Question about Cosmi Computers & Internet
My business pak does not work with windows 7
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 64 Answers
The alternatives that you have are: - Downgrade Win 7 to XP (not recommended) - Install and run XP under a virtual machine: vmware or virtualbox (laborious) - Search alternative programs (recommended) Good luck!
Posted on Mar 20, 2011
Dosn't work with windows 7
Broderbund's ClickArt 200,000 Image Pak should install quite easily on a 32-bit version of Windows 7.
64-bit version of Windows 7:
It is not possible to install ClickArt 200,000 Image Pak on a 64-bit version of Windows 7 - because the Setup.exe file is not compatible with any 64-bit Operating System. That is due to the fact that the Setup. exe file contains 16-programming code. 64-bit Operating Systems cannot handle any 16-bit programming code.
Hope this answers your query. Cheers!
May 03, 2011 | Broderbund Clickart 200,000 Image Pack for...
Motor works window does not go up drivers side 1997 grand marquis
u most likely have a bad gear pak in ur window motor,which can b serviced seperatly, or u have a window regulator that consists of plastic pulleys an steel cables monted on stamped steel frames,which are weak designs an almost always fails causing condition u decribed. if u remove dr panel u can see a bad regulator by noticing cables jus layn around not hooked to anything,or cables not routed thru the small plastic pulleys.if all ur cables are intact the gear pak which consists or plastic parts for safety reasons,has gone bad an can b serviced without buyng a new mtr, jus purchase the gear pak install an ull b bak in business. good luck
Mar 24, 2011 | 1997 Mercury Grand Marquis
My old computer with a Borland dBase 5.0 program on it crashed but the hard drive was salvaged and I have hooked it up to my new computer. However, my old computer ran Windows XP on 32 bit, the new one...
Do I need Windows XP Mode?
Windows 7 has several built-in tools to help with program compatibility and Windows XP programs should be installed directly on Windows 7. Windows XP Mode runs many older Windows XP productivity programs and that are not natively compatible with Windows 7, thus helping realize cost savings and reduce possible operational downtime by extending the life of existing software. Visit the Windows 7 Compatibility Center to find software that works with Windows 7.
http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
It's the best of both worlds: The new Windows XP Mode lets you run older Windows XP business software right on your Windows 7 desktop.
Designed primarily with small- and medium-sized businesses in mind, Windows XP Mode comes as a separate download and works only with Windows 7 Professional, Ultimate, and Enterprise. Windows XP Mode also requires virtualization software such as Windows Virtual PC. Both are available free on the Microsoft website.
Download
Learn how
Jan 23, 2011 | Borland DBASE 5.0 Upgrade Version Academic...
I can't get any game to work. We used to be able to wiggle the game or take it out and put it into the console on a different angle, but now it won;t work at all. The power light still comes on on the...
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance.
  1. Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
  2. Make sure the Game Pak firmly clicks down into place.
  3. Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
  4. Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
  5. Check the list of specific game issues to see if there are any known problems for the game you are playing.
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product.
  • Controller Error Messages (e.g. No Controller Detected)
    1. Make sure you are using all licensed accessories with your system. Make sure both the controller is licensed and any accessories you are using with the controller (Rumble Pak, Controller Pak) are licensed as well. Unlicensed products may not be fully compatible with our systems.
    2. Slide the Power Switch on the control deck to the OFF position and unplug the controller. Plug the controller back in, making sure the controller-plug is firmly inserted into socket one (on the left front ofthe control deck). Slide the power switch on the control deck to the ON position.
    3. If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
  • Character Won't Move or Moves on its Own
    1. The most common cause of this problem is when the control stick on the controller is not in the neutral position when the N64 system is turned on. The neutral position is when the control stick is centered, as it is when you hold the controller while not touching the control stick. Recalibrate the Controller by using one of the following methods:
      • Turn the power off on the system. Make sure the control stick on the controller is in the neutral (center) position, and slide the power switch to the ON position. Be sure not to touch the control stick for the first few seconds.
      • During game play you can press the L+R+START simultaneously while the control stick on the controller is in a neutral (center) position.
    2. Consult the Game Pak manual for information on the primary directional control for the game. Some game paks use the control pad rather than the control stick for character movement.
    3. Try cleaning the controller (See Below).
    4. If possible, try another controller in the left-hand port. If you have a second Controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here..
  • N64 Sticky Buttons or Control Stick, or other controller problems Try the following cleaning procedures:
    1. Unplug the controller from the control deck.
    2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the controller in any type of liquid.
    3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the controller around the buttons and control stick.
    4. Work the bristles down around the sides of the buttons and the control stick.
    5. After cleaning the controller, dry it off with a paper towel.
    6. Let the controller air dry for at least a couple of hours.
    7. Test the controller for proper response.
    If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 7. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
Transfer Pak
  1. Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
  2. Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
  3. Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
  4. Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
  5. Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
  6. Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
  7. If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Controller Pak
  • Deleting Saved Information From Controller Paks Depending on the game you own, there are a couple of different ways to delete the saved information on a Controller Pak.
    1. While turning on the Control Deck, hold down the START button on Controller #1. If the programmers utilized this feature, a Controller Pak menu should appear. This menu will allow you to view and delete the contents of the Controller Pak.
    2. If the first option doesn't work, then the game pak will have a feature that can only be accessed from a game menu. For example, in Wayne Gretzky's 3D Hockey, you delete saved info from the Options screen.
    To find out the specifics of how the Controller Pak works with a particular game, check the game's instruction manual.
Expansion Pak
  • For assistance with installing the Expansion Pak, click here.
Jan 19, 2011 | Nintendo 64 Console
Will not print. Have to power off and then power back on for printer to start.
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet P2015dn Printer
Windows 7 and Mathcad 14 compatibility
can anyone get me information whether Mathcad 14 is working on Windows 7
Thanks in advance
Nov 25, 2009 | Mathsoft Mathcad 14 for Windows Full...
Cant find drivers on windows 7
Summary Use Vista Driver in Windows 7
Detail Driver Support
For many of our products, the Vista driver will work in the Windows 7 environment.
Driver Availability
The links below list products which have Windows 7 support.
Windows 7 Home Office and SMB Products (Inkjet and All-In-One)
Windows 7 Business Products (Laser)
Nov 23, 2009 | Lexmark X2350 All-In-One InkJet Printer
Which version of windows 7 goes with primavera 6
It works with Win 7 Ultimate, but it should work with all versions -you need to install SQL Server SP3 BEFORE running P6 for the first timethough...
SQLServer2005SP3-KB955706-x86-ENU.exe
Nov 17, 2009 | Primavera Project Planner P3 (PRIMAVERAP3)...
COD 1.3 build win-x86 Mar 2 2004 -----
For this you have to back up your file and they it can work or you can restore the computer that day when it was good . Just cilcke on Strat then click on programmes and accress and system tools and and at last clike on system restore ...
Jul 11, 2009 | Computers & Internet
Nintendo 64 console
Too many variables to answer this yet. Where did the expansion pak come from? Was it new or used? Was a jumper pak in place and the console working before you installed the expansion pak? Did you unplug the console before removing the jumper pak and installing the expansion pak?
Dec 02, 2007 | Nintendo 64 Console
Computers & Internet Logo
Top Cosmi Computers & Internet Experts
Tony
Alun Cox
raysaw
Are you a Cosmi Computer and Internet Expert? Answer questions, earn points and help others
