download.
The file size should be around 80.4MB.
Dec 03, 2010 | Computers & Internet
Fisher and paykel intuitive washer what is a code 43 please
HI, Go to this site is has all fault codes all you do is find your product click it and it will show you the fault codes and what they mean and suggest how to fix it. http://www.repairclinic.com/0078.asp
May 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Computers & Internet Logo
21 people viewed this question
Alun Cox
David Payne
David Payne
