Hello , i need just the hub for my ge washing machine model number WPRB8050D1WW...where can i find this??
    Sergeant:
  • 192 Answers
Http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=168736
You should be able to find it here.
Posted on Mar 20, 2011
The start button keeps blinking, WONT LET ME DO ANYTHING
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitIf this pin breaks off, the washer will not recognize that the door has be. ... Whatever cycle I choose, the light just flashes and holding the start button does nothing. ... I don't seem to have a black pin....the normal wash button just keeps flashing ...
GE Washer Start button flashing - DoItYourself.com Community Forums
www.doityourself.com/.../386041-ge-washer-start-button-flashing.html
Apr 6, 2009 - GE Washer Start Button flashing will not start Model WPRB8050D1WW, tried holding start button in for 5-10 seconds, did the unplug for 30 ...
Oct 29, 2015 | Washing Machines
How do you get the inner tub hub only, for GE top load washer?
You can go online to searspartsdirect.com and enter your model #. You should be able to find part description, price and part #. Google part #. Should be able to find pretty cheap
Feb 24, 2015 | GE Washing Machines
NEED TO REMOVE AN AGITATOR FROM A WASHING MACHINE
  • 1 First you must determine the brand of washing machine you have.
  • 2 To remove agitator on a whirlpool washer, remove top cap from agitator, Next you will find a translucent cap, remove this with your pliers. Then you will see a 3/8 inch nut, Back this nut out and you can then remove the agitator. Be Careful though, inside the agitator where the bolt has been removed is a white piece of plastic that holds the "dog ears". These dog ears are what lets the agitator move in one direction and locks when the transmission moves back in the other direction.
    Maytag and Admiral washers are very similar to remove. General Electric, (GE) is different, To remove a GE agitator simply pull upwards very hard, GE agitators snap on. Be careful not to pop it into your mouth, that really hurts.
  • 3 Remove agitator, repair or replace and reset, GE just push on, you will be able to see the groves to line up the agitator to the hub. For whirlpool place bolt into dog ear guide, and set down on top of transmission post and tighten, be careful that dog ears, do not get out of alignment. That's it.
    Buy F150 parts.
    Jun 03, 2012 | GE Washing Machines
    Does GE make the Frigidaire brand washing machine? and if so will the pump out of the Frigidaire work in the GE washing machine?
    Hello, welcome to FixYa. The GE frontloads of several years ago where indeed made by Figidaire ( not the other way around) though GE now make their own as do Frigidaire/Electrolux and no longer have anything in common. The GE that had been built by Frigidaire used identical pumps, you'll just need to provide a model number of the unit in question and I can tell what pump it uses...and what washers it will work in. Thanks for choosing FixYa today. Regards, Macmarkus :)
    May 27, 2011 | GE Washing Machines
    Hello, I have a GE profile washer model number WPSL3120W0WW. It won't agitate...what needs to be fixed?
    The belt most likely. Good vid on youtube shows how to get front cover off
    Mar 19, 2011 | GE Washing Machines
    The peice used to close the dryer has broken off is there maybe a peice that is usable to fix it or replace the item?
    Hello, truth1333.
    With the model number of your machine, try looking here:
    http://www.repairclinic.com/
    Enter your model number and hit 'Enter'.
    I'm not sure which piece you need, but try looking at the parts listed in 'Latch Parts' in the drop-down menu ('Part Type').
    Feb 28, 2011 | GE Spacemaker Washer and Dryer Electric...
    Have a ge WBSE2092A TOP LOAD WASHER - THE KNOBS ARE BROKEN. Need replacement. thx
    hello shah. you should be able to get them at searspartsdirect.com
    Have your model number ready as you will need to input that.
    Joe
    Thanks for choosing Fixya!
    Feb 16, 2011 | Washing Machines
    Washer drains but won't spin.
    The next time this condition occuers, take the front panel off the machine and look under the top cover of the motor at the right front side. There is a LED light on the motor inverter board there. If it is flashing twice, then a pause, then repeating this again and again you most likely have a loose hub nut on your wash basket. (the motor reads this as belt slippage)
    1. Order and install a new hub washer (WH2X1199) and a new split ring (WH2X1195) along with a new hub nut (WH2X1193). If the hub part of the basket is worn, replace that as well (plastic tub models = WH45X10027, SS tub = hub / basket WH45X10060.
    2. Tighten hub nut, torque to 110 ft-lbs.
    3. Clear flash code error. (your method to clear code is a bit more extreme than required, but will work)
    Mar 30, 2009 | GE WBSR3140DW Top Load Washer
    During wash cycle the hub nut that is located under the agitator comes loose. It has to be tightened after each wash. GE Profile Top Load Washing Machine
    replace the hub nut and the washers under the tubbe sure to tighten really tight if it comes loose again you will need to replace the transmition
    Jan 15, 2009 | GE Profile WPRE6100G Top Load Washer
    Washing Machines Logo
    32 people viewed this question
    Top Washing Machines Experts
