Question about Bosch 24 in. SHU43 Built-in Dishwasher
Burnt wiring on Bosch SHX46A06 Dishwasher
My Bosch dishwasher is about 2 1/2 years old. It has operated with no problems for 2.5 years. I tired to turn run it this week with no success. No lights on the door and no power to unit. I removed the toe panel to gain access to the electrical. I found the wiring had melted along with the wire nut on the black side and some on the white side. The black 12/2 just broke after having melted off from the wire nut. I used the existing awg 12/2 with ground that was attached to previous dishwasher. No additional appliances were added to the existing load. The directions from Bosch had called for 14/2 with ground. Could this be a problem? Could I have made a bad connection for the start? Any thoughts to what might have caused the problem. I have done lots of wiring in my home prior to this.
Thanks
Bill
  • Anonymous Nov 29, 2008
    SAME THING HAPPENED TO ME TWICE NOW IN A THREE TO FOUR YEAR TIME SPAN
  • Anonymous Mar 12, 2014
    the wires(white) burnt through the wire nut and the ground wire broke
    Novelist:
  • 130 Answers
Bill that is exactly what happened, the connection wasn't correct from the start. The Bosch dishwasher pulls 11 amps during the cycle while heating the water to temp. The cooler the water the longer the heat time. Your dishwasher came with a set of wire nuts that where suppose to be used. Be sure when you correct this to use 20 amp wire nuts with the unit. This will stop this from happening again.
Posted on Aug 12, 2008
  • 725 Answers
The problem with this solution is that a 12/2 is a larger wire than a 14/2 ..the 12/2 wires are just fine you mush have had a loose connection at the wire nuts..
Posted on Aug 21, 2008
I have a shu43 bosch dishwasher and the whole machine is dead. No power. The circuit breaker is good but I would have to pull the dishwaher out to check the outlet. Is there an internal fuse?
There is no internal fuse (at least I've not seen or replaced any) on Bosch dishwashers. The most typical problems for Bosch are: 1) one of the power cord connections to the internal wiring is corroded and doesn't make a contact; or 2) the power button has failed.
The number one is so far the most common problem. To check: Turn off the power to the dishwasher by any means necessary. Remove the kick panel on the bottom. There should be a small metal box with power cord and 2 or 3 wires coming into it. Remove screw(s) holding the cover on that box. There should be 2 or 3 wires connected to the power cord wires by wire nuts. Any burnt insulation or wire nut will be the problem area. Cut burnt wires, remove 1/2" of insulation and clean of both connecting wires to bare copper. If you have an electrical contact grease - apply to copper. Install new wire nut.
Good luck,
Vlad with First Choice Appliance, Sacramento, CA
Jun 28, 2012 | Bosch 24 in. SHU43 Built-in Dishwasher
Cycle does not finish leaving dirty water bottom of tub without draining out
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 12, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Both upper and lower water dispensing devices are not spinning
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Sep 01, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
OUR BOSH 24 IN SHX46A02 BUILT IN DISHWASHER WON'T DAIN
consult handbook for checking for blockages this is a user serviceable component and can be serviced easily.
May 27, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
My 4 1/2 year old Bosch dishwasher won't clean.
this tells me that you have a drainage problem chk. the hose for kinks and or plugs
Aug 23, 2009 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Won't turn on
The door switch is definitely not the problem if the indicator lights are not coming on. These lights are supposed to come on when the door is open.
The problem is 1 of 3 things:
1) No power to outlet that DW is plugged into;
2) Bad connection where power cord is connected to dishwasher (see very bottom front, under kick panel)
3) Some problem internal to the DW (eg., bad switch, shorted wire, etc., )
Our SHX46A is definitely having problem 3, but Bosch's manual gives zero help. So, off to find more info online or, lastly, to call Bosch repair person. Sigh.
Jun 13, 2007 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Sprung leak when dishwasher was off
could be the valve but more likely is the fill hose itself. pull it out, turn on the water and check the hose carefully especially at the ends wher it joins onto the tap and the machine
Apr 08, 2007 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Bosch 24 in. SHU43 Built-in Dishwasher Logo
533 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
