Question about Haier Washing Machines
The washing machine was on and washing a small load of laundry and all the sudden it stopped. Still on wash mode but no power is getting to it. I have tried unplugging it and plugging it back in and also tried turning it to spin mode but nothing is happening.
    Sergeant:
  • 192 Answers
Check to see if the circuit breaker has been tripped in your circuit box.
Posted on Mar 20, 2011
I just bought a used Frigidaire Affinity Front Loading washer (Model #FAFS4272LA0). When trying to start my very first load of laundry it went through the first wash cycle, but stopped and continued to...
Please remove power and allow the circuit to drain off, then switch on and choose a different program, if there is no change it can be due to some errors in the memory. check the main board of the controller , check for moisture within the board.
Sep 27, 2013 | Washing Machines
Wash machine - DST10146P Problem - After switch on and without any load in the drum, the kgMODE indicator appear, and the level load indicator starts blink the 10% levels from the mini to the MAX. The LED...
THIS MAY be your defective part!
BE VERY careful handling this switch because it's quite delicate!
1885374 "PRESSURE SWITCH" $89.68
Use THIS LINK:
http://spares.bigwarehouse.com.au/index.php?cPath=64618_64688_109010
These YOUTUBE video MAY help you!
Here is another YOUTUBE that discusses "Pressure Switches"... and that MAY be your problem. KNOW this is general information and not specific to your Hoover!
Diagnosing Washing Machine Pressure Switch Problems
How to Resolve Pressure Switch Problems in Washing Machine
Hoover and Candy Washing Machine Error Codes
TROUBLESHOOTING Link:
Dynamic Model No DST10146P 80 Product Code 31003253
Another snip-it:
..."Kg MODE Indicator". On Cotton and Synthetic cycles, during the first 4 minutes of the cycle the intelligent sensor will weigh the laundry and adjust the cycle time, water and electricity consumption accordingly. ...
More: The intelligent KG Mode sensor weighs the laundry and adjusts the cycle time, water and electricity consumption to suit the size of the load. This gives you the optimum consumption even if you are only washing one shirt.
During the first minutes of the cycle, the "Kg MODE" indicator remain on while the intelligent sensor will weigh the laundry
• Through every wash phase "Kg MODE"
allows to monitor information on the wash
load in the drum and in the first minutes
of the wash it:
- adjusts the amount of water required;
- determines the length of the wash cycle;
- controls rinsing according to the type of
fabric selected to be washed it;
- adjusts the rhythm of drum rotation for
the type of fabric being washed;
- recognizes
the presence
of lather,
increasing, if necessary, the amount of
water during rinsing;
- adjusts the spin speed according to the
load, thus avoiding any imbalance.
Dec 25, 2017 | Hoover Washing Machines
I have a ge profile harmony top load washing machine. Is there any way I can get more water to fill with certain loads of laundry?
there should be something on the console that says small medium large,that's the water settings.if you have a few things to wash put it on small,large load fill it up on large that's it.
Apr 09, 2011 | Washing Machines
My washing machin suddenly stop while I was doing laundry when it gt fill with water
After water filled, the machine will enter agitation mode. It stopped since the mechanism to engage the agitation to one direction of motor turning is not engaged. It is a helix nut to lock in the direction of motor turning (motor has 2 direction : one is for agitating and the other is for spinning). It is worn out and needed replacement.
Sep 20, 2010 | Kenmore Washing Machines
The twin tub connected to the washing machine doesn't drain.
The laundry tub does not have adequate drain size to handle discharge from the washing machine. In addition, the kitchen and laundry area piping may not be correctly vented.
May 17, 2017 | Daewoo DW500M Top Load Washer
Clothes get through seal and cause pump to stop
This has happened to us 3 times in the last month. Once it was a sock, another time men's underware and another time a thong...I agree, a laundry bag would be a good solution, but I would also have to put all wash cloths in a laundry bag because they are about the same size or smaller than a pair of "tighty whities!" I can understand a thong...but this is crazy!
Dec 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
Started washing machine; suddenly stopped drawing water
If you are certain there is water up to the inlet valve, and you can hear it humming, then there are 3 possible reasons.
  • The valve is not opening because it is stuck.Replace valve.
  • Check inlet of valve for a possible clogged filter, remove and clean.
  • Insuficient water pressure to open valve.
  • Plz rate my solution.
  • Thanks.
Jan 13, 2009 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
110 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
