Question about MegaVision Hyvision MV176 17 in. LCD Television
How do you program the tv for local channels - MegaVision Hyvision MV176 17 in. LCD Television
  • 902 Answers
Go into menu and there should be a channel search you must do a cable and over the air channel search. and your good to go. it may be called something else then channel search on your model
Posted on Mar 20, 2011
Programming channels for TV viewing?
You can often find the digital channel numbers for your local stations in a guide like http://www.titantv.com/ or https://tvschedule.zap2it.com/?aid=gapzap . Alternately, check if the local stations websites offer a link to their schedule. This will usually list the channel/channel digital identity. Another source for the digital channel numbers are the antenna choice/position/direction guides. Look at http://www.antennaweb.org or http://www.tvfool.com . Tvfool.com gives the direction and signal strength for all channel transmitters in your general area. Antennaweb.org is much more conservative and will only give the strongest stations in your area. That conservative list assumes an external antenna and clear path between the transmitter and your antenna.
In my area, the analog channel 7 became digital channel 7-1 . However, the channels 12 and 16 now transmit at 43-1 and 46-1 . However, after letting the TV do the auto-search, they are 12-1 and 16-1 when I type in the channel numbers on my remote.
I hope this helps. I might be able to provide a list of your local digital channels if you add a comment with your general location.
Mar 04, 2018 | Panasonic TH-42PC77U TV
Could you tell me why the tv insignia channels swich fron 2 to 3 channel, and the tv value is going up and down by itself? Because I"m not able to watch my programs. Can You help with this?
if you have set top box ,go to main menu ,check on restore factory settings ,put in default password 0000 and press ok,restarting the set top box automatically,waiting for some minutes.
restarting starts scanning all channels one by one and put them on their respective location in channel store.
now ,enjoy with all channels.
same process is done with tv if u have't any set top box ,only RF input from ur cable operator.
Nov 29, 2009 | Insignia IS 20" TV040919 TV
Have Direct TV using a Sony Digital Satellite receiver model #SAT B2-2 /Sony Satellite dish purchased in 7/97. I get local channels thru Direct TV. Recently, local channels will show on the Direct TV guide...
Your dish is out of alignment. The local channel satellite doesn't have as strong of a signal, so a slight misalignment will cause problems.
It could also be an F-connector needs to be replaced at the dish or multiswitch (if you have one). Sometimes moisture builds up inside the connector and corrodes the copper stinger inside.
If you go into your satellite signal strength menu and find the local channel satellite, you're sure to see either a weak signal or an intermittent one.
One more thing, if a tree has grown in the line of sight between the dish and the satellite, this will cause signal problems too. In this case, you either have to trim the tree or move the dish.
Hope this helps!
P.S.
The customer service reps at DirecTV usually idiots reading from a script with no real field experience.
Mar 25, 2009 | Televison & Video
Television only locates 7 channels????!!!!!
Hi there!
If you cannot receive all channels it may be a fault with the antenna or the tuner may be faulty. If you have a VCR, you can tune that into the TV first and then tune the VCR to see if you then receive all channels. If so, use the VCR position on the TV to view and select or change channels on the VCR only. Good Luck,JUS004
Mar 07, 2008 | RCA F32649 32" TV
Sanyo DS31350 31" TV problem
you need to buy the sanyo remote from www.sanyo.com
Dec 14, 2007 | Sanyo DS31590 31" TV
Some channels not programable
Bad tuner = verify part # from back of set to get part #...
Let me know..........................T.
Nov 22, 2007 | JVC AV-27D303 27" TV
MegaVision Hyvision MV176 17 in. LCD Television Logo
76 people viewed this question
Top MegaVision Televison & Video Experts
Are you a MegaVision Televison and Video Expert? Answer questions, earn points and help others
