Printers
Problem for Printers
Generic problem for all Printers
I have a Lexmark x73
By BonBon40 on Aug 02, 2008
I have a Lexmark x73 I can print stuff but it won't let me copy anything it comes up on the screen artcopy 55 MFC has incountered a problem what does that mean it won't work
Solution #1
posted on Sep 05, 2009
Not Rated)
consumerissu
Rank: Apprentice
Rating: 0%, 0 votes
artcopy55.exe
Was this helpful?
Yes
No
Solution #2
posted on Aug 02, 2008
Not Rated)
devildox
Rank: Wiz
Rating: 81%, 16 votes
I found this answer to your problem on www.fixyourownprinter.com and it should help you. Basically, it looks like you will have to reinstall the application, but read the text of this post that I am putting below, first.
"If you're getting this error when you try to scan, fax or copy when logged on to Windows with a Limited User account (as opposed to a Computer Administrator account), read on; otherwise I have no advice to offer.
Artcopy55.exe apparently needs to be able to write to the file C:\balance.txt every time it does a scan. The default NTFS security permissions will stop it from doing this if it's run from a limited account, and instead of coping in any reasonable way with this (like, for example, simply believing the settings that are already in there) it just dies.
You should run artcopy55.exe at least once from a Computer Administrator account to let it create all the files and registry keys it needs, then apply Modify permission for Users, and Deny Delete permission for Everyone, to C:\balance.txt.
Artcopy55.exe also wants to save the scanned image into a subfolder of C:\Program Files\LexmarkX73, as well as mess with the contents of some settings files inside that folder. So you need to apply Modify permissions for Users to this folder as well. If you don't do this, copy and fax operations simply stop after performing the scan.
Process Monitor reveals all kinds of other files and registry keys that artcopy55.exe gets ACCESS DENIED results on when run from a limited account; however, it works OK with just these two changes."
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
MP 620 printer is it a good buy
Answer
konika minolta 1600 magicolor
Answer
unable to communicatec with computer, all 3 troubleshooting carried out but no avail
Answer
"no maintenance cartridge" displayed on canon IPF 8100.even i have change the maintenance... (More)
Answer
how do i unlatch the idler roller lock to install new ink cartridge?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printers Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(918) 583-5483
Elite printer Services, Inc. is a full service HP...
Elite Printer Services
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
