Question about Garmin Forerunner 310XT Handheld GPS Receiver
Stuck on low battery warning. Battery not actually low. Plugging in to charger does not help.
    Habit-Forming:
    New Friend:
  • 83 Answers
Just turn down you brightness, turn off wifi when possible, and use LEO Privacy to boost your phone and save battery.
LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Jan 17, 2017
4 Suggested Answers
  • 9 Answers
SOURCE: garmin problems
try contacting garmin they are at garmin.com they should have a dealer near you or take it back to where you bought it they should exchange it no problem as long as you have the reciept hope this helps
Posted on Aug 15, 2008
riceski
  • 1851 Answers
SOURCE: Low Battery notice kept coming on
TRY RESETTING THE UNIT - Also - charge the unit over night with a WALL CHARGER - this helped when mine pulled that same stunt. Eventually it went away after charging it over night in the wall. Here's how to reset -it just puts everything back to factory settings - 1- Turn unit on WHILE HOLDING your thumb in the lower right corner as shown in picture. 2-Select YES 5770b9e.jpg
Posted on May 08, 2010
  • 1514 Answers
SOURCE: My Garmin 760 charger appears to not be working.
It's most likely that the fuse has blown in the charger plug. Instructions complete with pictures are available from http://www.garmin.com/garmin/cms/cache/offonce/us/support/searchsupport;jsessionid=DB06036F1F1FBB6DE01E21EE59D70192
Posted on Aug 13, 2010
Why can't I turn on my Jabra sport after charging?
Could be. No battery has a lifetime forever. But perhaps you did not unplug it correct?
Try plugging it in and look if any light goes on when plugged in on the charger. You don't need it on the charger for a long time. Then unplug it an try to start it again. also check if all contacts on the Jabra and on the charge cable are clean and nothing can block the current.
May 23, 2014 | Jabra SPORT Earset
Telecom r100 battery
It could be one of these three things.
1. Bad port. Often in laptops these ports become loose.
2. Bad battery.
3. Bad charger.
Borrowing either a universal power charger, or the charger from someone with a similar laptop, can eliminate some of the possibilities unless it is indeed your charging port.
If after plugging it in, the battery charges you know you had a bad charger. If the battery fails to charge, you know its time for a new battery. Again this only if the port itself is not bad.
Universal chargers can be expensive. You can find batteries and chargers on Ebay for a decent price.
Mar 01, 2014 | Dell Computers & Internet
No flashing LEDs. Joystick and charger indicate full charge.
Time to replace battery - not taking a charge properly.
Aug 21, 2017 | Health & Beauty
My Camera just lost power, the lens is still stuck out, the battery was full when i used it, I also tried plugging in the charger now to see if it will restore power but it hasn't.. What should I do?
hi
usually camera doesn't lose power with lens stuck out, there must be external cause. But you should check first battery which actually is good or not.(using multimeter or to different camera that use same battery.) second with good battery is any light blinks momentarily. If any light blink then cause come from lens most case. But nothing happen then main pcb or power control pcb is the problem. Good luck with you!
May 22, 2011 | Olympus T100 Digital Camera
GE Simon 3 low battery warning: Newer battery has 6.54V?
Read the battery voltage with the system on but with the ac power disconnected. I always suspect the battery from experience. Battery needs to be replaced every few years normally(but can vary).
Jun 23, 2009 | GE Security Simon 3 Wireless Home Security...
My Ipod Nano Wont Charge on the wall Charger.
Hello Kawase,
I would suggest you try charging the unit this one time by connecting it to the computer. I suspect that the charger may be defective if plugging the wall charger into the iPod has no effect on the low battery warning. If the iPod is able to be charged from the USB port on your computer that would tend to confirm that the charger is not working. If the iPod does not charge when connected to either the computer or the wall charger then you may very well have a another defective iPod.
Best Regards
Ken
"Go Ahead. Use Us."
Jun 30, 2008 | Apple iPod nano 3rd Generation
Sansa E250 won't turn on after trying to plug it into an an ipod docking station my sansa mp3 player wont turn on or off the only way i can get it on is to plug it in to charge. and i cant take it to work...
my sansa e250 wont turn on only when i plug it into the charger...and when i try to turn it on without plugging it into the charger it says battery is low and turns off..when actually the battery is full...?
Jun 27, 2008 | SanDisk Sansa c240 MP3 Player
V262 constantly beeps "low battery" alert
your battery might need to be changed. even if it has a full charger it might not be able to properly charge you phone.
try a new battery.
Mar 06, 2008 | Motorola Mobility V262
Palm TX
Hey mike.
First, i have a question,
have you tried to reset it.
if not try it. press the little button at the back using your stylus and check if it will reset.
good luck
Nov 19, 2007 | Palm TX Handheld
Garmin Forerunner 310XT Handheld GPS Receiver Logo
194 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
